Question about Gateway FPD1960 19" Flat Panel LCD Monitor
Monitor problem. Monitor was working fine, I left it on and the next day it was off the the even the green light was off.
  • Thomas F. Schneider May 11, 2010
    Check the power cord to confirm voltage still available to the monitor?
    Problem Solver:
  • 11 Answers
Same prob here..except mine occured next use--outlet has power--cables are secure-just NO light on button--i'm thinking power supply button or board--I have found these parts on e-bay for 15.00--will let U know if it works
Posted on Aug 18, 2009
Monitor light is green but display is black
your power supply board, probably has some bad caps in it
Jun 12, 2010 | AOC LM729 17" LCD Monitor
What does the red light mean next to the power button?
The red light next to the power button is usuall the hard drive led which should blink every time the hard drive is in use, there is normally a green or yellow light for the power that shoukld stay on constant when the computer is on.
Feb 09, 2010 | Intel Compaq EVO D500 (RBMDTCPQP42400) PC...
No display on monitor
this lead to cpu overheating problem
clean your cpu fan and put some thermal grease between the fan and cpu
Jul 17, 2009 | Foxconn NF4K8AC-RS-1.0 Motherboard
Monitor has just stopped working
perhaps a repair shop. most electronic devices fail this way
Oct 06, 2017 | Hanns.G Corporation HX191DP LCD Monitor
Monitor problem
Hi...there,
It's turns blue to power safe mode (yellow) it's prevent futher damaged to your monitor. It's seems you got a busted backlight inverter. Need to replaced a new one...Since you only got it for a few months, send it back to Acer for a replacement of a new backlight inverter... Have a nice day!
Oct 17, 2008 | Acer AL1916W 19" LCD Monitor
Dell Minitors has lost power
small cable to button/control lights may be disconnected
Sep 18, 2008 | Dell UltraSharp 2405FPW 24" Flat Panel LCD...
Monitor keeps blank even the power lLED is on green
Try replacin a new display card. If it is fine working.ok
If not try fixing for cold solder in the video section.
I suggest video section according your report the light green LED lighted that shows the power section is doing fine.
Apr 22, 2008 | Proview PL913S 19" Flat Panel LCD Monitor
CM2019 LCD MONITOR NO PICTURE
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Feb 17, 2008 | Balance CM2019 19" LCD Monitor
Won't Turn On
Hi
If the green light doesnt turn on, check if the wall outlet is workign properly.
Also pls check with another moitor power cable.
If the above steps dont work, then the monitor needs to be serviced.
Jan 14, 2008 | Acer AL1912 19" LCD Monitor
Gateway FPD1960 19" Flat Panel LCD Monitor Logo
195 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
