Question about Carrier SBP Humidifier
My carrier humidifier has a hose which drains into the laundry sink and a lot of water is coming out. Should this happen in winter? I thought water should only come out in the summer?
I have water on my windows and the demudifier in the basement goes on to remove moisture?
    Genius:
  • Carrier Master
  • 1,033 Answers
The humidifier should run in winter, however if the windows are fogged up it means the humidistat is set too high. Try lowerimg the setting on tue humidistat.
Posted on Jan 03, 2013
4 Suggested Answers
  • 1456 Answers
SOURCE: Carrier Humidifier Model No.49BG013210 -
Hello
Check all supply registers of the unit, which are wide and flat and located on your walls. Make sure that they are open and unclogged. Inspect the cleanliness of the unit and of the distribution pad.
Observe the fan's function. Spray lubricant on on the motor shaft of the fan unit to ensure it rotates properly.
Take off the small pipe between the solenoid valve and the humidifier and check if the opening is blocked. If not, you may need to replace the solenoid valve.
Check whether the thermostat has been set to a heat position and that the temperature is set above the room temperature. Check that the furnace is getting power supply and the circuit panel to see if all the circuit breakers are in an "ON" position. Check all the return air grills on the wall, make sure they are not blocked.
Check whether the thermostat is set to "COOL." Check also the circuit breakers and that they are in an "ON" position. Make sure that the blower motor in the furnace is running, as it should be when the thermostat has been set in a cool position.
Posted on Nov 05, 2010
SOURCE: Carrier SBP Humidifier is not working
I would suggest turning up the humidistat (usually located on the the return air duct to a higher setting and listening for a "click" noise on the supply valve. If you do hear a click but dont see / hear any water than the culprit is likely the valve itself.
Posted on Feb 16, 2009
  • 3248 Answers
SOURCE: Excessive water usage with Carrier LBP humidifier.
hi the water runs down the pad the fan blows air across is , this controled by the stat which should control the water flow / on or off, this should be under warranty in the first year
Posted on Mar 04, 2010
Water leaking / running from top of humidifier
humidifiers have a drain and if there is water going in it will be coming out the drain. check drain to see if it is clear, check hoses going into top of humidifier for cracks, check filter in humidifier.
Feb 05, 2014 | AutoFlo 250 Humidifier
I have a carrier weathermaker 9200 - Water is leaking from under the furnace. I have checked the humidifier and in the furnace itself and cant find where the water is coming from. The furnace runs and...
Chances are it's from the condesate tubes or collector box. If not, you may have a cracked A/C drain pan- lots of installers over tighten the male adapter into them and cause cracks. next check to see if they installed all the condensate plugs at install, some installers don't- read the manual in the "how to set up the condesate" section and trace EVERY tube to make sure they are routed correctly and not cracked/ cut/ nicked. Most furnaces are multi-position now and some installers don't move every tube nessessary... Hope this helps, if not, post a close-up pic, and I'll pinpoint the bad spot for you...
Feb 22, 2013 | Carrier Humidifiers
My humidifier is a Carrier and uses the square evaporator cartrages. There is a drain pipe coming out of the bottom that goes to a floor drain. I've noticed that there is a slow drip here all of the...
Hello, no the humidifier should be running only when the blower motor is running. Sounds like the solenoid valve is faulty if water keeps drainig from humidifier.
Sep 25, 2011 | Aprilaire 700 Humidifier
How to change from summer to winter
Can you give a little more info? Usually depending on where you live, people use de-humidifiers in the summer and humidifiers in the winter. If you need a humidifier year around, there should be nothing you need to do uther than filter cleaning and checking the water valve and cleaning the pan of mineral deposits. Depending on your water, you might need to pour a cup of limeaway in your pan and let it run for a couple hours. Then drain it, flush it, and let it keep running.
Sep 28, 2010 | Aprilaire 600 Humidifier
Mar 01, 2010 | Carrier LBP Humidifier
Water leak
Sounds like the air flow is too great and it is blowing the water in the bottom of the tray around before it gets a chance to drain. Try placing your summer, winter damper at half closed to slow the airflow down a little.
Nov 19, 2008 | Honeywell HE220A1019 Whole House...
Water flow through humidifier
I installed this humidifier (and had a lot of trouble installing it!) and was surprised by the flow of water. Mine leaks out of the bottom of the unit so I haven't actually used it yet. I'll try to figure out why it's leaking this weekend. I thought there would be less water flowing through the pad. I suspect that the weight of the unit is causing it to not be plumb so some water is dripping off of the pad and past the drain tray.
Nov 30, 2007 | Honeywell HE360A1027 Whole House...
Humidifier leaks
My Air-O-Swiss U7142 has a leak from the very bottom. I found that as long as the water flows on to the "pan" that evaporizes the water, the water will come out from the bottom. Does anybody know how to fix this?
Jan 18, 2006 | Honeywell HCM530 Humidifier
Carrier SBP Humidifier Logo
178 people viewed this question
Top Carrier Humidifiers Experts
Paul Carew
Mack Baxter
Tom Chichester
Are you a Carrier Humidifier Expert? Answer questions, earn points and help others
