Question about Canon Office Equipment & Supplies
Canon pixma mx870 pgbk 220 won't print
Pgbk 220 cartridge won't print. Page prints with all colors except black.
SOURCE: Canon PIXMA iP4000 Will not print red Deep clean won t work Other colors OK
remove print head assembly. clean off.
print head not on cartridge.
Posted on Jun 21, 2008
SOURCE: how to fix my canon pixma ip1000 printer will not print black ink
replace the printer head....
Posted on Jun 25, 2009
  • 1584 Answers
SOURCE: Canon ip4300; new printhead and PGBK ink cart but it won't print
Perform Print head clean should do the trick. May have to repeat.
Posted on Dec 03, 2009
  • 164 Answers
SOURCE: Coloured printer with black not printing?
Breath and Relax... this should resolve your problem.
Routine maintenance and keeping full ink tanks will prevent this problem, however if you have the problem you can resolve it by doing the following:
1. Clean your ip3000 print head using denatured alcohol solvent which can be purchased from most hardware stores. If unavailable, use 91% Alcohol (isopropyl alcohol (first aid antiseptic) which is available for less than a dollar at most Walmart pharmacy departments.
*Warning: You may want to use a pair of latex exam gloves as this is a messy process and can stain your fingers.
Supplies needed:
Isopropyl Alcohol or denatured alcohol
paper towels
latex gloves
sink, bowls and or basin
can of compressed air
very small screw driver
tablespoon or baby bulb type syringe
warm water
Time necessary 45-50 minutes
1. Lift print head from printer. It pulls out easily because it is held in with the same down lever that holds the cartridge in place.
2. Put two layers of paper towels in the bottom of a dish to protect sensitive sprayer heads.
3.Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
4. Take the two small screws out that hold the white ceramic piece
5. Gently, pry the ceramic piece back and away , to reveal the underside (No need to pull away the glued points on the sides.)
6. Gently, move head up and down to slosh solvent around it the best as you can. Use a table spoon or syringe to pour solvent over all orifices in the print head, turning it upside down and then back a few times.
7. Use canned air with a plastic straw to blow into and through all orifices, alternately sloshing/swishing and pouring solvent over head (be careful not to touch any of the holes, screens, or sprayer heads with anything)
8. Empty dirty solvent from bowl and replace with paper towels and clean solvent. Soak for approx 10 minutes. Rinse again with clean solvent poured directly on all parts, letting solvent overrun and fall into dish or basin.
9. Gently shake the solvent off the head, take it outside and spray with compressed air into all orifices to clear out and help evaporate any remaining solvent. Let sit on a clean paper towel for approx 20 minutes. (There may be a little ink bleeding out of the head, but once it dries completely it does not present any problems.
10. Reinstall head, cartridges and it will print like a new printer.
SUGGESTION: For many years of problem free printing, keep a double set of ink cartridges, one set full at all times. Whenever a cartridge runs out of ink, replace it IMMEDIATELY, with a new one or a refilled one. This gives the print head no chance to dry out and create clogged heads. Routine maintenance of cleaning the heads every 24 months does wonders for keeping your ip3000 in new condition.
Happy Printing .
Posted on Feb 07, 2010
pineworks
  • 4041 Answers
SOURCE: Printer willl print color but does not print black and white
Hi There You can try/
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Apr 28, 2010
Canon PIXMA iP4200 not printing PGBK properly - only printing top 50% of PGBK grid on test page.
Man you did some awesome troubleshooting! I don't know, but it sounds like something is physically wrong with internal electronics. I'd call in the big dogs at Canon themselves.
https://www.usa.canon.com/internet/portal/us/home/contactus
Nov 17, 2016 | Canon PIXMA iP4200 InkJet Photo Printer
Canon MX870 print alignment. Only occurs
Reinstall the printer driver. Sounds like it is corrupted.
May 09, 2017 | Canon PIXMA MX870 Wireless Office...
Canon mx860 printer not using ink from PGBK 220
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Mar 07, 2013 | Canon PIXMA MX860 All-In-One InkJet...
Won't print because color is out, I have setting on black only shouldn't that work?
i think all printers do not print if one of the separate color cartridges is empty. check ink and replace. hope this will help.
Apr 02, 2012 | Canon PIXMA MX310 All-In-One Printer
How do I print a color page in black in white so i won't use up the color/
Open 'Printers and Faxes'.
Right-click your printer and select properties.
Click 'Printing Preferences' button (Close to the bottom of the dialogue).
Click 'Paper/Quality' tab from top.
Select 'Black & White'.
Click 'OK'.
If you want to use B&W cartridge for all documents, Click 'Printing Defaults' button from advanced tab and change the same setting.
Sep 04, 2011 | Canon PIXMA MX310 All-In-One Printer
I have a Canon Printer PIXMA MX870. My black ink (PGBK) has run out. Will the single black (BK) kick in? I've looked for the user manual which might describe this but couldn't find it.
The black ink (smaller cartridge) will not kick in, but if you are just getting the warning that the ink in the larger cartridge is out, you can override the alam by holding down the OK button on the printer. Once you do this, the printer will continue to print, but you have to manually monitor the ink to assess when the cartridge needs to be replaced.
Let me know if you have any other questions. Thanks.
Apr 26, 2011 | Canon PIXMA MX870 Wireless Office...
Mp960 color prints ok but black and white not printing
When was the last time you printed in color? New ink printers are built so with a "use it or lose it" theme. The print heads are now built into the machines and are not generally replaceable. Yours luckily is, but I don't know how easily. The link below is to the replacement which costs $130 + shipping. Sometimes it can be just as worth it to buy a new machine, in this case I would probably prefer to repair the damaged machine as the new printer cartridges cost more and have less ink.
Feb 16, 2010 | Canon PIXMA MP960 Printer
Black ink
The PGBK cartridge is a pigment black ink, while the others use a dye for coloration. The pigment black is used when printing text and other documents. The dye ink is used when printing photos and other colored documents. The dye black is used in conjunction with the color (dye) inks to provide tinting and color gradation, and therefore is not used nearly as much as the pigment black unless you use your printer only for printing photos.
If you're printing text and documents, you will need to buy another pigment black (PGBK) cartridge.
Oct 13, 2008 | Canon MP610 Photo All-In-One Printer
Canon MP500 PGPK cartridge wont print
i have the same problem too. This is obviously a product defect. If Canon not fix it, i wont buy Canon printer anymore.
May 21, 2008 | Canon Pixma MP500 All-In-One InkJet...
98 people viewed this question
old marine
old marine
