Question about Asrock P4i65G Motherboard
Jumper setting vor motherboard setting in computer
Setting in dis computer motherboard replacing
  • 5,660 Answers
AsRock Support > P4i65G > Main Support page,
http://www.asrock.com/mb/Intel/P4i65G/
In the top left column under the green AsRock name, click on - Manual in the list.
To the right of - User Manual - click on the country NAME nearest yours.
When the PDF file comes up........
Hover your mouse cursor at the bottom. The ghosted out navigation guide will appear.
Go to the far right, and click on the Adobe PDF icon.
(When you hover your mouse cursor over it, "Show Adobe Reader toolbar" will briefly appear)
Click on the Zoom Out icon ( - ) at the top, to Decrease the view size.
Use the Zoom In icon ( + ) to Increase the view size.
The Adobe Reader page number box, is to the right of the Down Arrow, at top.
Page 9 shows a Motherboard Layout, and the jumper locations.
Page 15 has the details about the jumper settings.
Motherboard installed in computer case;
A) At the Top/Left corner is PS2/USB/PWR1 jumper
There are 3 pins.
Starting on the LEFT side going towards the Right;
Pins 1, 2, and 3.
Jumper cap on Pins 2 and 3 for +5VSB
+5 Volt StandBy power.
It is for PS/2 or USB Wake-Up events.
Suggest leave on Pins 1 and 2.
B) To the Top/Left corner of the top white PCI slot, is the JR1JL1 jumper.
4 pins going across.
From the LEFT side going towards the Right;
Pin 1 and Pin 2 for JR1.
The next two pins are Pin 1 and Pin 2 for JL1.
If there is a jumper cap on those pins, your Front Panel audio ports, and Rear panel audio ports will not work.
(JL1 = Front Panel JR1 = Rear panel. The rear panel is also the I/O area. Input/Output. Where the mouse, keyboard, monitor, etc hook up)
C) Right below the round CMOS battery on the right side, is the
CLRCMOS0 jumper.
Clear CMOS jumper
NO jumper cap on those 2 pins to operate the motherboard.
"CLRCMOS0 allows you to clear the data in CMOS. The data in CMOS includes system setup information such as system password, date, time, and system setup parameters.
To clear and reset the system parameters to default setup, please turn off the computer and unplug the power cord from power supply.
After waiting for 15 seconds, use a jumper cap to short two pins on CLRCMOS0 for 5 seconds."
Regards,
joecoolvette
Posted on Jan 03, 2013
Lost Password
if using pc. look for jumper on motherboard. It will say clr password. reremove jumper start computer up. should take you to windows. Shut computer down replace jumper. Restart computer it should leave you with factory settings for password. DEll has no password for factory settings. More than likely other computers don't either'Reset a new password
Mar 13, 2013 | Computers & Internet
Do you have to set the motherboard jumper settings? or are they preset
Jumper settings can usually be left alone. All jumper settings can be found in the motherboard manual found here:
Super Micro Computer Inc Products Motherboards Xeon Boards X8DA6
Oct 13, 2010 | SuperMicro X8DA6 DP LGA1366 MAX96GB EATX...
Reset bios password
please give me lenovo sl400 bios reset password thanks
Oct 12, 2010 | Matsonic MS9158EP (DSMTSMS9158EP)...
Reset power on password jumper
Motherboard Jumpers:
Some, but not all, motherboard manufacturers provide a set of three jumpers on their motherboards that provide you with the ability to clear the Bios/CMOS settings, thereby allowing them to be reset. For the most part this is used when the Bios/CMOS data becomes scrambled and you need to clear the Bios/CMOS in order to return the computer to a functional state. This same procedure, however, can be used to clear passwords from the Bios/CMOS setup. Typically a jumper will be found across pins #1 and #2 as the default position, and by shutting the computer down, unplugging the power cord and then moving the jumper so that it is across pins #2 and #3 will clear the Bios/CMOS settings.
Here's an example of a Supermicro PIIISEA motherboard.
piiisea_jump.jpgAs you can see from the picture, we have added two small red arrows. The arrow to the left denotes the location of the "Clear CMOS" jumpers, while the red arrow to the right denotes the location of the CMOS battery.
Here are the procedures if the jumpers are present on the motherboard:
  • Locate, if possible, the instruction booklet for your motherboard. If you cannot locate the booklet, then user the motherboard references on this site to locate the manufacturer and see if a manual is available there. You may also want to closely examine the motherboard itself.
  • Shut down your computer and disconnect the power plug.
  • Now identify where the jumpers are located, then check the present pin location and the location of the jumper on those pins to determine their default location. As an example, the default location on the above motherboard is to have the jumper across pins #1 and #2. Write it down!
