Prints on left side only
Picture isgood quality but only prints not quite one half with a jagged edge
    Problem Solver:
  • 6 Answers
If its a laser jet printer your ink jets are probably blocked. This will occur if the printer has not been used for a while. Some printers have a inkjet cleaning option, if not you may have to try to clean tham using a q-tip and a cleaning solution.
If its a toner printer the issue could be the developer solution on one side of the developer unit, or else a damaged imaging/drum unit.
Posted on Jan 03, 2013
  • 138 Answers
SOURCE: Hp 2300dtn Poor quality printing
Well lets start with DISREGARD ALL THE ABOVE BULL in the above brainless clarification request first noted. Here's a little good advice for you from a 14 year veteran printer tech.
Lets start with the cheapest and easiest moving to the more difficult or more expensive. Your problem can be caused by a few differnt things.
Print a configuration page (on the printer menu press check button, scroll to info menu, press check, scroll to print configuration, press check. Once you have the look for the page count on the page.
Try fresh good paper from a sealed ****. If your paper has picked up moisture this will show up as light or uneven print.
Next if the printer is over 100K page count, replace the transfer roller (foam roller inside printer under the toner cartridge). Lets try cleaning it first if your under 100K or to see if it improves at all. Any improvement will verify the transfer roller as bad. Review the photo below as it shows the transfer roller end inside the printer. The screwdriver is showing where the release white clips are (two). Press the tabs and lift the left side. The right will come out of the hole socket on its own but note where the hole on the right is for replacement. Try not handling the roller with your bare hands any more than you must as oil from your hands can cause slight imaging defects if your hands are sweaty or damp.
Using a clean rag (like t-shirt material) dampened (not soaking) with 99% alcohol (not 70%) lets clean the roller. Gently but firmly scrub the talc and paper dust buil-up from the roller. Once you've removed the build up it should return to a dark grey color. Let the 99% alcohol dry (5 minutes or so)and reinstall.
Try printing again. If the problem is solved your done. If not and it has improved, you will need a new transfer roller. They are available on Ebay much cheaper than from a dealer. The part number to search for is RM1-0343. Here's a link to ebay for one at around $20.00 landed.
http://cgi.ebay.com/LJ-2300-Transfer-Roller-New-OEM-RM1-0343-Unopened_W0QQitemZ270247145853QQcmdZViewItem?_trksid=p3286.m20.l1116
If the problem is the same, your problem is more than likely a dirty laser scanner lense. You'll need to remove the covers from the printer to accomplish this. The laser scanner can be located under the top cover. It's the larger black box on the top side of the printer. Once the scanner has been located, remove the top cover. DO NOT TOUCH THE MULTI SIDED SPINNING MIRROR TO THE REAR OF THE SCANNER. You will be cleaning the clear lenses and mirror towards the front. You clean this gently with a CLEAN and DRY Q-tip. Use a few Q-tips rather than re-applying a dirty one. Heck they are cheap!
Re-assemble the printer and try printing again. One of the steps above should resolve your issue. I am enclosing a link to a free service manual for your printer to help you through the disassembly and in the rare case that your issue remains.
http://www.feedroller.com/Store/Service%20Manual/LASERJET%202300%20Service%20Manual.pdf
Hope this helps you a lot more than the first response you receved. If so rate me with a FIXYA!
Thanks.
Posted on Oct 02, 2008
aicaxz
  • 511 Answers
SOURCE: Poor, faded print quality on left and right sides of paper
Have you check the teflon at the heater? have you clean the reflector of laser? Try that.
Posted on May 30, 2009
SOURCE: Edge to edge print problem
The Fargo DTC550 will not be able to print an "over the edge" card. Any Direct To Card printers will have a white line on the edges. There are several printers that are able to print covering the entire card, those printers are called Reverse Transfer or Fargo's High Definition Printers. One printer that I do recommend is the Fargo HDP5000, you can read more about it at: http://printers.idcardgroup.com/productdetails.aspx?item=hdp5000
Posted on Jun 11, 2009
QHabib
  • 126 Answers
SOURCE: The printer will not print on the half inch left
You will need to set margins for your documents. As well as cross verify the paper size in the printer with the paper size of your documents on the computer.
To check the margins in Word 2007 document: Click on the Tab Page Layout Click on Margins and set it to Normal or Narrow Click on Size to choose your paper size (this should be the same as the one your printer uses)
An alternate method is to go to File menu and choose Print Preview under Print Modify the margins and paper size and look at the Preview.
For pdf documents make sure your Page Scaling is selected to 'Shrink to Printable Area'
To change/check paper size for printer from the computer Go to Control Panel > Printers Right click on your printer model and choose Properties. Go to the Page Setup tab Choose the paper size of the paper inserted in your printer.
Hope this helps.
Posted on Sep 02, 2009
reitann
  • 214 Answers
SOURCE: Picture only prints on one half of page
Try printing a testpage just press print + cancel and make sure you have a paper loaded
Posted on Dec 29, 2009
How can I fix my visio tv 49 inch?
The backlights are out on one side.
Jun 15, 2017 | Televison & Video
What is the best photo size for good quality digital photo prints from my Samsung tl205?
I always recommend setting the camera to take the largest size format at the highest quality or "resolution" settings the camera offers.
