Question about Archos 605 WiFi Digital Media Player
Samsung tv - archos 605 s-video greyed out on tv
I have connected the archos with all the right cables but the s-video option is greyed out on the tv along with other options, the tv is an samsung LE32S86BDS .Anyone know how to activate this so it is not greyed out please as I can only record onto my archos in black and white.
Thanks so much.
    Problem Solver:
  • 6 Answers
This sounds like you have the cable at the Archos end plugged in the normal video output - you need to plug the round end of the cable into the round socket on the DVR
Posted on Jan 20, 2009
Having problems gettin sky channels through archos i get to setting infrared settings and can not get code.dont know wether to connect dvr t the tv or the sky box
Remove the DVR station from the box, and attach the DVR adapter plate (found in the
DEVICE box); it is correctly attached when it clicks on.
-Take the Black Audio/video Marked "output" cable, and insert the connections into the corresponding coloured sockets, yellow>yellow, green> green etc. Make sure they are
inserted into the TOP row on the back of the DVR Station "Marked Out". The remaining
black connector should be plugged into the SW socket, which can be found underneath
the orange socket on the back of the DVR station. (If after setting up your ARCHOS the
picture is very green remove the black cable from the SW socket)
-Plug the SCART connector into the SCART socket on your TV set. These are usually
marked AV1, AV2, or Ext 1, Ext 2, L1, L2, Line in 1, Line in 2, Aux 1, Aux 2, make sure you
select the corresponding channel above (ie AV1 AV2 etc) on your TV set when you turn on
the TV.
-Attach the UK plug adapter to the Mains charger, and plug the charger into the DC-In
socket on the back right of the DVR station. Turn the mains on at the socket.
-Insert the powered off ARCHOS unit onto the DVR station, the unit will now power on,
and ask if you want to 'Switch to TV out', select 'Okay'. The 'TV output configuration' set
up will load up. Select 'Okay'.
-TV connection: When your DEVICE is connected to the optional DVR Station you need to
select the type of video output (Composite, S-video, component, RGB, HDMI etc), based
on how you have connected the DVR Station to your TV and what possibilities your TV will
allow. For the cables supplied and the instructions aboce you will need to select either
RGB or Composite. Use the arrows to go through the options and select either RGB or
Composite.
-TV Standard: this should be set to PAL (Europe). Select 'Next'.
-Now you need to test the settings, select 'Okay', the ARCHOS home screen should now
be visible on your TV set. If you have nothing showing on your TV, scroll through the
AV/Ext channels, the channel will correspond to the AV/Ext socket you connected the
cable to on your TV set. Use the ARCHOS remote to select 'Okay'; you have now set up
the output connection settings for your DVR station.
-You may need to adjust your output from the ARCHOS to match your TV, from the "TV
Format" options. Use the arrows on the ARCHOS remote to select the format of your TV
screen, so the ARCHOS unit outputs the correct picture size (ie 4:3 / 16:9 etc). Use the
arrows on the remote to select 'Next'.
Dec 24, 2010 | Archos 605 WiFi Digital Media Player
Archos won't connect by USB to computers
You should keep your eye on the device after its been plugged to the PC it will give you 2 options "charge" or "usb" you ca not establish a connection without picking usb connection option on the Archos screen when it pops up. If you are doing so and problem still existed then i would recommend you to download the latest windows media player. Because it comes with new devices sync driver update.
Aug 10, 2009 | Archos 605 Wifi Portable Multimedia Player
605 not recognized by Windows Media Player 11.0
You may require a driver to work with your device. Try downloading driver from company's web site.
Jul 15, 2009 | Archos 605 WiFi Digital Media Player
Copying Video from archos 605 wifi to computer
I think the Archos 605 has a 2gb file limit, so the only option would be to split the avi.
Search on Google for an avi splitter - there are some free ones out there.
May 06, 2009 | Archos 605 WiFi Digital Media Player
Just got Archos 5 goes into error 101...
Hi there, these instructions are for the archos 705 but they are the same for the 605.
A) Download the firmware from Archos and save it to your desktop (Make sure the file name on the desktop hasn't changed from the original download file name)
B) The Archos 705:
1- Connect the unit to its power source.
