Question about Air Tools & Compressors
Air compressor not filling tank
I have a 60 gal craftsman air compressor that will only build 92 psi. Just runs and runs, never buillding enough pressure to trigger switch. Pulled apart pump, everything looked good. Rings and cylinder walls were perfect, so i replaced gaskets and reasembled. No leaks anywere else, not sure where to go next. Very little use and only 3 years old. Help?
  • skajaquada Jan 19, 2009
    Did replace all valves, still same. Will check for leaks again, don't think that is it. Ready to just replace punp out of frustraition. Had pump apart several times, each time replacing gaskets. Could it be rings even though they look good? Thanks for the info.
  • skajaquada Jan 21, 2009
    Did suction test on intake, no suction at all! In fact the reverse is happening. Next step? Tear down and replace vavles again? Thanks for the help.
    President:
  • 1,388 Answers
Most compressors with the problem that you are having suffer from leaking valves. As in a gasoline engine, leaking valves will lower efficiency. Valves in a compressor are in the form of reeds that seal against valve plate. Leaking reed valves or gaskets will increase the discharge air temperture. Inspect these parts with a magnifying lense. Look for evidense of wear or leaks. Also look for signs of air leaking from one cylinder to the other thru gaskets. Replace valve plate as necessary. Simple test, as your compressor is filling, check the intake for strong suction; as it neers the 92 psi mark suction will probably deminish if you have leaking valves. If suction remains strong at 92psi then you have a leak at the discharge side. Check with soapy water on all parts. Good luck
Posted on Jan 19, 2009
  • John Trevino Jan 20, 2009
    Not likely rings because all that air would be dumped into crankcase pushing out the oil from vent at dipstick. We very rarely see problems with rings/cylinder on oil bath type compressors. Oil free compressors are however known to leak past vinyl ring and cylinder at the pressure you mentioned. We pressure test reed valves/plate on special jig to 120psi. You can test discharge reeds by removing discharge tube from pump and connect air pressure hose to discharge port. Reeds should not leak into cylinders. (tank pressure should not leak past tank check valve when you remove discharge tube from head of compressor) Also you did not mention the results of blocking the intake with finger to check for suction. (try this when the unit is at 90psi). If you do not feel much suction suspect valves or air leaking thru gasket into adjacent cylinder.
I have a 3 gal craftsman air compressor. Compressor runs but will not build more than 20 psi in tank reserve. Whats wrong?
if shuts down at 20 psi regulator is set wrong
it runs but only builds 20 psi, compressor is probably worn out
Oct 03, 2015 | Craftsman Air Tools & Compressors
Charge air pro model ir330e20 builds pressure to only 60 psi and will not stop running
Cbillgreene:
Your compressor is leaking air somewhere between the compressor head and the tank. With the compressor running, feel carefully around the ends of the tube that leads from the compressor head to the air tank. You will probably feel some air leaking around one end or the other. If so... remove the tube and find out which packing has failed.
Mar 09, 2013 | Craftsman Air Tools & Compressors
My compressor will not go over 20 psi i have a craftsman 921 4 gal 125 psi compressor and it will not build past 20 psi i do not know how to get to the pistons and stuff what do i do?
The problem with compressors not building pressure is usually a bad pressure switch or bad regulator. Does the motor shut off at 20psi or does it continue running and not build pressure? If the motor continues to run with no increase in pressure, the you should go over the machine looking for air leaks from your regulator back all the way to the motor. Any air leak while the compressor is running can cause the pressure to "peak" way before the intended shutoff that it is regulated to.
Mar 01, 2011 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
1 hp 3gal craftsman compressor will only build up to 20lbs pressure in tank. how much compression should single cyl have on compression stroke?
A piston in any engine should be around 100 psi I would guess. A Chevy 350 used to be around 150 psi. An air compressor that only pumps enough air to reach 20psi is obviously too low on compression. Nailers and the like need 80 or more psi. The intake valves may be shot, the unloader might be stuck or piston rings are worn.
Dec 08, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Will not build up pressure
worn out pump on the compressor, or leak in tank.
Jul 05, 2010 | Craftsman 1 Hp, 4 Gal. Air Compressor
Pressure in the tank only builds to 30 psi
Bad check valve. But I would check the regulator, by turning it down to about 10 PSI and running it and see if it builds again, if that works then it is the check valve. But from what you are saying I would replace the check valve anyways.
Jun 05, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
My craftsman air compressor model 919 16737 1.1 hp 17 gal 150 psi won't build up any air pressure. It runs but sounds a little odd.
Probably the check valve has failed. It apparently is where the pipe goes into the tank from the compressor.
Aug 24, 2009 | Craftsman Air Tools & Compressors
Craftsman 5 hp 30 Gal Won't build to more than 50/60 PSi
Most oilless compressors suffer from a short lifespan of the cylinder and piston ring. Unplug the unit and remove the cover to expose the cylinder and rod. Move piston to topmost position and examine the condition of the cylinder. If you see scratches or worn areas close to the top of the cyl. then most likely will need rebuild kit. (Not expensive) If cylinder looks good, remove the head and check the reed valves for debris or broken reed. Reed valve plate is also available as part with gaskets. To extend the life of an oilless compressor try not to use it in dusty or sandy areas as the bottom of the unit is open and tends to **** dirt into cylinder. Good Luck.
Dec 31, 2008 | Craftsman Air Tools & Compressors
Lack of pressure
My air compressor builds up to 40 psi and just keeps running, i have a craftsman 5 GAL, 1HP, 125 PSI and pressure goes up to 40 psi and dose not go any higher and on the other hand engine keeps running and dose not stop. Please advise?
Thanks.
Kia
Oct 25, 2008 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Air Tools & Compressors Logo
512 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
