Question about Amana AFD2535DES French Door Refrigerator
Amana af12538aes Refigerator No lights, ice, water
I've have this refrigerator for about a year and a half. I can hear the compressor kicking on. And the refrigerator and freezer are still cold.
But there is no lights when you open the doors to the refrigerator or freezer. And there is no lights / power to the Ice maker, water. temp controller pad on the front of the fridge
  • wbush571 Jan 20, 2009
    The problem is lack of power to the control panel on the door that controls everything. When this went out so did all the lights in the Fridge and Freezer. At first I thought the whole thing died on me. It was only when I heard the hum of the compressor and felt cold are that I knew it was something else.
  • wbush571 Jan 26, 2009
    I'm adding this in the hopes that it will help someone else in the future. I called Amana / Maytag up and talked to a rep. They were very helpful.
    The first thing they had me try was to hold the lock button for 3 seconds. When that didn't work they had me hold down the door alarm button. When I did I Deg F and Deg C appeared on the display. I had to cycle through the choices by using the freezer up and Down, and make the choice with the Refrigerator up and down.
    Seems that the Refrigerator went into a "Sabbath" mode. Not sure how it got there but it did. If you have a problem with your display this should be the first thing you try, since it is easy, and cost nothing.
    Oh to get out the setup mode just hold down the door alarm again. Thank you everyone for there help.
    Sergeant:
  • 221 Answers
There's no ice If your ice maker has stopped producing ice completely, check these, in this order:
  • It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:
    • If your ice maker has a small red plastic lever, lower it to lower the wire.
    • If there's no plastic lever, simply lower the wire.
    In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.
  • The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Small or too few ice cubes If the ice maker is producing ice poorly--making small cubes or too few cubes--you probably have a clogged water line, a defective water-inlet valve, or a defective ice maker mold thermostat that isn't cycling properly. Check these:
  • The water line that's attached to the back of the refrigerator. Make sure you have good water flow. If the flow is poor, repair, clean, or replace the tubing or the shut-off valve that supplies the water.
  • The water-inlet valve. Replace it if it has failed.
  • Check the freezer temperature. If should be 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker mold thermostat. Make sure that it's cycling properly.
Specks in the cubes If you find black or gray specks in your ice cubes, have a look at the ice cube tray. If the protective coating is peeling away, the most economical solution is to completely replace the ice maker.
Posted on Jan 19, 2009
  • Amana Master
  • 19,396 Answers
You need to test wiring harness and connectors, and control board. Enter model number on link below the link below to find schematics and replacement parts.
Appliance Parts From PartSelect
Need help finding the model number on your appliance?
Posted on Jan 23, 2009
It seems like you have an issue with the LEDs or display so u might have to just check electronic circuits for that and probably replace them and refrigerator seems to be working as u said the compressor and the freezer works. replace the display unit and it should work fine for you
Posted on Jan 20, 2009
    Sergeant:
  • 367 Answers
Look for the reset there should be a button somewhere near that panel. Also check the following or your own user manual.
Let me know
  • 163 Answers
Hi!!! make you seem to have a control board problem.If your not getting 120 volts in the light socket then you have a board problem..good luck..check for loose wire at the control board.
Four year old amana side by side has stopped cooling. Sounds like compressors is not kicking on. what's wrong?
Unplug it for 30 minutes to an hour and it should start up again. Problem is your compressor is no good. Get ready for a new fridge in 3-6 months.
Jul 25, 2012 | Amana Refrigerators
Bottom half for freezer not freezing and ice maker stopped making ice.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 25, 2011 | Amana 22.6 cu. ft. Side-By-Side...
My refrigerator is six years old and for the past two months is making a loud buzzing noise. The frequency has increased over time. What could it be? It's an Amana side by side model ASD2626HE. Sounds like...
Saw your post a week late but the sound could be the start relay on compressor is weaking or if the water is turned off to ice maker the water control valve will try to fill ice maker if the ice make switch is left on and has no water. I will send a manual shortly, Sea Breeze
Apr 12, 2010 | Amana ASD2626HE Side by Side Refrigerator
Shuts off - compressor not on
could well need re-gassing or it could be a blockage in ur compressor. If it comes on and you get a buzzz...click this is normally the problem.
Mar 20, 2010 | Amana 22.6 cu. ft. Side-By-Side...
The Amana refigerator I have stopped cooling. There is power to the unit, the lights work but the unit is not cooling. The unit clicks every few minutes.
Start capacitor,start relay, overload and windings in compressor need checked. When clicking like that the compressor is overheating and could damage the internal overload. Send model number so I may tell you the correct parts. I will be here if you need, Sea Breeze
Jan 20, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Refrigerator compressor never kicks on.
If the compressor "never kicks in," I don't see how you have having any cooling at all.
It could be a relay, or it could be the compressor. If you're lucky, it's a relay. These are cheap. In any event, it will take a diagnosis that is probably beyond the capability of a do-it-yourselfer.
Oct 15, 2009 | Amana 25.9 cu. ft. Side-by-Side...
Light is on, fan runs, compressor will not come on, compressor has never made a noise. Amana Distinctions model ARS2665A S/N 0010242568..side by side refrigerator freezer with ice maker.
Below bottom grate is a defrost timer. Turn slowly clockwise until you hear compressor start. If this works, replace defrost timer.
Let me know, Thanks, Sea Breeze
Mar 19, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Restart after year; light goes on nothing happens - no compressor
If doors were close during the time of not using the refrigerator, I believe the thermostat has become stuck. Straight wire the two wires on back of thermostat to see if compressor starts. Unplug first. Let me know, Sea Breeze
Mar 15, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Amana AFD2535DES French Door Refrigerator Logo
910 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
