Question about Nikon Coolpix L11 Digital Camera
How do I increase the speed of my mouse. The speed bar is already at max position.?
  • 1 more comment
  • rajelect Feb 18, 2009
    what do you mean "the speed of the cursor in the camera". where is the cursor in the camera
  • Rob
    Rob May 11, 2010
    The cursor is what you see when you switch between menus in the camera.
  • Rob
    Rob May 11, 2010
    Do you mean the speed of the cursor in the camera? Or the mouse on a computer?
  • 423 Answers
If the speed bar is already in max position, then that's as fast as it will go.
Posted on Feb 19, 2009
Cursor jumps and repsitions script higher up in script
1. Please disable the tapping option if it enabled in the computer.
2. Click on the "Start" button.
3. Click on "Control Panel."
4. Click on "Mouse."
5.Click on "Pointer Options."
6. Move the "Select a Pointer Speed" slider bar left to reduce the pointer speed and right to increase it. Once you have set the pointer speed, click "OK" to save the settings.
Wish you all the best
Jan 21, 2011 | Microsoft Windows XP Home Edition
I have to click twice or three times to get any action to happen on my ThoinkPad T43p
Hi, it seems that the Mouse click speed is slow, try increasing the Speed. It might help you. To increase the Mouse speed follow the steps.
Press and hold Windows Logo+ R key, this will launch the Run command prompt.
Then type "Control" in the Run Command prompt, to open Control Panel.
Now select the Mouse Option in the Control Panel.
Check the double click speed, move the slider to fast and check. Please get back if the issue still persist.
Dec 08, 2010 | IBM ThinkPad T43p Notebook
Mouse sensitivity is slow.i want more then more speed of mouse pointer,i already search but nothing...pleas SIR
These are the steps to change the mouse sensitivity
Click on the "Start" button in the lower left corner of your computer screen to open the Start menu so you can change the mouse sensitivity. Locate the control panel link on the right-hand column of the Start menu and click on the link.
Wait for the Control Panel manu to open and then locate the "Search Control Panel" bar at the top of the menu on the the right-hand side. Type in "mouse" (no quote marks) in the window and locate the mouse menu at the top, left side of the menu.
Locate the link that says "Change Button Settings" at the bottom of the mouse menu and click on the link. When the mouse properties window appears, locate the tabs at the top of the window and find the one that says "Pointer Options."
Click on the "Pointer Options" window tab and locate the heading that says "Motion." In the Motion section, find the slide ajustment bar that is labeled "Slow" on the left side and "Fast" on the right side of the bar.
Move the bar according to your desired speed and preferences, and click on the "Apply" button on the lower right-hand side of the window.
Click the "OK" button on the lower left-hand side of the window, which will take you back to the default window. Verify that the mouse sensitivity is according to your needs and readjust if necessary by repeating these steps.
Good luck
do rate the solution if got help
Dec 07, 2010 | HP P2360AA Keyboard/Mouse
I have a Dell studio laptop. Recently, within the
1. In order to fix this, you go to control panel > mouse
the last tab is called "Device Settings" click it and make sure you have "static tray icon in taskbar" selected.
(You can always remove this later.) Apply the changes and click the red coloured icon in your task bar. An option will be available called "Tap to click." Clicking it will enable you to tap with your mouse pad instead of the keys! Hope this helps you out, I know it helped my friend.
2.
In the Control Panel open Accessibility Options Icon and click Mouse Tab and than Setting.
To move the mouse pointer by using MouseKeys
If you have not already done so, turn on MouseKeys.
To turn on MouseKeys, open Accessibility Options, click the Mouse tab, and then select the Use MouseKeys check box. Use the buttons on the numeric keypad to move the mouse pointer. If MouseKeys doesn't function, press NUM LOCK, and then try MouseKeys again.
To move the pointer horizontally or vertically, press the arrow keys on your numeric keypad.