  • Next, move the jumpers from the their default location (Example: from across pins #1 and #2 as above) and then place the jumper across pins #2 and #3.
  • Leave the jumper in place for 20 to 30 seconds and then return it to its default location.
  • Now plug the power cord back in and restart the computer.
  • When the computer begins it's startup (boot) process, tap the DEL, F10 or F1 key, (whichever is appropriate for your computer) to get into the Bios/CMOS setup. If you need more detailed information as to how to get to the Bios/CMOS setup, follow this link. Bios Basics
  • Once into the Bios/CMOS setup, look for a section or area to set the Bios/CMOS to its default settings. This will return the motherboard to either its basic or optimum settings depending upon the motherboard manufacturers settings. You will then need to verify certain settings, such a CPU and memory as well as hard drive type and size recognition. If you need more information regarding these settings, follow either of these links: For an AMI Bios or for an Award Bios.
  • After making any final adjustments, save your settings and restart the computer. The Bios password should be gone and the Bios set to its optimum settings.
If the "Clear CMOS" jumpers are not present or not available:
The procedures for clearing a Bios/CMOS without jumpers is essentially the same as those given above when they are present, it just takes a little more effort.
  • Shut down the computer and disconnect the power plug.
  • Locate, if possible, the instruction booklet for your motherboard. If you cannot locate the booklet, then use the motherboard references on this site to locate the manufacturer and see if a manual is available there. You may also want to closely examine the motherboard itself.
  • Now identify where the battery is located on the motherboard. It will be approximately 1/2 inch in diameter.
  • Normally these batteries are held into place with one or more small clips over the face of the battery. Carefully lift the battery out of its socket and set it aside. Note: Some batteries are actually soldered to the motherboard, so take that into consideration and be careful.
  • Leave the battery our of the computer for about 20 to 30 minutes and then return it to its socket.
May 28, 2010 | HP Compaq dc5100 Small Form Factor PC...
Power
Hello
If you're replacing a motherboard then the new motherboard has a jumper across the on/off jumpers. If this is used board then check to make sure the on/off jumper pins are not shorted. If OK boot up and go into BIOS. Make sure that any line stating Automatic Turn ON is off.
Sep 24, 2009 | Intel PGA478 Motherboard
Reset Cmos Settings for Acer Computers
There might be a jumper on your motherboard that's labelled CMOS, or reset... you just have to move the jumper to the other pin combination, power up your PC, then turn it back off and replace the jumper.
If you can't find a CMOS jumper, try unplugging your computer and removing the battery on your motherboard for a few minutes. When you turn it back on, your CMOS should reset to factory defaults.
May 07, 2009 | Computers & Internet
CMOS battery getting hot.. bad jumper setting... help!!
you can downlaod the manual which shows the jumper settings, plus diagnostic software and drivers for your board from the makers website at the address listed below.
http://support.asus.com/download/download_item.aspx?product=1&model=K8S-MX&SLanguage=en-us
Please rate this answer and good luck.
Oct 30, 2008 | ASUS K8S-MX Motherboard
I recently upraded my computer with an Asrock Penryn1600SLI-110dB motherboard with an Intel CORE 2 DUO E4600 processor. The symptoms are: When I tried to boot for the first time the cpu and case...
If you have recently upgraded your motherboard and when you turn it on, there is no display. You could check the jumper setting of your motherboard.
http://download.asrock.com/manual/PENRYN1600SLI-110DB.pdf
Check this site for jumper settings. Download the manual. Go first to page 11 and find clear CMOS jumper. That will be number 17. Then go to page 24 for the correct jumper settings. Jumper should be on the pins 1 and 2. That's the default settings.
If the jumper is set already to 1 and 2. Clear the CMOS by putting the jumper on 2 and 3. It should be off when you are going to set the jumper. This is to make sure that the settings for your motherboard is set to its original settings.
If you are going to clear the CMOS settings, you will have turn the computer on after clearing it and then turn it off again. Put the jumper back to pins 1 and 2. Now make sure that computer is totally off. Uplugged the computer just to make sure when you are doing this.
Note:
To test also the motherboard if it is working, do not connect the other pheriperals such as network card, sound card, and other cards that is not buit-in. Also drives such as Hard Drive and CDROM drives.
Check for beep codes. Short beeps tells you that the Video card is not inserted properly. Long beeps tells you that the memory card is not in place correctly.
Just remove the Video card or Memory card and then place it back again.
Computer should be off as well when doing this.
Sep 09, 2008 | Computers & Internet
Asrock P4i65G Motherboard Logo
346 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
pankaj rautela
pankaj rautela
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
