Question about Sony Televison & Video
Sony sxrd HDCP error
KDS-r60xbr1 HDMI will not play my DVD, Roku and appletv. Roku and DVD now playing thru component input. Apple TV displays "HDCP compatibility required..." I have unplugged everything with no results. Questions 1. Can I bypass HDMI HDCP error by using an HDMI adapter to DVI or VGA? 2. Do either VGA or DVI share HDPC circuitry with the HDMI ports? 3. Will the Sony TV work with the HDMI p-board removed?
  • Jack Shaffer Jan 05, 2013
    Went to JustAsk and got solution. The PD-board that houses the HDMI ports has failed and needs replacement or repairing to "handshake" with devices requiring HDPC. VGA not sharing HDPC circuit. SHOULD work without PD-board.
3 Suggested Answers
SOURCE: KDS R60XBR1 Red Light blinks 3 times when turning
on my xbr tv there is a little *** that sticks out on the lamp cover. the wrapped and it wont work light flashed 3 time with a new cover it worked fine. there was a t. s. b. for an over heat problem new fan and sensor and door. go to sony.com its there
Posted on Mar 31, 2009
falsafat
  • 31 Answers
SOURCE: Connect Sony Vaio Laptop to DVI on Sony LCD Projection TV
try to lower the resolution of the display, to know how please visit the following link:
https://www.microsoft.com/windowsxp/using/accessibility/screenresolution.mspx
< Please Rate :) >
Posted on Apr 12, 2009
I have a 2009 Lg 37lh30 Tv and for the most part it works until recently. I am now getting a HDCP rejection when using an Apple tv or Roku and no screen when using my bluRay Player (which use to work
Some TV's & cables are not HDCP compliant . Sometimes you can replace the cable to fix the problem & other times you have to replace the tv because its not HDCP compliant . First check to see if your tv is HDCP compliant .
Jan 03, 2015 | LG 37LH30 37 in. LCD HDTV
How do I get HDMI cables to sync or talk to each other. We had this problem when we hooked up an Apple TV box to a Denon AVR-E400 and our Sony HD TV. We were told to disconnect all HDMI cables unplug
Personally I would use an RCA cable and hook up the AVR.
((RCA out of TV to AVR audio in))
((cable box HDMI cable output to TV HDMI Input1))
(As far as the AppleTv I would use a separate HDMI Input2)
If your AVR has a dvd or blue ray player Hook up a
HDMI cable out to another Input HDMI3 of the TV
using separate inputs on the tv will allow your surround system to be
used on all modes(CABLE,DVD/BLUERAY,APPLETV)
Sep 27, 2014 | Denon AVR-E400
Sorry for the duplicate post, but somehow someone's not helpful solution got marked as solved, so I'm going to post again. I have a Sony Wega KP-51WS520. The problem is with the HDMI port. I have...
HDCP is causing the trouble You experience. Try using other video input connection for same set. If it works fine that way, the problem is that the rights protection (HDCP) is acting as "police" to prevent copying or reproduce unauthorized content. If only the HDMI is connected (disconnect all other inputs/outputs) on some sets, could be work fine.
Oct 10, 2013 | Sony KP-51WS520 51" Rear Projection...
Will not play movie - continually displays "Copyrighted Movie HDMI HDCP frail with TV "
There are several reasons for this but exactly knowing which is one isn't possible without first knowing what products you are using such as your connector, player and television.
HDCP is the acronym for high definition content protection. It is a digital signature embedded into the disc software designed to prevent copying of the disc. On certain occasions due to the hardware such as the HDMI port on the television, or the connection type, the signal will not be allowed to pass through. The HDMI port on the television may not be HDCP compliant for example. In this case if possible you can try a different HDMI input on the TV if available or use the component video input instead.
Jan 09, 2010 | LG DR787T DVD Recorder
H1005 error
I played with going to another HDMI outlet and then back to the original and it seems to quickly reset itself and the message dissappeared!
May 23, 2009 | Panasonic VIERA TH-C50FD18 50 in. Plasma...
"Display connected non-HDCP compliant" error
The HDMI cable was causing "Display connected non-HDCP compliant" error message to appear.
When I reconnected my DVD to TV using regular cable with 3 color connectors(i don't know what is the proper name for that cable) that error message no longer appears on my screen and I was able to watch my movie normally.
May 17, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
HDMI inputs stopped working
I had the same problem with the HDMI connected to my HD cable box DVR. We called the cable company and he changed the box and the problem remained. He said there was something wrong with my TV.  The component (5-wire) jacks on input 5 work fine.  A few months later i got the 'green tint" problem and the tech came out to replace the whole optical box.  I asked about the HDMI problem and he said that the Sony protocol for HDMI is the problem. It will "talk" to some hardware and not others. He has not found a fix, except to use the other A/V inputs and abandon the HDMI (#7) input.
Mar 22, 2008 | Sony KDS-R60XBR1 60" Projection HDTV
Televison & Video Logo
73 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
