Question about Dishwashers
Bosch silence plus 50 dBA won;t drain - Dishwashers
2 Suggested Answers
SOURCE: How to cancel cycle on dishwasher
On my dishwasher you have to press and hold the Stop or Cancel button for 5 to 10 seconds.
Posted on Sep 28, 2012
My dishwasher, a Bosch Silence Plus 48dba, makes one beep about every 20 minutes.
Interesting...You have a whole LOT of COMPANY... (upset users)
Evidently this machine has been tormenting its OWNERS since early 2005.
My Search got "banishing the beep bosch" (actually pretty funny)
Found great answers to your question BEFORE I was able to PULL UP any technical SPECIFICATIONS.
Most notably in 2008 by RACHELL G ("best answer") at
https://answers.yahoo.com/question/index?qid=20080307100614AA99tTV
Where-in you will find several approaches for TRANQUILITY... Most notable...
It tells you two buttons MUST be SIMULTANEOUSLY PRESSED to put the WASHER into PROGRAM MODE.
What display to look for... "0" from display.
More importantly... Tells US the changes must be SAVED to take effect on EXIT (below)
From JIMWROBLESKI... SAME SOURCED Article:
Rachel G is on the right track. Do you see a line under your wash selection buttons? Find the button at the right end of the line (probably labelled Pots & Pans, Half Load, or some other wash setting). Hold that and the power button down until you see a 0,1,2 or 3. Hit the button again till you see a 0 in the display.
Then hit the Power button to lock in the selection.
12/10/2015 ADDENDUM:
Went online and pulled down YOUR manual...
http://www.searspartsdirect.com/partsdirect/part-model/Bosch-Parts/Dishwasher-Parts/user-manuals/manual-downloads/Model-SHE43R56UC64/1794/0130000?modelNumber=SHE43R56UC%2F64&diagramPageId=&documentId=
These instructions are a wee bit more precise:
Cycle completion signal:
The cycle completion signal alerts you when a cycle completes and the dishwasher has waashed and
dried the dishes. You can choose to disable the tone or adjust the volume.
To activate:
1 With the unit OFF, press and hold the RIGHTof the two Cancel/Reset buttons and then press and hold
the On/Off button.
2 When the light on the Cancel/Reset button you are pressing illuminates and the tone goes off,
release both buttons.
3 Press the RIGHT of the two Cancel/Reset buttons again until you achieve the desired volume or until
there is no tone (to turn cycle completion signal OFF).
4 Press the On/Off button to save the setting.
Hope these are more helpful.
Dec 09, 2015 | Bosch Dishwashers
New installation. Opened and closed door. Why is it now warped and crooked?
Invite the installer to have another go at it - this time getting it right.
Sep 19, 2015 | Bosch SHX3AR72UC Ascenta Series 50 dBA 24"...
Bosch silence plus 50 dba dishwasher not draining it says E24
Error codes are cryptic but usually indicate the obvious. Probably drain pipe blocked with junk build up. Clear blockage. Spring curtain rod up the pipe. Ouch....
Perhaps a little draino.
Mar 02, 2015 | Bosch Dishwashers
Where is the thermal fuse
Go to Utube and copy and paste this in : Bosch dishwasher thermal fuse replacement location . You will be able to fix it yourself with the videos .
Here is the link :
https://www.youtube.com/results?search_query=Bosch+dishwasher+thermal++fuse+replacement+location
Hope this helps , Grant
Aug 11, 2014 | Bosch SHE3AR75UC Ascenta Series 50 dBA 62...
Why do i have a problem with my Bosch diswasher mod:she9er55uc/51 ...sanitize and refil rince are flashing when i start the machine
The rinse light is telling you the resiviore is empty and should be refilled the sanitize means that option is choosen try resetting options
Jun 25, 2014 | Bosch 800 Plus Series SHE9ER55UC 24...
Bosch silence plus 50 dba is showing error code h01
I believe this is a filling or water flow error. Make sure all the plumbing stuff is OK look at the valve under the sink that feeds the dishwasher. make sure it has not gotten turned off. Sometimes with hot water and cold also a chunk of crud will break off somewhere and get lodged blocking or restricting the flow. You may also have a filter somewhere on the DW to prevent junk from getting in. If there is a piece of crud a likely spot for it to be is at the valve connection under the sink where the DW hose connects to the hot water line. You can try unhooking the DW supply hose from the shut off(turn the shut off OFF first) and seeing if there is any junk in it. Shake the hose about 8" back from the end to try and send any junk in it flying across the kitchen. Also open the valve a bit with a bowl under it to blast any junk out. also see if it seems like a decent amount of water comes out to rule out any upstream plumbing issues.
Apr 05, 2014 | Bosch Evolution 300 DLX SHE43P26UC Full...
Bosch silence plus 50 dba has error code h01
The statement below can be found at: http://www.ehow.com/list_6978265_bosch-dishwasher-error-codes.html,
The SHU4326 and 4326 models use "Regular Wash" and "Rinse Hold" to begin the test while the other three series in this section use "Scrub Wash" and "Delicate/Econo," but all use the same set of fault codes, shown not as lights but as numbers on the Cycle Countdown display. Here, 1 is an aqua sensor fault, 2 is a heating fault, 4 is a filling fault, 8 is an NTC fault and 0 means that everything is working as it ought. During an actual wash, when you aren't testing, the Cycle Countdown display may show the letter "F," which also signifies a filling fault.
Read more: http://www.ehow.com/list_6978265_bosch-dishwasher-error-codes.html#ixzz33JutQVQR
Our Bosch Silence Plus 50 dBA shuts off and turns back on by itself.
You mean that you have to open it and slam it shut for it to finish?
Apr 25, 2013 | Bosch SHE3AR55UC Ascenta Series 50 dBA 42...
Sep 28, 2012 | Bosch Dishwashers
Dishwashers Logo
229 people viewed this question
Top Dishwashers Experts
