Unit will not power on. I took shell off and checked fuse and it's good, I have a basic understanding of electronics, but need help. I purchased it on ebay and item came in DOA, have no ideal what caused it to be DOA. All the boards look good and there is no burnt smell as if amp has overheated, please help
  • 1 more comment
  • Charles Hicks Jan 19, 2009
    Sony TA AX295 Integrated Stereo Amplifier, I don't have an exact date, but amp was made around 1985 thru 1989.
    Sony TA-AX295 Integrated Stereo Amplifier wont turn on. Push power button and nothing, fuse is good, the unit dosen't have burnt smell. I've been checking soilder connections and everythings looking good, I've have tested voltage on power supply board, I have correct voltage coming in from plug, need help on diagnoseing problem
  • Charles Hicks Jan 25, 2009
    After researching the problem power from power board to diode board had the 5 volt, the problem was in the soldier, from post to circuit, on the power board, when circuit was suppose to energize it failed due to a faulty soldier. I believe this to occur in most older units, from heating and cooling of the circuit with vibration or sudden impact. Thanks for lookin this problem solved.
    Brigadier General:
  • 8,619 Answers
Hi!
Try to check the power at all the capacitors, if you have power at all caps, you should be having power on +/- of power transistors. can you check that?
Posted on Jan 19, 2009
  • 4,234 Answers
If this is the unit I think it is, then there is an amp pac inside marked STK0029. This part is probably defective. This will kick in the protection circuit and prevent the unit from powering up completely. This part is no longer available unfortunately. This was a good receiver in its day.
Dan
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Offhand, postback the brand and model.
Initially, with a continuity tester, determine the primary winding of the transformer (if it uses one). Determine if it is a multiple voltage version with selector switch. Trace the secondary to the diode/capacitor board and likewise check for the +/- voltages.
Alternately, if it uses SMPS, determine if there is DCV at the primary side and if there is standby +5VDC.
Pls post back result(s). Good luck and Thank you for using FixYa.
  • Louie  Role
    Louie Role Jan 25, 2009
    Glad that the Sony TA-AX295 is back in operation. We look forward to being of further assistance in the future.
    Sergeant:
  • 367 Answers
What is the brand and year and model of the amp?
  • Rob Houg
    Rob Houg Jan 19, 2009
    If the above solution from benimur doesn't help let us know.
My microwave shows nothing on display and will not turn on
see this causes and fix it. God bless you
First check is the main fuse of the unit. On countertop units, you will need to take the shell off. The fuse will be close to where the cord comes through into the unit. OTR units, this main fuse is usually behind the control panel or possibly behind the vent. Usually the fuse is obvious if blown, otherwise test with an OHM meter, if open, replace fuse.
Some brands will also have a thermal cut-off fuse in the incoming voltage line to the control board. Older Maytags and Samsungs have this fuse in it. This thermostat looking fuse is usually above the oven cavity somewhere under the outside shell. Sometimes you can get to it through the vent of OTR models. Test with an OHM meter, replace if open.
Sep 27, 2012 | Maytag Appliances Over-the-Range Microwave...
Has no power,
see the next steps: God bless your use the common sense, NOT feared.
No Lights or Power, Unit seems Dead First check is the main fuse of the unit. On countertop units, you will need to take the shell off. The fuse will be close to where the cord comes through into the unit. OTR units, this main fuse is usually behind the control panel or possibly behind the vent. Usually the fuse is obvious if blown, otherwise test with an OHM meter, if open, replace fuse.
see the block
Jul 31, 2012 | Amana ACO1520A Microwave Oven
My M4155sp stopped working. No power at all (yes, I checked the power source). Replaced the fuse behind the keypad, - still nothing. Any suggestions?
please see the next step: God bless you
see the diagram attached.
Jul 26, 2012 | Whirlpool MT4155SP Microwave Oven
I have a 2003 chevy s10 4.3 zr2 truck that died. I put a new fuel pump in and I get no noise to it when the key is turned on.
have you checked the fuse. and the grounds. check it has voltage to the pump using the live feed and the shell if you have power then its the earth wire. if you still have now power check the fuse, take out the fuse and check both side to see if there is voltage. if you have voltage but the fuse looks good. it could still be the fuse they can crack and look good but are not.
Feb 23, 2018 | Chevrolet S 10 Cars & Trucks
My cigarette lighter blows the fuse. I am replacing it. I have everything out but the lighter shell. What's the secret?
its a two part piece. unplug the power source to the unit, from behind the dash grab the shell and it unscrews off the inner piece that holds it to the dash.I use a needle nose pliar to hold the inner shell. If you have a new one unscrew the two pieces and it will help you understand the operation of it
Jan 27, 2011 | Ford F-250 Super Duty Cars & Trucks
I have a Samsung 40" lcd model LN40A53OP1FX2A
Could be,might not also,any things on the power supply board could be burn and dies,when it getting to much electricity current to it.Dead or dying capacitors on the power supply board are alway bulges or puffing up on it tops.Check the power supply board carefully look at all the capacitors parts,if require replacing,u must have tools like a soldering iron,a desoldering pump or a roll of desoldering braid,a roll of solders,also u must know basic soldering understand basic electronic to do it.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Dec 09, 2010 | Samsung LN40A530 40 in. LCD TV
1000 volt jump start placed incorrectly
Your system probably has a lot of relays and other electronics that are bad now. Your Electronic Control Unit (ECU) may be cooked as well. You may also have a fusable link that has been blown as well. The fusable link is basicly an in-line fuse that you have to replace the wire to replace the fuse. Get a wiring schematic and look to see if theres a fuse or similar that you misssed. You may find that you dont have power going to all or part of one of your fuse panels.
Hope this helps...
Sep 23, 2009 | 2002 Toyota Camry
Mine stereo will not turn on when i plug it in.
A blown fuse is a result of a failed component it electronic circuits. Replacing the fuse wont do no good. I fix television, and I wish I could show you how, but it has too many terminology, and rquires at least basic electronic understanding. Electronic device are the only thing a really good handy man can't fix. They are extremely complicated.
Jun 28, 2009 | Durabrand DU1901 TV
Dead printer?
I assume the transformer has 2 wires coming out of it. My guess is that the wire from the transformer is working however the wire leading from the Transformer to the printer is not.
You may need to purchase another power unit.
But on the bright side, a transformer is cheaper than a new printer.
Hope this helps.
Feb 15, 2008 | Computers & Internet
No power
You mentioned taking the "buttons" off. That may not give you complete access to the units motherboard or power supply area. Unplug the unit and remove the outside cover. Look for a blown fuse on the motherboard or power supply. Replace it with the EXACT value of the original fuse. You can purchase a new fuse at Radio Shack or hardware store or auto parts store. Try powering up the unit again and see if it works now or whether the fuse blows again. If it blows again, the power supply may have been damaged.
Jan 29, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
 Grubhead
Grubhead
