Craig 7 inch netbook won't charge now
Net book was charging this morning but battery is dead now and won't charge.
Gort007
  • 1187 Answers
SOURCE: My TOSHIBA MINI NB205-n313/9 10.1 inch net book will not turn on
The instructions say to let the battery charge for 8 hours before use.
Test the computer:
1. Remove the battery from the netbook.
2. Use the power adapter and turn ON the netbook (without the battery). It should boot up and ask you a lot of questions.
When finished:
3. Put battery back in netbook while the power is still plugged-in and the netbook is still running (Windows).
4. The netbook will continue to operate with the battery in.
5. Shut down Windows and let the battery complete the 8-hour charge.
I hope this is clear ...
Posted on Sep 15, 2009
HEMPYODA
  • 168 Answers
SOURCE: Advent Netbook 4489
IT sounds like you need to replace your battery. If your laptop (notebook) is working properly while plugged in with Ac power we know it is not your power supply.
I would visit the manufacturer's website for replacement batteries. One complaint I have read about over and over on these particular systems is that the battery life is very poor.
Posted on Sep 17, 2009
  • 20 Answers
SOURCE: battery is not charging
Here are some great source where will will get any kinds of HP,ACER,DELL and COMPAQ laptop Solution and any kinds of Driver download.
» Hp Laptop's Solution
» Compaq Laptop's Solution
» Acer Laptop's Solution
» Dell Laptop's Solution
» Toshiba Laptop's Solution
» Asus Laptop's Solution
» Hp Driver's Download
» Compaq Driver's Download
» Acer Driver's Download
» Dell Driver's Download
» Toshiba Driver's Download
» Asus Driver's Download
jodiki20
Posted on Jan 03, 2010
jryc32
  • 408 Answers
SOURCE: My daughter's Acer Aspire 5732Z laptop will not
It sounds like the battery charging ac cable might be faulty.. You might want to go to a local shop and see if they could try another cable before you go out and spend money on a new one. They usually will try a cable to see if that's the problem.. Please let me know if this washelpful and if it solved the problem and good luck..
Posted on Sep 10, 2011
SOURCE: Netbook charging indicator light won't light
If the battery won't charge and the laptop won't turn on but the ac adapter works with other laptops, then the problem is the port where you plugin the ac adapter. Some of the laptops has it built in to the motherboard. So you might need to have it repaired by a technician. Or if the laptop is still in warranty, you might need to send it to the manufacturer to have it repaired or replaced. But if the laptop works without the battery, or it will turn on but the battery indicator is not lighting up, you're facing one of these problems.
1. The battery itself is dead. 2. the battery bay is loose 3. the battery itself is loose
Hope this helps...
Posted on Sep 15, 2011
Factory rest
call customer service for craig 1-866-321-7191.
Feb 05, 2014 | Craig Electronics Recertified - Craig...
Lack of useable app downloads
The LG G3 is something spectacular compared to that net book lol. That net book is honestly too slow in my opinion but I would try jail breaking it if its on android and then putting a new more updated version, like android 4.0
Jan 22, 2014 | Craig Electronics Recertified - Craig...
I forgot my password on my craig 7inch netbook how do i hard reset my device?
To reset the 7 inch Craig Netbook you need to shut it down and take out the battery, Leave it for couple of mins with no charger (press and hold the power button to get every bit of power out of the various components inside) and put the battery and charger back in and power it back up.
Oct 06, 2013 | Craig Electronics Recertified - Craig...
Charging asus eee 1001HA netbook
Does your unit power on at all or is it just not charging the battery?
If it's just not charging your battery the likely cause is the battery has just gotten used up, replacements are usually between $50 and $89 CAD
Oct 17, 2012 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Samsung N145 Plus battery charge failure
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Sep 03, 2012 | Samsung Computers & Internet
Netbook charging indicator light won't light and battery won't charge. AC adapter works on other computers
Hope this helps...
Sep 15, 2011 | Gateway LT2021u Netbook
My COBY NetBook can't switch on. What is the main reason cause by the netbook? Any solution to solve it?
The battery could be dead or completly dead so that means it won`t hold a charge. The way to fix it is to replace the battery. But this might not be the exact reason though.
Jul 23, 2011 | Coby PC Netbook 1ea
The laptop is not turning on?
Remove the battery and try boot the machine on AC power only. If the computer starts up turn it back off, reinsert the battery and try to boot the computer again.
If it still won't boot with the battery inserted then i suggest you send or take the computer back as there is a hardware problem.
Regards.
Sep 15, 2009 | Toshiba Satellite PSAG0U-02D00M Notebook
Computers & Internet Logo
191 people viewed this question
David Payne
David Payne
