Question about Frigidaire FPMC3085KF Professional 30" Electric Wall Oven/Microwave Co
Broiler element does not heat
Broiler element resistance reads OK, so unfortunately the simplest solution is not it. Pulled controller off oven and disconnected the harnesses. Checking the wires at the harness, there is no continuity between BR/W and BL wire associated with the broiler element and the thermal circuit breaker. This suggests a bad thermal circuit breaker. I have reset the over at the breaker panel, but the thermal breaker does not reset. Where is this device located in the fpmc3085kf?
    Problem Solver:
  • 14 Answers
Youtube has much information in video
Posted on Jun 08, 2017
2 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: frigidaire microwave continues to blow 20 amp
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead several seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
We would need the model number to help you further, but would be happy to give you more DIY tips.
Chances are we can point you to the service manual online.
Posted on Aug 19, 2010
Kenmore oven C880 676239J2 is not heating up... is the only fuse the one located under the light on top of the control panel?
I doubt that fuse is used for the heating element. If you can unplug the element in the oven, an ohmmeter should show you if it has opened up (burned out) on you. Turn off the 220 breaker in the breaker box before doing this even though there should be no voltage with the controls turned off. (There usually will still be 110 to the top of the unit.)
Jun 05, 2017 | Kenmore Microwave Ovens
I have a built in wall oven whirlpool gold mod.gbs309pvsoo controls turn on but no heat from element
Could be element could be Hi limit thermostat could be control. In that order. First step is turn breaker off and remove element to make sure the wires are still connected to back of element. Visually inspect element very good for burns or a white powder residue signally the element burned up. Next step is harder, need to remove the oven and take off back panel, there you will find the hi temp thermostat. Check for continuity, if none replace.
Feb 02, 2015 | Whirlpool GSC309PVB 30" Built-in Microwave...
What is Error F7
I am having the same problem. According to the owner's repair guide error Code F7 indicates that power to the magnetron was interrupted. You will want to make the following checks: 1. Unplug microwave oven or disconnect power. 2. After 40 seconds, check to see whether this solves the problem. 3. Unplug microwave oven or disconnect power. 4. Check resistance of the magnetron thermostat. 5. Check the magnetron. 6. Check wiring to the 1100W inverter and control system. See "Checking Inverters." 7. Plug in microwave oven or reconnect power. 8. Check operation of all interlock switches. Check door, hinge and cavity front alignment. Adjust as needed. 9. Unplug microwave oven or disconnect power. 10. If switches operate correctly, replace 1100W inverter. 11. If problem persists, replace electronic control. 12. Plug in microwave oven or reconnect power.
While this is helpful, it is still out of my confort zone as I pulled the control panel and discovered a virtual zoo of connectors. Obviously ponly a trained repairman knows which ones need to be checked. I will probably have to resort to calling one and shelling out the dough.
Jun 21, 2013 | KitchenAid KHHS179LSS Convection /...
Pleb30s8ccc baking heating element does not work. I checked the voltage at the terminals and am not getting a reading while the broiler gets a reading. What do I do next?
You will have to trace the wires back from the terminals to the switch or thermostat where they come from. The heating element will have its own thermostat & this is the most probable cause for the power not reaching the element. It will then have to be replaced.
Let me know if you need any further assistance.
Best wishes,
Graemevm
Mar 24, 2011 | Microwave Ovens
Maytag Gemini Electric Range Model MER6770AAW. Upper oven broiler element will not heat up. Took the element to a parts appliance store where they tested it, and the element tested that it was still...
The control to tun the element on must be faulty, you will have to check it with an ohmmeter after youtake the wires off of jt make sure you draw a diagram of where the wires go when you put them back on Make sure to turn the power off before you start Hope this works for you good luck
Jan 03, 2011 | Microwave Ovens
Range controlpad is no working, is showing SA6& each burnershows 56 orS6
Hi and
SA (burners off) is a door lock switch A problem. The switch has to be checked for 0 resistance across the terminals. If it has resistance then there is another resitance check to look ofr 2350 Ohms between pin 5 in plug P4 and terminal N. If the meter reads zero or infinity the lock motor or the wiring to the lock motor is defective. If the meter reads 2350 Ohms replace the electronic oven control.
This is per page 97 of the service manual: (C/P)
http://frigidaireservicetips.com/pdfs/477_5.pdf
Remove power from the range and go to the back of
the control and disconnect the P3 plug. Measure
the resistance between pins 3 and 4. If the meter
reads infinity check the oven door switch and the
wiring to the door switch. If the meter reads zero go
to step 2.
2. Measure the resistance between pins 1 and 3 of
plug P3. If the meter reads infinity switch A of the
lock motor assembly or the wiring to switch A is
defective. If the meter reads zero go to step 3.
3. Measure the resistance between pin 5 in plug P4
Thanks for choosing FixYa,
Kelly
Nov 24, 2010 | Kenmore Microwave Ovens
My old GE oven (JSP38G052BG) won't bake or broil. It start then stop after 1 or 2 minutes. The heating elements get worm. Can you help me please
Hello ediben11.
If your oven's bake or the broiler heating elements won't heat but the range burners still work;the clock may be set for a timed or self-cleaning cycle. So,make sure to check the clock buttons and the knobs are set properly.
*If your clock has a knob that says "push for manual" then push the knob in after that, try the baking and broiling elements again.
*If it still does not work properly, you may have a defect in the thermostat/selector switch/common wiring.
*If the oven does not have a separate bake or broil selector switch; then the thermostat is probably the problem. It is not easy to check the selector switch or thermostat for proper operation. If you suspect a problem in this area, call a qualified appliance repair technician.
Hope this helps.
Mar 23, 2010 | LG LMVM1945 Microwave Oven
Microwave not heating
In all likelihood the Magnetron, or Power Diode has failed, or perhaps even the Power Supply. You need to have it serviced by a reputable service centre/man. Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one.
Feb 26, 2010 | GE Microwave Ovens
F3 code on GE
ok here is the result to searching GE the answer to thew code.
Please rate our help to keep this free service online
Open oven temperature sensor (circuit) (over 2700 ohms) or, shorted oven temperature sensor. Could be a result of:
· contamination on terminals
· pinched wire in oven temperature sensor circuit
· cold solder joint on control. · Disconnect power to range and remove oven temperature sensor connector from control.
· Measure oven temperature sensor resistance at oven temperature sensor connector (take care not to damage terminals in block) - Should read 1100 ohms at room temperature (approx 72 degrees F).
· Measure each oven temperature sensor lead from connector block to ground. If shorted, look for pinched or cut wire in oven temperature sensor circuit.
· Check connector terminals - Look for deformed or corrosion on terminals. Repair or replace.
If all above is ok replace control.
Aug 28, 2009 | GE JVM1430 Microwave Oven
He's Dead, Jim! Died when door opened, but Usual Suspects clear?
May 13, 2009 | GE JE2160 Microwave Oven
Frigidaire FPMC3085KF Professional 30" Electric Wall Oven/Microwave Co Logo
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
