Question about HP Officejet 5610 All-In-One InkJet Printer
5610 all in one cartridge error "see troubleshooting"???
What do i do? have tryed holding #6 and ok cancel and unpuging?
  • Anonymous Jan 22, 2009
    cartridge error: refer to device docmentation
    Problem Solver:
  • 10 Answers
Please let me know what is the exact error message you get on the printer screen.
and also let me know which cartridges you are using.
the cartridges you need to use are HP Black : 27 or 56
HP Tri color cartridge : 22 and 58
Posted on Jan 21, 2009
Display reports: Problems in inksystem. Error no: 0xc18a0306 What do i do?
error detecting ink volume and will need to be cleared by resetting your printer. here are the two ways to reset it.
Reset to default setting
1. While your printer is on, unplug to power cable from the printer.
2. Press and hold the "OK" and "HELP" buttons while you plug the power cable at the back of the printer.
Full reset
1. Press & hold " * " key...(asterisk sign)
2. While holding the " * ", press "#" key and then release both keys."Enter Special Key Combo" will be displayed.
3. Press "1", "2" and "3" to display Support.
4 Press ">" right arrow button and release when System Config Menu appear, then click OK
5. Press arrow key to display Hardware Failure Status, click OK.
6. When Hardware Failure Status:Clear appeared, press "OK" to clear.
7. Press "OK" again to display "Hardware Failure Status Cleared. Press Cancel To Continue".
8. Press "CANCEL" as many times to display "Welcome To Photosmart Express" or "Ink System Failure".
9. The last part is to turn off the printer and unplug at the back, wait for 30 sec, then plug and turn on the printer, if asked, press "OK" to continue and allow the "One Time Ink Initialization" to procede..After this try to print
Don't forget to rate this answer.
Thank you for using Fixya.
May 26, 2011 | HP Photosmart 3210 Printer
Error:oxc18a0401??
Hi There,
These are reset instructions designed to clear most of hp errors starting with 0xc...It works on different hp models.. it could work on you too.
Semi reset
1. While your printer is on.. unplug to power cable from the printer.
2. Press and hold the "OK" and "HELP" buttons while you plug the power cable at the back of the printer. Try these steps to reset your printer to default setting.
Full reset
2. While holding the " * ", press "#" key and then release both keys..."Enter Special Key Combo" will be displayed...
3. Press "1", "2" and "3" to display Support...
4 Press ">" right arrow button and release when System Config Menu appear....then click OK
5. Press arrow key to display Hardware Failure Status...click OK....
6. When Hardware Failure Status:Clear appeared, press "OK" to clear...
7. Press "OK" again to display "Hardware Failure Status Cleared. Press Cancel To Continue".....
8. Press "CANCEL" as many times to display "Welcome To Photosmart Express" or "Ink System Failure".....
9. The last part is to turn off the printer and unplug at the back...wait for 30 sec, then plug and turn on the printer...if asked, press "OK" to continue and allow the "One Time Ink Initialization" to proceed..After this try to print...
If you find the reset solutions helpful...Please rate this solution and vote YES ..thanks..
Nov 04, 2010 | HP Photosmart 3210 Printer
What does error oxc18a0106 mean?? I have replaced all the ink cartridges this afternoon and still won't print
Full reset
Sep 11, 2010 | HP Photosmart 3210 Printer
How do I fix Error:Oxc18s0301 Ink system failed.
Try using these two reset instruction...these clears most of hp errors starting with 0xc...It works on different hp models.. it could work on you too.
Semi reset
Full reset
If you find the reset solutions helpful to you...Please rate this solution and vote on this on the YES below..thanks..
Aug 20, 2010 | HP Photosmart C6280 Printer
Error: Oxc18a0401
here.. check this out. a solution to your problem.
Semi reset
Full reset
Aug 16, 2010 | HP Photosmart 3210 All-In-One InkJet...
0xc18a0001
Semi reset
Full reset
9. The last part is to turn off the printer and unplug at the back...wait for 30 sec, then plug and turn on the printer...if asked, press "OK" to continue and allow the "One Time Ink Initialization" to procede..After this try to print...
Jun 02, 2010 | HP Photosmart 3210 Printer
My hoppoint washer wf 640 say test, what do i have to do to solve thgis?
Hiya,
It depends on the version of your machine, there are three methods so try them all.
Try pressing and holding 3start/cancel until all the leds light.
Then press start/cancel and on/off until dOFF is displayed.
Machine should now be ok.
If that one doesn't work.
Try pressing and holding the cancel button. Machine should now be ok.
Finally
Press and hold start/cancel, on/off and the top left option button until dOFF is displayed. Machine should now be ok.
Hope this helps.
Thanks
Dec 26, 2008 | Washing Machines
WON'T SEND FAX FROM FEEDER.
u can try the following steps >
unplug the power cord from the back of the unit [without turning off the unit ] > press and hold ok and cancel key together > while holding these keys down plug in the power cord back into the unit . do not release the keys > wait for a few seconds it will make certain noises an wud turn off automatically .
turn on the printer again it will go into allignment phase > let it finish.
after its done > try to make a copy from the feeder .
Note - In case [ok and cancel key ] combination doesnot work < u can try # and 6 key combo as well with the same procedure.
THANKS
Mac
Mar 27, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Hp 2115
issue with carrage , try cleaning ink carrage .
first
*unplug the power cable and press and hold power button for 1 min
*press and hold # and 6 , while holding # and 6 plug the power cable back in
*release the button after 10 sec
*wait for some time
*open carrage access door
*cleane printer carrage see for any dust in carrage
*pull the carrage to left
*turn off printer and turn it on
then try pressing OK and cancel at the same time
check for test page
Feb 17, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Cycle Power
instead of # and 6 try
unplug the power cable, press and hold :
OK and CANCEL, while keeping them on hold put the power cable back in ... it ll do a full NVRAM reset on it ..
It ll be fixed .
Best of luck
Dec 20, 2006 | HP PSC 2410 All-In-One InkJet Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
269 people viewed this question
Ben Johnson
