Question about Pioneer Xv-dv55 5.1 Home Cinema System
When a disk is inserted, it starts to run, than stops end the draw opens
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Pioneer Master
  • 924 Answers
Most likely, you have a bad optical picker(laser). For more information, or should you have more questions, please visit my website at audioserviceclinic.com. You may contact me through the website. Thank you.
Posted on Dec 22, 2013
How do I open the disk drive draw?
  1. Press the button in the centre of it.
  2. Insert a straightened paperclip into the hole and press.
  3. Open a program and press eject.
  4. Gently prize it open with a butter knife.
Jan 21, 2016 | Computers & Internet
Program to stop running on my PC screen
Try opening the task manager and ending the program from there: press control and alt together and then press delete. Choose to open the task manager. On the applications tab, highlight the program you want to stop and click end task. If you get a window saying the program is not responding, click; end now. After this go to the start menu and type msconfig into the search field and return. Open the tab that says startup programs, find the HP program and uncheck the box. Restart the machine. You can then go to the control panel, choose remove a program, highlight the HP program and click uninstall.
Mar 28, 2012 | Computers & Internet
Inserted disk into draw on my dell computer and noe it is jammed
There's a very small hole on the front of the cd\dvd drive you need a long stiff piece of wire or a pin and push it quite hard into the hole, which should push the draw open.
May 28, 2011 | Computers & Internet
Phillips dvd player disc draw won"t open help
Usually, there's a pin hole beneath the tray that come out. If there is a pin hole, get a paper clip or safety pin and insert the pin or clip into the pin hole and push. That should pop the disk tray out.
Mar 21, 2011 | Philips Electronics - Others
Disk is clean and all, but when I turn it on, its starts fine until the little box finish making the Game Cube Icon and then start turning and goes straight to my memory card. I can hear the cd running but...
Your Gamecube's laser may be dirty. Try this:
Grab a cotton swab (A Q-Tip), and some rubbing alcohol. Lightly wet one end of the cotton swab with the rubbing alcohol and open up your Gamecube's disk tray. LIGHTYLY rub the wet end of the cotton swab on the disks laser in a circular motion. The laser is the shiny part pointed to by red arrows in this picture: http://i.imgur.com/MAXRQ.png
Now leave it for a minute or two to dry and attempt to play a game again. If this doesn't work your problem may be an underlying hardware error that can't be solved without opening up and gutting your gamecube. Let's hope for the best though!
-Risonhighmer
Feb 27, 2011 | Nintendo GameCube Console
Please guide the steps to install the norton antivirus 360 latest version one user
The easiest way, open your CD drive and with that open shut down your computer. Insert the Disk in the drive and close it then restart the computer. The installation program should start auto automatically as windows starts. The reason I said to shut down then reboot with the disk in the drive is to allow the program to scan your system before windows starts to speed up the install process. If you insert the Disk and close the drive while the computer is on it will auto start and scan the system anyway but it takes longer. Make sure you stop and uninstall any other anti virus programs or Anti Adware programs, such as Spy Bot, you may have running, the Adware programs only need to be closed.
Jul 22, 2010 | Symantec Norton 360 Version 3.0 Full...
My drive on my advent roma is not recognising any discs
You can try cleaning it with a cleaning disk but otherwise it does sound like the drive is going bad.
May 05, 2010 | Computers & Internet
12xb battery drains and has been replaced more than once always on tender, Harley thought ground wire on painted frame cleaned it same issue one week later
It could be a shorted voltage regulator. Sometimes they will short and draw current even when the bike is not running. I would measure the current drain with an amp meter by removing a battery cable and inserting amp meter between the cable end and the battery. Then pull one fuse at a time to locate the current draw. If pulling fuses doesn't find it then while still testing with the amp meter disconnect the voltage regulator and see if current draw stops.
Hope this helps you.
Bob
Nov 04, 2009 | 2004 Buell Lightning XB12S
1993 Land Rover stops running on when on rough roads,
I had the same problem with my 1993 range rover. It turned out to be the ignition switch. after thousands of times inserting the key, over the years this process slowly pushes the back side of the switch away from the ignition switch housing. This consists of a plastic disk which holds the mechanical stop that keeps the ignition in the run position. If the disk is not secure and tight against the ignition housing the hold mechanism will not work properly. Mine would start and run however the first time i hit a bump the ignition switch would turn its self to the acc. position and the vehicle would stop running. I found the solution on okierover.com He was very clever in his way of a permanent repair. He opened up the steering column and used tie wraps to hold the plastic disk secure against the end of the ignition switch. Thus no more automatic ignition turn offs.
Jan 23, 2009 | 1993 Land Rover Range Rover County
Dvd wont eject
hi jodestar,
i am having the same problem with my player. how did you end up fixing yours?
Sep 23, 2007 | Philips DVDR3455H/37B
Pioneer Xv-dv55 5.1 Home Cinema System Logo
77 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
