Cambridge sound works extreme 2.1
I have the cambridge extreme 2.1 speaker system, which consist of MC105 x 2, BassCube 821. I have sent it back three times in a little over a year and now they wont fix it for less than $200. I now have the same problem that I've had all three times. The sub blows the fuse and when you put a new one in, it blows as soon as you turn the power on.
  • Audio Player... Master
  • 5,686 Answers
Fuses blow when there is an overload. This is most likely caused by the main power amp part of the sub. Or it's power supply. What's happening is that some part is acting like a piece of wire instead of doing it's job.
It's possible that the previous repair people fitted the wrong part and if you are using it at say high levels it goes again. It could also be caused by faulty speaker wiring. So check that after replacing the faulty part. It might be visibly burnt or broken if you look inside it.
Posted on Oct 05, 2017
SOURCE:
SOURCE: no sound
I had the same exact problem, here is what someone else suggested I do:
I had a problem with no audio and I recently found the fix. When thesub still worked and you turn it on you hear one relay click and thenabout 5 seconds later a second relay clicks and the audio comes on. Theproblem I had lies with that second relay. When you take the case apartthere are 4 circuit boards. The big board with the two big bluecapacitors is the main board. Well next to the two blue capacitors is ablue relay. That relay had a pin that came un-soldered from the circuitboard. I re-soldered that pin and the sub works just like new.
Posted on Oct 08, 2008
  • 3 Answers
SOURCE: AR1 Subwoofer Keeps Blowing the 5 Amp Fuse
Well, so far so good. I reinstalled the newly repaired amp and fired it up and so far, so good. Ran it through about an hour of fairly intense break-in tracks and then ran it through about 2 dozen power up and down cycles to try to get it to fail (better now than a month from now and have to fight them on backing it up).
Posted on Nov 13, 2008
  • 45 Answers
SOURCE: Fuses keep blowing
This particular product has a lot of comments posted on it and I've answered a few of them now so I'm beginning to think you may want to look into weather or not the manufacturer has received any complaints or this is just a freak occurrence. Keep in mind not all commments are the same so this may just be nothing. Either way I can tell you this much, if fuses keep blowing quickly, over and over again-You have a direct short somewhere and will most likely be in need of professional assistance of some sort with the possiblilty of having to replace it. I'm sorry it's not an easier fix but it may not be too expensive.
-Dynami
Posted on Mar 29, 2009
  • 56 Answers
SOURCE: klipsch sub 10 keeps blowing fuses
More than likely the power supply switching transistors have fried. Also check the large caps in the primary side of the power supply. If you don't know what your are doing do not attempt to fix the power supply.. very dangerous voltages involved !!! Send it to Klipsch for repair or purchase a Bash replacement panel http://www.parts-express.com/pe/showdetl.cfm?Partnumber=300-750
Posted on Apr 13, 2009
  • 7 Answers
SOURCE: Cambridge Soundworks Basscube 12S only makes pulsing buzz noise
Hey! So i fixed my problem! This is for the BassCube 10
Like i said before i saw that the circut board was burnt near the diodes ZD3 & ZD4, and the resistor R63. Thanks to Deadly1 and BillRad62, i figured it out. The R63 is a 1200 resistor, and the diodes are 15v zeners. I went with 3x 5.1v zeners to replace ZD3, unfortunately Rip-Off-Shack (Radioshack) didnt have 3 packs of these so for the ZD4 i put a 12v and 5.1v. Which exceeds 15, but seems to work without a problem. Hope it helps!
Posted on May 26, 2009
No speaker output from Basscube 8s
Yes. Check your connections that you are using from your preamp/processor or receiver to the Basscube to confirm that any adjustments I'll give you instructions for will go to the correct output. There are 2 ways that signal can be connected to the Basscube, your inquiry does not describe which you are using; either speaker level or line level. Line level is the easiest as it uses only one cable so I'll assume that is what you've used.
The following instructions I'll provide you with will presume that you are using a digitally controlled receiver or preamp/processor with an LED or LCD display and remote.
On the preamp/processor or receiver, navigate to your speaker setup menu and adjust the frequency output of any bass management system it may have to a full range signal. This may be a setting labeled for speaker size for example, choose "large." Or, if it has just a crossover setting, increase that to it's highest value.
Then go to the rear panel of your of your Basscube. Adjust the crossover to about 120Hz.
Return to your preamp/processor or receiver. Navigate to your speaker level control on the speaker setup menu. Increase this level to a matching value for each channel until you can hear your Newton speakers.
May 16, 2012 | Cambridge Soundworks BassCube 8S Speaker
Basscube 15 hums only in "Auto" mode?
There is a guy on ebay (edwards electronics) that can repair this amp for around 150.00
Feb 20, 2012 | Cambridge Soundworks BassCube 12 Speaker
Has humming sound when powers on
You may have a power problem. Check to make sure that your wires aren't touching and not crossed.If this doesn't help try plugging in you sub to different plug could be getting interference electrically in the spot it's in
Feb 06, 2011 | Cambridge Soundworks BassCube 15 Speaker
Fuse blows wean speaker is on and burning plastic smell from amp side speakers work fine
the amplifier is drowing too much current, and components are getting heat from that
check your amplifier final stage tempreature,
all so check a short of the circuit.
Apr 25, 2009 | Cambridge Soundworks BassCube 12 Speaker
Dec 13, 2008 | Cambridge Soundworks BassCube 12 Speaker
BassCube 12 Startup Problem
same here. happened after moving residences
Jun 30, 2008 | Cambridge Soundworks BassCube 12 Speaker
Repetitive buzzing noise
Some componet in the Amp circuit is breaking down. The longer you let this go, the more of a chance that you will have a major short and blow out several parts,m as thats what happens with amps. Get it service asap and dont use it.
Sep 01, 2006 | Cambridge Soundworks BassCube 12 Speaker
99 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