Using the largest size and resolution combination provides images with the most detail available in your camera. It will provide excellent results for standard 4 x 6 prints and you'll be glad you chose the larger format and resolution if you wish to edit, crop & enlarge any of your shots. At one point, you'll take a picture that you're going to want to enlarge and frame - but when you have your camera set for smaller images at lower resolutions, jagged edges and pixelization begins to appear in the image. The more you enlarge - the more noticeable it becomes. You see this for yourself by taking a picture of something with small size and low resolution settings and another picture of the exact same scene but with the largest size and highest resolution settings. Display the pictures on your computer screen and enlarge them both to 200% or more. Compare the details and edges of both pictures at the same percentage on enlargement to see what I'm describing.
The size of your pictures has no bearing on the cost of printing them. The only downside is the fact that your memory card will hold fewer pictures. This means you'll need to buy additional or larger memory cards if you find that you take too many pictures between the times you transfer to your computer.
I hope this helps & good luck! Please rate my reply. Thank you.
Apr 01, 2011 | Samsung DualView TL205 Digital Camera
There is a black gap between the actual picture and the right edge of the monitor and it also "pushes" the picture into the left edge a half an inch or so, rendering it unviewable on the left...
the "horizontal position "control has been tampered with .but locating it and setting it can be hazardous so only a qualified person should do it .
Mar 06, 2011 | Samsung DynaFlat TX-R2035 TV
Vertical lines are not smooth, they are jagged. The lines are straight for about an inch, then they are offset to the left. Some words are broken in half horiziontally with the lower half offset to the...
You can align the print cartridges at any time from the control panel or by using the HP Image Zone software on your computer. Aligning the print cartridges ensures high-quality output.
Note: If you remove and reinstall the same print cartridge, the HP all-in-one will not prompt you to align the print cartridges. The HP all-in-one remembers the alignment values for that print cartridge, so you do not need to realign the print cartridges.
To align the cartridges from the control panel:
  1. Load letter or A4 unused plain white paper into the input tray.
  2. Press Setup.
  3. Press 6, then press 2.
  4. This displays the Tools menu and then selects Align Print Cartridge.
  5. The HP all-in-one prints a print cartridge alignment sheet and aligns the print cartridges.
Feb 16, 2011 | HP OfficeJet 7410 All-In-One InkJet...
PRINT IS BLURRY
The printed output is fuzzy, blurry, or grainy, or the edges of objects in the images are jagged. Solution Follow these steps until the issue is resolved. Step one: Check your paper
  • Many papers have printing and non-printing sides. Load the paper with the printing side down.
  • Use the correct paper type for the project. For everyday documents, plain paper works well. For documents with dense printing, such as high-contrast graphics or photographs, use HP Advanced paper for the best results.
  • If these steps do not help, try a different paper. Ink might not bleed as easily on heavier paper. Paper that does not accept ink well is also prone to bleeding and smearing. HP designs its inks and papers to work together.
Step two: Check the settings
  1. In the program being used for printing, click File , and then click Print . The Print window opens.
  2. Make sure the appropriate product is selected, and then click Preferences or Properties . The Preferences/Properties window opens.
  3. Click the Printing Shortcuts tab. Consider modifying some or all of the options in the Printing Shortcuts menu to increase print quality.
    • Print quality : If the quality of the printouts is not acceptable, try increasing the print quality. To print more quickly, try decreasing the print quality.
    • Paper type : If one of the options matches the paper type exactly, select it instead of Automatic .
    • Paper size : Make sure that this option matches the paper loaded in the product.
    To see additional options, click the Advanced tab, and then click Advanced Features . The Advanced Features window opens. Consider changing the following option: Ink volume : Adjust the amount of ink that prints on a page. For lighter images (less ink), drag the slider to the left. For darker images (more ink), drag the slider to the right. The lighter the ink volume, the more quickly the printout dries.
Step three: Check image resolution Make sure that the image file has enough resolution for the size of the printed picture. Although many photo applications can enlarge an image or part of an image to any size, eventually the individual pixels become visible and the whole image looks blurry. Here are some general guidelines for image file resolutions:
  • 94 pixels per cm (240 pixels per inch) for images to print on smaller format photo paper, such as 10 x 15 cm (4 x 6 inch)
  • 117 pixels per cm (300 pixels per inch) or higher for larger format photo papers
  • Lower resolutions might produce acceptable images when printed on rough-textured paper
Step four: Align the cartridges If the previous steps have not improved the appearance of the printout, align the cartridges. See the user guide for alignment instructions. PSC 1600 User guide: http://h10032.www1.hp.com/ctg/Manual/c00276605.pdf Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 11, 2009 | HP PSC 1600 InkJet Printer
Nov 15, 2008 | Kodak EasyShare Thermal Photo Printer
L7780 won't print on edge of paper
it could be the printer settings. Before you actually print something go to File>print:- and then choose properties, click on advanced and ensure that the correct paper and size is set to how you want it.
Oct 28, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
Epson
It sound like a fuser roller or a developing issue. If you can give me some more info we can narrow it down.
Is the line on all pages or just some of them?
Are the edges of the line crisp and clear or are they jagged?
Does the line look the same on all the prints?
How old is the machine and how many prints are on it (if avail)?
Jan 17, 2008 | Computers & Internet
Sony trinitron KV27V22
Solder any / bad connects horiz,vert and power supply then
try again....................T.
Please rate this solution.........................
Nov 15, 2007 | Sony KV-27V22 TV
19 people viewed this question
jasbo
jasbo
