Question about EliteGroup K7AMA Motherboard
Memory settings for ddr - EliteGroup K7AMA Motherboard
  • EliteGroup Master
  • 5,660 Answers
Http://www.motherboards.org/mobot/motherboards_d/ECS/K7AMA/
Since the Processor Front Side Bus (FSB) support is 200 or 266MegaHertz (MHz), the ram memory will be DDR Sdram at either 100Megahertz or 266MHz.
That is PC1600 and PC2100, respectively.
2GB's maximum TOTAL amount for motherboard.
1GB per ram memory slot - Maximum
If you have a Socket A (Socket 462) AMD processor with a 200MHz FSB, I suggest DDR Sdram at 100MHz. (PC1600)
AMD processor with 266MHz Front Side Bus = either PC1600, or PC2100. I would go with PC2100.
Voltage in BIOS Setup is 2.5 Volts. That is is the JEDEC standard voltage, for DDR Sdram.
Ram timings will be dependent upon what the ram memory supports.
IF you have just ONE ram memory module ('Stick'), it goes in Slot 1.
(DIMM 1)
This is the ram memory slot the Processor reads first.
http://www.cpu-upgrade.com/mb-ECS/K7AMA%28V1.5%29.html
http://www.ocinside.de/go_e.html?http://www.ocinside.de/html/workshop/ecs_k7s6a_vcore.html
http://8000.hillbillyhardware.com:8000/Reviews/ecs_945gcd-m/ecs_945gcd-m.html
"When it comes to innovative motherboards ECS is not a company that first comes to mind. Not since the days of the K7AMA that offered DDR266 and PC133 memory options for AMD's K7 line of processors has ECS released a motherboard that has filled a gapping hole in the PC hardware market space. Lets just hope that the failure rate of the 945GCD-M is nothing like the failure prone K7AMA."
Hmmmmm,
Not doing it for you? Then post more details in a Comment.
Regards,
joecoolvette
Posted on Jan 03, 2013
How much ram can I install on my Averatec 2200?
The ram maxes out at 2GB. There is only one memory slot, so you would need a 2GB memory stick. Hope this helps.
Regards,
Matt
Apr 15, 2011 | Computers & Internet
DDR modules not recognized on P4VXASD
either you have the wrong memory or the memory is not seated properly.also set the jumpers to default or try resseting your bios some time reseting things will let the bios auto pick up whats installed.
Jan 08, 2010 | EliteGroup P4VXASD (P4VXASD-R) Motherboard
Memory is not compatible to motherboard
You might want to go into the motherboard BIOS and change all of the memory timing settings to AUTOMATIC. The settings that are currently configured may be set too high/fast for the new chips.
There are many different specifications/speed settings that can differ from memory chip to memory chip, even within the same general MHZ category (Like your DDR 400)
Jan 04, 2010 | ASUS P5PE-VM Motherboard
How to install additional 256 MB memory
You simply just push the memory into the DIMM socket on the motherboard. You need to use DDR SDRAM but should check what your I/O bus speed is set at. They make 4 different types of DDR SDRAM. They are DDR-200 (PC1600). DDR-266 (PC2100). DDR-333 (PC2700) and DDR-400 (PC3200). The following links should help you out:
http://www.tech-faq.com/unbuffered-memory.shtml
http://en.wikipedia.org/wiki/DDR_SDRAM
Mar 20, 2009 | EliteGroup P4VMM2 Motherboard
Memory DDR
have you checked the memory settings in the bios check the manual how to do this
Feb 20, 2008 | Gigabyte GA-8KNXP Motherboard
RAM upgrate
you can upgrade to a max of 2gb on that board. These are your 1gb options: 1GB PC2700 333MHz DDR Memory, 1GB PC2100 266MHz DDR Memory, and 1GB PC3200 400MHz Non-ECC Unbuffered 184-pin DDR DIMM Memory. Install a set of any of these and your off and running.
Dec 22, 2007 | FIC P4M-800T Motherboard
ECS M925 1.0 sdramm to ddr memory
The normal DDR Ram is supported..It doesn't support DDR2..
Nov 03, 2007 | PC Chips (M925G) Motherboard
Missing part
Hi, Sorry to tell you but this motherboard supports ONLY SDRAM memory. There is no way that a DDR memory will fit into this motherboard. What you can do is add another SDRAM memory for better performance.
Apr 28, 2007 | Syntax SV266A SKA KT266A Motherboard
EliteGroup K7AMA Motherboard Logo
59 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