To move the pointer diagonally, press HOME, END, PAGE UP, or PAGE DOWN on your numeric keypad.
Notes To open Accessibility Options, click Start, click Control Panel, and then double-click Accessibility Options.
To specify whether NUM LOCK must be on or off for MouseKeys to function, on the Mouse tab, click Settings, and then for Use MouseKeys when NumLock is, click On or Off.
To change the pointer speed and acceleration when using MouseKeys, on the Mouse tab, click Settings, and then move the sliders to adjust the pointer speed and acceleration.
To temporarily increase or decrease the pointer speed, on the Mouse tab, click Settings, and then select the Hold down Ctrl to speed up and Shift to slow down check box.
Jul 27, 2010 | Dell Studio 1737 Laptop
Maximize my laptops memory and speed
See if you can "Upgrade" the processor would be one way... Maybe upgrade to a 64 bit OS. The rest you have already done. a large, fast/big cache, high speed Hard Drive.
Mar 05, 2010 | HP Pavilion tx1000z Notebook
My KitchenAid KSM90 will not turn off. All the speed settings seem to work, it just won't shut off. I have it open, but don't understand how the switch operates such that it turns the mixer off. The...
I determined that the switch that controls whether the mixer is on or off is controlled by a copper bar with a contact. The contact got fused to the copper bar, possibly due to a short. Since the contact got fused to the copper bar, the circuit was always connected, so the mixer was always on. The solution was to 1) unplug the mixer, and 2) take a screw driver and gently pry the contact away from the copper bar. When the mixer is in the off position, the copper bar and contact are no longer in contact. When the mixer is on, the copper bar and contact make contact. My mixer now works just fine. Yea!
Jan 28, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
Bladestorm PS3 Game - Fame level stops increasing at FameStar 1
you need to do a big story battle after reaching max full bar.
mind you, im looking right now if there are any bugs to this on xbox 360, since iv done about 3 quest battles (least i think they are the main story, the one where france asks you to attack the cities and one guy calls the woman a wench xD) and mine has yet to increase...
im stuck on 2 stars max fame... =(
all i know is that you have to do a story / quest mission... then it ***"SHOULD"*** go up a star....
Apr 13, 2009 | KOEI Corporation Bladestorm: The Hundred...
Speedup firefox
Yes, firefox is already pretty damn fast but did you know that you can tweak it and improve the speed even more?
That's the beauty of this program being open source. Here's what you do: In the URL bar, type “about:config” and press enter. This will bring up the configuration “menu” where you can change the parameters of Firefox.
Note that these are what I’ve found to REALLY speed up my Firefox significantly - and these settings seem to be common among everybody else as well. But these settings are optimized for broadband connections - I mean with as much concurrent requests we’re going to open up with pipelining… lol… you’d better have a big connection.
Double Click on the following settins and put in the numbers below - for the true / false booleans - they’ll change when you double click.
Code: browser.tabs.showSingleWindowModePrefs – true network.http.max-connections – 48 network.http.max-connections-per-server – 16 network.http.max-persistent-connections-per-proxy – 8 network.http.max-persistent-connections-per-server – 4 network.http.pipelining – true network.http.pipelining.maxrequests – 100 network.http.proxy.pipelining – true network.http.request.timeout – 300
One more thing… Right-click somewhere on that screen and add a NEW -> Integer. Name it “nglayout.initialpaint.delay” and set its value to “0”. This value is the amount of time the browser waits before it acts on information it receives. Since you’re broadband - it shouldn’t have to wait.
Now you should notice you’re loading pages MUCH faster now!
Oct 19, 2008 | Computers & Internet
Laptop mouse
Go to Start --> Control Panel --> Mouse.
Click on the Pointer Options tab and adjust the slider for the pointer speed.
Regards,
Javabytes
Nov 16, 2007 | HP Compaq Presario V2000 Notebook
Nikon Coolpix L11 Digital Camera Logo
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
