Question about Avaya Office Computers & Internet
Avaya 5610 SW IP phone extension Login
I am adding another phone to our system. I have set up the user and the extension. When I plug in the phone I know I have to tell it what extension it is. I press "Login" and enter the new extension "345#", then press next. when I set up the ones in use I didn't enter a password just pressed "done" but I get the word "INVALID". I think there may be a default password. Does anyone know what it is? How to solve the issue? Thanks.
SOURCE: Avaya 5610 double display on incoming caller ID
Did you get this fixed. I would double check the firmware files of the phone. And maybe reset it.
Posted on Dec 25, 2007
SOURCE: Avaya 5610 IP Phone
Press mute reset (mute 73738)
Posted on Oct 21, 2008
  • 33 Answers
SOURCE: CHANGE OF PHONE NUMBER
On thephone go to options button on that logoff then it will reboot after that it will ask for a extension provide the desired extension number.
Posted on Dec 08, 2008
  • 10 Answers
SOURCE: Avaya assighning New static IP address after IP address conflict
If you need to reconfigure the phone press "mute"RESET# where the alphabets correspond to the digits button they appear against on phone. E.g. for R press 7... and so on ..... then the phone will ask reset values? press # to reset and reboot the phone. Then key in the correct IP address for phone .... call server IP address ... router .. files server .... VLAN ID etc ....
If all the settings are done correctly ... and if the phone gets the reach ability to the call server it will work fine...
if you are unsure of these settings.... go to the menu and network options of any working phone and get the correct values from there
Posted on Apr 02, 2009
  • 10 Answers
SOURCE: How to configure Avaya's IP Phone 5610?
Ensure the reachability of the call server from that port. To ensure the same, configure a laptop with the IP address and default gateway of the intended IP phone. Then try pinging the call server from the laptop.
If this works then the setting should work for IP phone too. Double check on the router IP address and Vlan ID configured on the phone.
Avaya phone 5410 how can I manually change time
The IPO should get its time from the VM Pro server. The time server should be
set to the IP address if the VM Pro pc. If there isnt a vmpro pc, you can set
it manually.
http://mfurrer.dyndns.org/?p=224
For IP Office systems without access to a time server, a number of methods to
manually set the system time exist. These are available in the IP Office 4.1+.
The following method is only supported on these phones: 2410, 2420, 4412, 4424,
4612, 4624, 4610, 4620, 4621, 5410, 5420, 5610, 5620, 5621, 6412, 6424. It is
supported on any analog, T3, T3 IP or wireless (IP DECT, 3600, 3700 Series)
phones.
Note: If the IP Office system that is still configured for automatic time
updates (on by default), any manually set time and date will be overridden on
the next automatic update. The use of automatic updates can be disabled by
setting the System ' System ' Time Server IP Address to 0.0.0.1.
Enabling a User Button for Time and Date
Select the user who can adjust the system time and date.
If necessary create a new user who can be used to log in and set the
time and date before logging out.
On the User ' Telephony tab, ensure that the option System Phone is
selected.
On the User ' Button Programming tab select and double-click on an available
button.
Select Emulation > Self-Administer as the action.
In the Action Data field enter 2.
Enter an appropriate label for the button.
Adding another button set to the Emulation > Time of Day action is
recommended as this will allow the user to view and confirm the systems current
time.
In the User tab, Change System Phone Rights to "Level2"
Send the updated configuration to the IP Office.
Using the Programmable Button
Press the programmed button. If the user has a Login Code enter it as
requested, and press Done
The options Date and Time are displayed.
To set the date press Date.
The current system date is displayed.
Enter the new date, using two digits for day and month. Use the * or #
keys to insert the / separators. The format for date enter matches the locale of
the IP Office system.
During entry the key labeled <<< can be used to backspace.
When the full date has been entered as required, press Next.
Press Done.
The phone will return to idle.
To set the time press Time.
The current system time is displayed.
Enter the new time using 24-hour clock format. Use the * or # keys to
insert the : separator.
When the full time has been entered as required, press Done.
Nov 05, 2012 | Avaya IP Office 5410 Terminal - New
How to change phone extentsions
You are basically setting up what extension teh phone is to use. Now you need to tell teh extension what user is going to use it.
If the phone says, no user, then there should be a login button. If there is not, contact the admin person so they can program one.
May 04, 2012 | Avaya 5610sw IP Phone
5610 sw phone displaying Adddress Conflict * to program
Reboot the phone to grab a new DHCP address. If it still does that, then something else has that IP, and the phone has a static as well, so teh phones IP will need to change.
Jul 15, 2011 | Avaya 5610 IP Phone
Can I block an incoming number on my Avaya 5610 sw?
What system is that phone hooked up to?
Yes, you should be able to, but we need the model of the phone system.
Apr 01, 2011 | Avaya 5610 IP Phone
I want to assign a name to an extension no on Avaya 5602 IP, how do i do this?
Which system is this on? IP Office, Definity or Communication Manager?
Aug 12, 2010 | Avaya 5610 IP Phone
Dial tone, can be called, hear caller, but caller cann't hear me.
The problem is likely either a conflict in compression or a speech path problem.
In Manager, is "Allow Direct Media Path" checked?
If so uncheck and reboot eh phone system, then reboot the remote phone.
Jul 13, 2010 | Avaya 5610 IP Phone
How do I program a new extension into an Avaya 5610 phone?
First we would need to know the model of the phone system. That phone will work on a few Avaya systems.
Oct 08, 2009 | Avaya 5610 IP Phone
Avaya 4602 hands. Turn on message lamp when a message is waiting.
Do you know which system this phone is on? Is it an IP Office?
If so, chek the manager program and verify that under eachs users tab, ther is a "Vxxx" in the "trusted source" tab. Where "XXX is the extension number.
Nov 11, 2008 | Avaya 4602 IP Phone
Avaya 5610 IP Phone
Oct 21, 2008 | Avaya 5610 IP Phone
Computers & Internet Logo
321 people viewed this question
Top Avaya Computers & Internet Experts
Michael Vincent Cruz
RSole
Are you an Avaya Computer and Internet Expert? Answer questions, earn points and help others
