Question about Refrigerators
Orien ice machine fs651m freezing up
Freezing up in ice making area
2 Suggested Answers
22yooper
  • 828 Answers
SOURCE: KitchenAid Ice Machine doesn't freeze
First check the switch and make sure it is not in the clean position.
Check for compressor operation. if the machine is in the clean position the compressor will not run and form ice.
Posted on Jun 01, 2008
GE side by side refrigerator-freezer daily makes loud grrrrrnng noise. Sporadic. Comes from area just above ice maker. Makes no difference if I turn ice maker off. Any ideas what is causing this?
Many ice maker sporadically turn to keep ice from freezing together and becoming a solid block of ice. This would occur even if the ice maker is turned off in order to keep the ice already made from freezing. It is generally short and not that loud. I'm surprised you find it disturbing.
Jun 27, 2016 | GE Refrigerators
The inlet to my icemaker is frozen and wont make ice
Most likely your machine water valve is leaking water when not asked for water for the ice maker. This small amount of water will freeze inside that tube due to freezing temperatures inside freezer.
You may need to change the water valve assembly.
Try to use a heat gun (may be a hair dryer - be careful with water area) to slightly warm up the ice maker water inlet. You have to be very careful not apply direct too much heat. It is plastic and melt. Has to very slow and mild.
Oct 01, 2014 | Whirlpool Refrigerators
Ice getting to thick and not dumping
go to the freeze timer which has off and on dip switches. take some freeze time out by moving the first switch to off this will shorten freeze time. Also check the harvest assist solenoid and plunger when it go's into harvest. make sure the machine is cleaned and check the cube plate to make sure that none of the plates are not loose this will cause ice to freeze between the loose spots and will not let ice come off the plate.
Jul 21, 2014 | Ice-O-Matic ICEU220HA Undercounter Ice...
Short freeze
Ice is to thin. Check to make sure water inlet valve is not letting water go through valve during freeze cycle. Make sure condenser coil is clean and condenser fan is running. Check the hot gas valve to make sure it is not bypassing during freeze cycle.
Apr 15, 2014 | Scotsman C0630MR_HD30B-32 684 lb 30"...
Ice bridge too thick
look at the evap plate to see if there is a ice thickness probe, if there is it should have a screw 5/16 going through it that you can turn in or out you wont the thickness of a penny between the evaporator and the stainless sensor turn screw 1/8 of a turn at at a time let machine make a sheet of ice and keep making adjustments until you achieve the right thickness. Now if there is not a probe then the thickness is built in the run time of the control board. you can not adjust it. you need a tec to look at it to make sure your not having a harvest problem if it is not harvesting every time them ice will be to thick.
Jan 14, 2014 | Orien 44 Lb. Built-in Under Counter Clear...
COMPRESSOR WILL FREEZE A CYCLE OR 2 THEN STOP WORKING
a symptom of low refrigerrant is that the evaporator coil will develop a small very cold area but wont cool the entire surface .. that cold area can ice up and block air flow .. the result can be an overworked compressor with little or no cooling ... other things that can cause the same trouble
1. bad or blocked air flow on the external coils or condenser fan ..
2. a leak in the door seal will allow moisture that can cause icing
if there is icing then you can turn it off with the door open until the ice melts .. then start over ..
Jul 24, 2009 | Freezers
Ice Maker frost and freeze where ice drops into refrigerator door
You need a service guy to look at it. It could be water leaking or a simple case that the flap isnt sealing and the ice melts and then freezes the flap open
May 14, 2009 | U-Line CO2075F-B Echelon Refrigerator Ice...
U-Line icemaker is undependable
to make ice the thermo in the ice maker must be below 5 F...make sure there is a clear flow between the evaporator and the ice make also make sure you have a good seal between the freezer and the refrig areas..
1) put a cup of water in the refrig.
2)start with the coolest setting and move 1 setting every 24 hrs.
until it up until it freezing the water.
3) coolest you can get but not freezing the refrig...
hope is help
Aug 30, 2008 | U-Line Refrigerator Ice Maker
KitchenAid Ice Machine doesn't freeze water to make ice. The water flows over the freezing plate, but no ice.
May 31, 2008 | Refrigerators
Refrigerators Logo
85 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
