Washing machine not functioning properly. Gets to rinse, water is draining from washing machine and then stops with three lights coming up and beeping.
    Genius:
  • Washing Mach... Master
  • 1,669 Answers
Ok, nice video. It would be helpful if you could supply the make and model of the machine!
Posted on Jan 04, 2013
  • 1294 Answers
SOURCE: Rinse water fills the washing machine when the spin cycle starts
Check your outlet filter, most likely it is blocked, preventing the water from draining out. Chk your pump too. Before this disconnect from the wall socket; and also check the pipe coming from the tub to the filter. Siphon out the excess water from inside the machine before you open the pipes.
Posted on May 18, 2007
  • 686 Answers
SOURCE: Washing Machine is not draining in rinse cycle to go to spin cycl
you both seem to have bad lid switches. A bad lid switch will prevent draining and spinning.
Posted on Apr 04, 2009
garing
  • 998 Answers
SOURCE: FISHER PAYKEL WASHING MACHINE STUCK IN RINSE CYCLE
lift the end of the drain hose see if the tub fills and goes in the rinse cycle if it works you have a syphon problem if so make your drain pipe stand longer.
Posted on Aug 06, 2009
Mark Harmer
  • 8 Answers
SOURCE: Washing machine problem
Same - there's a company in Denmark which does brushes - you have to hunt them down on the web. The brushes come in a brass slider and spring, and sit in a rubber cage. Make sure you don't throw away any bits of the old brushes as you might need to reuse the old rubber cage.
Another solution (if you have the rubber cage) is to move the brushes along a bit and bend the metal tabs on the brass slider. That will give you a contact again - the machine will work for a few weeks or so, which gives you time to order the new brushes.
Posted on Sep 21, 2009
SOURCE: Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Posted on Mar 21, 2010
I have a top lg fuzzy logic washing mechine, it stops at rinse position , display lights , gear are all working. whats the fault please ?
this usually happens when the water pump or the hoses are clogged and it cannot drain, it stops there and does nothing
Feb 10, 2015 | LG Washing Machines
Washer wont drain. fills with water. goes through wash cycle but wont drain. once it gets to the spin cycle, it spins for a few seconds and then stops and rinse light comes back on.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 21, 2011 | GE Washing Machines
Getting stuck on rinse light and beeps second by second
Mrs Vargas, if you wash on 'warm' you're using both hot and cold water mixed together. If the cold inlet valve is faulty (not uncommon) the machine will fill with hot water alone. When the machine gets to rinse, it can't advance because F&P machines rinse only with cold water. If the valve is faulty it can't fill. So it stops!...Not a big job for a tech....Good luck....Nomess
May 13, 2010 | Fisher and Paykel GWL11 Top Load Washer
Kenmore washing machine 110.22082 does not drain
you probably looking for a new drain pump ( control board also possible)
Sep 05, 2009 | Washing Machines
Wont spin
the machine will only drain after the rinses and give it three minutes to reach a pressure setting if this pressure setting is not met within the three minutes,the machine will stop, this sounds like the drain might be slightly blocked try there first, and then the drain pump and sump of the machine.
Jul 30, 2009 | Washing Machines
Washing machine not rinsing
Set your machine for warm wash warm rinse.
If it works OK.
Replace the water inlet valve.
Feb 14, 2009 | Kenmore 22422 Top Load Washer
Kenmore 22622100 Top Load Washer won't drain the water, nor rinse
HI!!! you seem to have a bad lid switch on your washer..I would also check the timer on it good lucck.
Feb 13, 2009 | Kenmore 22422 Top Load Washer
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
May 17, 2007 | Frigidaire FGX831C Top Load Stacked Washer...
Washing Machines Logo
50 people viewed this question
Top Washing Machines Experts
