Question about Samsung Induction Range FTQ307
Samsung Induction error code 84 - Samsung Induction Range FTQ307
Error 27 how to fix this where is a problem
This is telling you have a problem with your oven temperature sensor. You'll need to test it with an ohm meter. You should read 1100 ohms across the two wires from the sensor.
Oct 26, 2015 | Samsung Induction Range FTQ307
Induction cooktop won't turn on
Could be the safety switch of, because the logic detects an error (or defect) in the induction system.
Mar 31, 2015 | Belling Ovens
Induction fault e6
E6 - Defect Induction module or over temperature of coil sensor with Falcon User interface with production date before 2010
- Disconnect the appliance from the mains for 30 sec. If alarm still occurs after 1 min operation exchange induction module.
Over temperature of coil sensor with Falcon User interface with production date before 2010
- temperature sensor defect or wrong mounted.
  1. Check connector at induction module.
  2. Check the coil sensor, it should be placed even in the silicon carrier.
  3. Appliances with 3 zones, is the "Dummy" temperature sensor at the 2nd terminal mounted?
  4. Exchange coil with sensor.
  5. If above is without success, exchange induction module.
Dado
Jun 03, 2014 | AEG Ovens
Samsung induction burnerdoes not recognize pan
You are correct I am not impressed with Samsung , I like Induction but their units are too finnicky - I have two 5 inch burners one accepts the pan the other does not same pan , so it is not the pans. I think I would like to go to a store where they have induction ranges and compare with induction ready pans (ready is not necessarily induction capable) before i would buy another. This oven has convinced me to disregard the cool features Samsung has (because it comes with others that it should - like cook all burners on HI at the same time) and so for my other appliances I will look at other brands that you know just work.
Jun 01, 2014 | Samsung Induction Range FTQ307
SAMSUNG INDUCTION STOVE ERROR CODE E84
Unplug the oven wait 10 minutes plug back in . Cooktop AND Oven working ? Yes - you have a communication problem - display board or main PCB.
Is the oven not working and the cooktop still works ? If yes it is a power problem on L1 or L2 , to verify if the issue is in the oven or the home swap L1 and L2 on the power cord. (if you do not know what you are doing then you should not touch them). If the Error remains yet the cooktop stops working or the cooktop stops and the oven starts working etc. Replace the Circuit breaker in your house panel - it works but not correctly. No Difference check the L1 line and the transformer connector on the oven board - resolder the connectors for the transformer.
Dec 23, 2012 | Samsung Induction Range FTQ307
Stove went completly dead during self cean no power door remains locked
Check the breaker for your kitchen even if it isn't flipped, flip it off and on again.. I had the same problem it turned out that my dryer and stove were on the same breaker, so I couldn't run them both at the same time.
Aug 03, 2012 | Samsung Induction Range FTQ307
De dietrich induction hob fault code d5 6f 20 a3
I have a De Dietrich DTI749X induction cooktop and i have the FO error code flashing on two of the hobs.
How do I fix this?
Sep 01, 2011 | De Dietrich Ovens
Can I put this range into the standard amperage that already exists?
I do not know what the breaker/fuse you have but a 50 amp breaker is what is required for it
Aug 24, 2011 | Samsung Induction Range FTQ307
Samsung Induction Range FTQ307 Logo
298 people viewed this question
Top Samsung Ovens Experts
ray gallant
Dave Lammas
Level 1 Expert
JonSnell Electronic
JonSnell Electronic
Are you a Samsung Oven Expert? Answer questions, earn points and help others