2- Start the unit in recovery mode: Press the TV button first then the power on/off and keep pressing TV button (do not release it)
3- The recovery mode will start (the screen that asks for repair or format etc…)
4- Select "Repair" by scrolling up and down with the TV Button (it is all explained to move through the menu at the top of the Archos screen) (Do not press "Format" at any time)
5- Now that you are on "Repair" select it to validate your selection
6- The unit will go to "Plug the unit etc…" plug it with the USB cable to the computer
8- Wait until Pc should recognizes your Archos (around 5 seconds)
C) Computer
1- From your computer select the firmware file you downloaded from the net and put it in your Archos (in the root folder, nowhere else, where it has the folders, music, videos, pictures etc… as a file)
D) On the Archos 705:
1- Select "Ok" on the Archos (on & off button) shortly to select and confirm the file is now on the Archos
2- you are done! The Archos 705 should now read through the file you have transferred and repair the system
3- DO NOT DISCONNECT the power cable until the process is finished
4- When done safely disconnect (as you usually do, for Mac trash the letter of the Archos to the bin or for PC's: right click the green icon bottom right of the screen for xp & vista)
5- Press on/off button to reboot
Your unit should restart with a fresh repaired, updated system like day one.
Jan 21, 2009 | Archos 605 WiFi Digital Media Player
Archos 605wifi not switching on
Hi, my Archos 605 160GB is doing the same, Sorry to say the battery has gone.
2 options
1. Back to Archos
2. Replace the battery yourself I ordered mine from HK from the web site BatteryUpgrade. co. uk for about £24 - If you search on Utube there is a video showing you how to change the battery on smaller 605's
Jan 09, 2009 | Archos 605 WiFi Digital Media Player
I have an Archos 605 WiFi. I haven't yet connected my Archos docking station to the TV and HDD. Meanwhile, I thought I would copy a programme from the HDD to a DVD, then put the DVD in the computer and...
What kind of HDD do you have, do you have any type of output on it. You stated that you haven't connected the docking station to it and the TV...? The best thing to do is to connect your Archos to the Docking station. Set the docking station up correctly, with cables coming out of the HDD (if it has some sort of output) to the station and out of the station to your TV. Once you set that up, you can use the Archos as a mini DVR or VCR. Go to the REC option on the main screen of Archos, you'll have an option for Video Recorder (tab on top). If you play any source on the HDD, then all you have to do is press the Rec option on the Archos. If you already have a file on the HDD, then try just moving it over into the Archos once you connect the Docking station to your computer via USB or just use the USB cable connected to the computer with the HDD. I use the USB preference as Windows Media Device. (found under menu/settings/system). Is is basically a HDD itself. Remember the Archos will only play certain videos without the purchase of any extra plugins.
Good Luck
Apr 14, 2008 | Archos 605 WiFi Digital Media Player
ARCHOS 605 WiFi - 120GB TV guide problem
I had the same problem as you, after hours of browsing the frustrating archos website i simply deleted all the products from my account and then re-registered them. Turned out I'd simply put the serial number of my 605 incorrectly. Once re-registered, the tv-guide came up on my archos link software and updated it. Don't be too pleased though, when I did this about 98% of the channels just had "no information available" displayed on them on my Archos. Can anyone solve that?
Dec 27, 2007 | Archos 605 WiFi Digital Media Player
How do you put things on your archos?
connect the usb cable for your archos to a computer. it then should auto connect on your computer. from there, just copy paste anything you want to watch/listen to the appropriate folders. example: video (for tv & movies), music, etc
Dec 27, 2007 | Archos 605 Digital Media Player
Archos 605 30 gb
Yes you can download music from the net
No you can't use it as a word processor (not yet anyway)
Widgets are not yet available - they are due any time now
Check you have the output from the cable box to the input on the docking station and the output from the docking station to the input on the TV. Double check all your connections. If in doubt, rip them all out and start over. Once connected you will have to set the TV to one of the Aux channels to see the content and ensure you hit the TV button on the Archos to push the output to the TV.
Oct 03, 2007 | Archos 605 Digital Media Player
Archos 605 WiFi Digital Media Player Logo
197 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
 Grubhead
Grubhead
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
