Question about Nikon Cameras
Nikon d80 will not keep sd card set in camera
Sd card will not stay in camera
    Sergeant:
  • 321 Answers
Check any broken peice inside
Posted on Jan 11, 2013
  • 265 Answers
SOURCE: nikon D80 "CHA"
Margie,
When you say it won't let you put it in, do you mean it won't fit in, physically or just that the CHA is on when it is in? If that is the case, you might look at the card and see if it is in 'locked' mode. If it is, it has to be unlocked before the camera can take a picture using that card. Also, your camera's information is available online from Nikon. Here is a link to the Owner's Manual for your camera body:
http://www.nikonusa.com/pdf/manuals/noprint/D80_noprint.pdf
If you want a printable version, you have to provide the website with your camera's serial number. You can do so here:
http://support.nikontech.com/cgi-bin/nikonusa.cfg/php/enduser/std_adp.php?p_faqid=14051
Posted on Dec 22, 2007
SOURCE: using a speedlight sb800 off camera on a Nikon d80
Found a great website that explains this since it's not in any of the manuals or other websites I have searched for so long!
http://www.kenrockwell.com/nikon/ittlslave.htm
HOW TO DO IT
This covers the D70 and SB-600 which I use personally. It should be similar on other cameras. Any questions? Presuming you have USA equipment, call (800) NIKON-UX for details.
On your D300:
Press MENU.
Move up or down to: PENCIL menu.
Move right and down to: e Bracketing/Flash
Move right and down to: e3: Flash cntrl for Built-in Flash
Move right and down to: C Commander Mode
On your D70:
Use P, S, A or M exposure mode.
Press MENU. Go to the yellow wrench menu, and be sure CSM MENU is set to DETAILED. Otherwise you won't see the next setting!
Go to the CSM menu which looks like a purple pencil. Set #19, Flash Mode, to "COMMANDER MODE." Further click to the right to set the commander mode to "TTL."
You also may set the commander mode to Manual or AA, which are other modes to fire the remote flash. The SB-600 only works with TTL and Manual. You set the manual power level at the camera.
Don't forget to POP UP THE BUILT-IN FLASH!
On your D200:
Press MENU.
Move right and down to: e3: Built-in Flash
Move right to get to a confusing panel of C Commander Mode settings.
Once in this confusing panel you can set everything for two external groups of flashes and the built-in flash. You move between the different fields by moving left and right, and set any field by toggling up and down.
In this panel you must select Channel, and set it to 3. Default is 1, which is the default for the SB-800. Don't ask me why they are different. Default for the SB-600 flash is channel 3, so if you forget this it won't work! Sorry about the complexity; Nikon didn't ask me for help here.
This is such a pain I use one of the D200's setting banks to store this.
On your SB-600:
Hold down ZOOM and "-" together to enter the CSM settings. That's why you see a gray "CSM" marking between those two buttons.
Press either the + or - buttons until you see an icon that looks like a wiggly Z-shaped arrow. This arrow refers to wireless communication between the flash and camera. When you see the wiggly arrow, press MODE to make it say ON.
Press ZOOM and "-" together to get out of the CSM mode. Even easier, just tap the power button to get back to normal operation. It won't turn off if you hit it while in the CSM settings.
Presuming you did this correctly you'll see "CHannel 3" and "GROUP A" displayed. If you see different channels or groups then press MODE to get one or the other to flash and then the + or - buttons to set them back to 3 and A. No, I have no idea why these are the settings you have to use instead of 1 and A; 3 and A are what you need to talk to the D70's built in flash. If you get smart and choose others then it won't work. The other channels and groups are for people much smarter than I who want to try to rig up a zillion flashes to work together and control them all separately and remotely. I prefer professional studio strobes if I'm using more than one strobe at a time.
The SB-600 doesn't go into standby in this mode, so you can run down your batteries if you forget and leave it this way. It just sits there blinking its little red LEDs visible from the front.
HOW TO SHOOT
Easy, just shoot! If you set everything to TTL as I suggest then the camera just does everything. You and I are free to concentrate on the more important parts of making a great image.
Everything is controlled from your camera. This is very convenient if you have the strobes someplace remote, like duct taped behind plants.
You can control the remote flash's output simply by varying the flash exposure compensation control on the camera. You can do that without taking your eye away from the finder! You do that by pressing the same button you used to pop up the flash and then moving the front control wheel. You'll see the amount of compensation on both the camera's top LCD as well as through the finder. Brilliant! You can add more or less flash fill without having to walk over to the remote flash.
You can set the mode (TTL, Manual or AA) from the camera.
You can set the manual power level from the camera as well.
Try to have the little black window on the bottom right of the flash (marked with that same wiggly arrow) pointing in the general direction of the camera. Thankfully it's not a big deal; you don't even need a line of sight so long as the flash is anywhere near the camera or subject.
The sensor is sensitive enough to pick up the flash from the camera even if it has to bounce around a corner or off the subject. This makes this current system so much better than the older ones. You can hide flashes anyplace and even if they can't see the camera they usually go off correctly. They beep to let you know what's going on, even if you cant' see them.
