Question about Asrock P4i65GV Motherboard
Jumper setting - Asrock P4i65GV Motherboard
  • nefhen
    nefhen Jan 03, 2013
    a have no picture on mij screen
  • 5,660 Answers
Probably not the jumper settings Nethen.
Check the Power Supply's three main voltages, with a multimeter set to DC Voltage.
3.3 Volts, 5 Volts, and 12 Volts.
No, don't guess. You could have a Power Supply with a weak voltage power rail, and have fans spinning, and LED's lighting up.
Why?
1) If ALL of the LED's were on at once, they would use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts of power.
3) A typical Processor can use 51 to 125 Watts of power.
Just depends on what Processor it is.
Hmmm, lemme see...
Socket 478 processor socket, and Intel 865G motherboard chipset;
Supports Intel Celeron, Celeron D, and Pentium 4.
Prescott, Northwood, and Willamette Cores,
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_4_microprocessors
http://en.wikipedia.org/wiki/List_of_Intel_Celeron_microprocessors#.22Willamette-128.22_.28180_nm.29
http://en.wikipedia.org/wiki/List_of_Intel_Celeron_microprocessors#Celeron_D_.28single-core.29
I'm going to say 55 to 89 Watts. Again, it depends on what Processor.
This means you would have enough power to turn those simply LED lights on, and fans; but NOT enough power to TURN the Processor on; with a Power Supply that has a weak voltage power rail.
OR,
Use a KNOWN to be good, Compatible power supply, for a temporary test unit.
Before you start though, take a CLOSE L@@K at those Electrolytic Capacitors on the motherboard.
(Radial Aluminum Electrolytic Capacitor/s, to be exact)
http://capacitorlab.com/visible-failures/index.htm
http://www.youtube.com/watch?v=Lut7MX5Dd_A
http://www.hardwaresecrets.com/article/595
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.mouser.com/Passive-Components/Capacitors/Aluminum-Electrolytic-Capacitors/Aluminum-Electrolytic-Capacitors-Leaded/_/N-75hqw/
Has anyone fooled with the CMOS jumper? If so state what happened.
Post back in a Comment.
Regards,
joecoolvette
Posted on Jan 03, 2013
Jumpers Serttings on Quantum HD
CS = Cable Select
DS = Master
SP = Spare (Slave)
Nov 10, 2013 | Maxtor Computers & Internet
Maxtor hard drive jumper settings for model 7245At maxtor hard drive jumper settings for model 52049h3
1. Jumper settings for model 7245At refer to LINK
2. jumper settings for model 52049h3 refer to LINK
Hope it helps.
Jun 22, 2011 | Maxtor Hard Drive
How the jumper setting is done for maxtor n256j50
If this is an IDE/PATA hard drive then the jumper settings are marked on the circuit board.
MA = master
SL = slave
CS = cable select
If this hard drive is the one installed on the Primary IDE controller the the jumper has to be set to Master. If it won't boot up then the jumper needs to be set to Cable select.
If this hard drive is a second hard drive and is connected to the 2nd connector on the IDE data cable that is connected to the primary IDE controller then the jumper must be set to Slave.
If this hard drive is a second hard drive and is connected to the secondary IDE controller and there is no other drive on the IDE data cable other than this hard disk the the jumper can be set to either Master or Slave.
If there is a CD drive on this cable too then the drives on this data cable then the jumpers on each drive must be set differently, they cannot be set the same jumper setting.
Feb 09, 2011 | Maxtor Hard Drive
I want to add another hard drive and need to know how to set the jumpers on my maxtor 90645d3 please help.ty
if you want to boot from this drive, please set the jumper to the master position.
if this drive is for additional storage, please set the jumper to slave. and make sure 1st hard drive is set to master.
if this is the only drive in the system, please set the jumper to single or remove the jumper.
there will be a chart telling you which pins are for which setting in the jumper area, which is between the data plug and the power plug on the back of your HDD.
main thing that will cause drives to not work is 2 jumpers on the same cable and they both are set to the same thng.. i.e. master/master or slave/slave. also, if one is set to single drive it will likely bypass the slave drive.
Jan 25, 2010 | Maxtor Hard Drive
Maxtor hard drive jumper setting for model 6v200e0
here is a poster of Maxtors jumper settings for each kind of drive.
Nov 12, 2009 | Computers & Internet
How to set jumpers in an old quantum fireball Lct20 HD. The master mode needs to be "jumpered"
Please look on top of your HD and u will see a table that show u the HD jumper setting (Master, Slave or Cable Select).
Then look again the rear side of the HD and u will see some pin that locate beside the power input of the HD, that is the jumper pin.
Now set the jumper according to your requirement refer to the jumper setting table just now. To set it just unplug the jumper (look like a U shape contactor covered with plastic) and plug it back according to the requirement. Sometime u may lost the jumper contactor, nevermind just use what ever conductor cable to roll between the two pin and make sure the pin is connected that all.
YBC (/\)
Oct 06, 2009 | Quantum Fireball Lct20 (QML20000LD-A) 20...
I need jumper settings for maxtor n256 model 96147h6 i wish to run it as a slave pls help. thx
For use as slave there is no jumper connected. (Master on/slave off0
Oct 04, 2009 | Maxtor Hard Drive
I NEED THE JUMPER SETTINGS FOR MICRO STAR MS-6533E MOTHERBOARD. THANS FOR THE HELP!
why are u trying to set the jumpers ? i should have thank u if u add some more details. all the jumpers onboard have their own purpose. look carefully on ur mainboard, u'll see the jumpers with their distinct labels.
May 05, 2009 | Computers & Internet
Asrock P4i65GV Motherboard Logo
194 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
