Question about Sceptre 46 X460BVF120 LCD TV
VERTICAL LINE ON SCEPTRE 46 INCH LCD - Sceptre 46 X460BVF120 LCD TV
I Have a scepter X405BV-FHDR TV That has a black vertical line about an inch wide and is and about 4" from the center of the screen.
TCON board or the LCD panel is faulty. Can confirm by replacing the TCON board. In some models TCON board is integrated to the panel, In such cases you have to replace the panel.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Feb 07, 2017 | Sceptre Televison & Video
What causes two thin vertical lines about a quarter inch apart on right side of picture?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 21, 2015 | Sharp LC-46D64U 46 in. LCD HDTV
All of a sudden I have blue line vertical right of center
Vertical lines on an LCD screen are, as a general rule, not good! Your screen is heading for the drain!
Jul 17, 2010 | Sceptre X 7 Komodo II 17 in. Flat Panel...
Permanent Vertical Line on my Sony Bravia 46 inch LCD TV
What you're describing is usually the result of an improperly seated connector. With the power disconnected, open the tv and locate any connectors between the LCD screen and the driver circuit board. Unplug them, and reconnect it assuring it's properly and firmly seated. Be careful when handling these cables as they tend to be quite fragile... take your time.
Nov 28, 2009 | Sony BRAVIA KDL-46V3000 Television
Samsung LCD 46 inch vertical lines and then reboots
I bet they replace everything else but he LCD panel itself, you will see mor line as time goes by.
Nov 05, 2009 | Samsung 46 in. LCD HDTV
Vertical lines on LCD tv monitor
this is an address registry problem a technician needs to cure this issue.
Jul 10, 2009 | Sony BRAVIA KDL-46XBR2 46 in. LCD HDTV
Thin Vertical Line top to bottom about 2 inches from the right.
Probable panel is bad. contact mitsubishi maybe they will do somthing for you.
Jun 26, 2009 | Mitsubishi WD62527 62 in. LCD HDTV
Horizontal and vertical lines on the screen
i do no know take it back to the shop you got it from
Jun 04, 2009 | Sharp LC-46D64U 46 in. LCD HDTV
Thin Yellow Vertical Line - Samsung LNT4665F LCD TV
Unplug for 30 seconds from it's power source and then try it again. If that doesn't work, call Samsung for further troubleshooting and have your model number and serial number handy. Please be prepared to tell them how long the line is.
Mar 30, 2008 | Samsung LN-T4665F 46 in. LCD Television
Sceptre X20G Naga III showing horizontal and vertical lines
Hi...there,
Yeah, there it... It's called a AD board. It that piece of component were you plugged your VGA or DVI cables to it. Panel scratchs repair kits, not recommended. Beside your panel could be already damaged by this problems you had. Replacing the AD board gonna cost you though...any where from $70.00 or more... My recommendation, just get a new one...saved you the headached and $$$.
Have a nice day!
May 02, 2007 | Sceptre X20g-Naga III 20.1" LCD Monitor
Sceptre 46 X460BVF120 LCD TV Logo
Top Sceptre Televison & Video Experts
Jaime Hernandez
Are you a Sceptre Televison and Video Expert? Answer questions, earn points and help others