The i-TTL system is much better than the old systems because it just works. If you ever used the older systems you'd know that half the time you'd get no flash, or a full-power flash that also wasted the shot. This new system just works, and that's critical for use in the field where the remote flash is rested on a garbage can or held in your left hand while you hold the camera with your right.
I even can have the flash in a different room out of view of the camera and it goes off just fine.
It works fine even 50 feet away. I haven't tried it any further. Honestly I have no need for a flash that far away; I was just seeing if it worked.
Posted on Sep 16, 2008
  • 5 Answers
SOURCE: My Nikon D80 is not Auto Focussing and 'r11' keeps appearing.
Try cleaning the lens contacts with alcohol or sprit
Posted on Jun 28, 2009
  • 102366 Answers
SOURCE: Nikon Coolpix 5900/4 GB Kingston SD Card
The 5900 uses SD cards. The 4GB card you have is actually an SDHC card and will not work in the 5900. You'll have to stay with cards 2GB and smaller.
Posted on May 19, 2010
lock123
  • 6831 Answers
SOURCE: nikon d80 will not take pics has err flashing in
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Aug 31, 2010
Upgrade firmware for Nikon D80
Confirming the firmware version:
  1. Turn on the D80
  2. Press the MENU button and select Firmware Version from the setup menu. The camera's firmware version will be displayed.
  3. Turn off the D80
Basic Upgrade instructions: for detailed instructions, see pdf files below.
  1. Download and expand the firmware files
  2. Format an approved SD (Secure Digital) memory card in the camera
  3. Connect Camera to computer (in MSC USB mode) or use a SD Card Reader
  4. Copy to the top level of the card the downloaded "A firmware" file
  5. Disconnect camera from computer
  6. Update the firmware from the "Setup" menu
  7. Follow the camera's on-screen menus
  8. Repeat steps 2 through 7 using the "B Firmware"
  9. Re-format Card
D80 1 11 firmware upgrade Nikon Knowledgebase
Apr 03, 2014 | Nikon Cameras
Everything on control panel is flashing. Can't operate camera.
Hi Shirley,
It sounds like your camera's CPU is stuck in a loop. First, I'd remove and transfer any pictures on the SD card in a card reader connected to your computer, followed by formatting the card. Leave the SD card out of the D80. Set the power switch on the D80 to "off" and install a freshly charged battery. If it is still flashing, a "Full Reset" may help.
Nikon recommends that a full reset be done only under direction of Nikon staff. The procedure is outlined along with graphics on this page under "Full reset". I suggest calling Nikon support to see if they think this procedure (or maybe another that they have) will solve the problem.
Nikon Technical Support
8AM - 12AM (Eastern)
7 days a week
1-800-Nikon-US
1-800-645-6687
Jan 09, 2013 | Nikon D80 Body Only Digital Camera
My computer is not reading the memory card. Nikon D80
If you are using a 4GB or higher SD card, some computers cannot read it directly from their in-built SD reader. Buy an external card reader and plug it in. Your computer should now be able to read cards 4GB and larger
Oct 07, 2009 | Nikon D80 Digital Camera with 18-135mm...
I have a Nikon D80. A few months ago, the SD card would not stay in the slot, then for no reason it started working normally agan. Now it won't stay in again. It doesn't catch when you push it in, it just...
the sd card slot is designed in such a way that when you push your card inside the slot till the deepest part and when yout leave it, it fits into the slot. if you want to take the card out you have to push the card again till the deep and leave to get it out.(just like a spring aided trap). i dont think that your slot is damaged.may be you are unsure how to insert the card in the slot. if you still find problems, please write back.
Jul 21, 2009 | Nikon D80 Digital Camera
Nikon d80 can't take pictures
Be sure you don't have the SD card loked (look at the tab on the SD card itself). You may be seeing CHA or something similar in the viewfiner too.
Apr 24, 2009 | Nikon D80 Body Only Digital Camera
Getting (CHR)error message on my D80
Your SD card may be "locked." Check the SD cards slider lock and make sure it's set to allow you to write to the card.
Apr 14, 2009 | Nikon D80 Digital Camera with 18-135mm...
Nikon D80 no picture number in LED & menu not working
Format the SD cards with the camera. You might have to do a software upgrade on the camera since the Kodak card files are different than Nikons.
Mar 29, 2017 | Nikon D80 Digital Camera with 18-135mm...
How to fix -E- problem Nikon D80. Thanks
The -E- just means that there is no SD card in the camera. There is also a setting that prevents the camera from attempting to take a shot without a card, and I assume that represents your flash in the viewfinder.
Feb 21, 2009 | Nikon D80 Digital Camera with 18-135mm...
Nikon D80 SD Card slot problem
Is it slightly thicker on the contact end, Or is something stuck on the flat corner? try getting a needle and picking out any plastic that could be stuck there. Is the card under warranty
Sep 09, 2008 | Nikon D80 Digital Camera with 18-135mm...
Nikon D80 Exposure Count
My camera is now fixed. It was a tiny speck of dirt on the sensors between the mounting of the lense & the camera. The uy that fixed it said it is a problem with the camera because they are so sensitive.
Jan 13, 2008 | Nikon D80 Digital Camera with 18-135mm...
Cameras Logo
32 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
