Question about Kenmore 24 in. 16032 Built-in Dishwasher
No water pumping in to the washer
The cycle sounds like it is working .Is it a water pump??
    Sergeant:
  • 367 Answers
Unplug the washer and move out so you can take the back cover off then look for Broken belts.
Posted on Jan 19, 2009
  • Rob Houg
    Rob Houg Jan 19, 2009
    If you don't see broken belts then the issue would most likely be with the pump.
My Frigidare Affinity front load washer doesn't pump water on the Normal cycle.
Check the water inlet electro valve at the rear of the washer and make sure it is working.
Jul 25, 2017 | Frigidaire Washing Machines
I have an affinity washer and dryer. The last loand did not complete its cycle. It is partially full of water, but not enough to seap out. Itmakes a buzzing sound and will not spin. It is not the type of...
It sounds like the drain pump has stopped. If it still has water in it and you turn it on (in the spin only cycle) the drain pump should be running and you sould be hearing the water drain. The washer will not spin until the water is out. Depending on how handy you are determines whether you can access the drain pump and remove the obstrustion. There is also a trap to catch debries from going into the pump. This could be plugged, but normally you don't hear a buzz. You hear the drain pump working but no water going out. Good luck
Apr 23, 2011 | Frigidaire Affinity ATF7000E Front Load...
The washer floods at the end of the cycle the pump is working this i know because when i manualy lift the mushroom float it pumps out could it be that there is a membrane in the mushroom float that is...
I'm not entirely sure what you mean by "floods at the end of the cycle". Is water leaking from the washer and where from?
The mushroom float isn't a water level sensor to determine when the washer should pump out. It's a second level safety feature to prevent flooding if the washer overfills. The flow meter regulates the water level in the washer.
Your pump is obviously working and there is no blockage in the drain hose, etc as the water pumps out when you lift the mushroom float. It sounds like the pump isn't receiving a signal from the controller to pump out at the end of the wash cycle. Lifting the float bypasses the controller and runs the drain pump.
Please try the following simple test:
1. Switch the programme selector to "Off"
2. Empty a bucket of water into the bottom of the washer
3. Turn the programme selector to any wash cycle
4. Press and hold the Reset button (start/stop) for at least 3 seconds. The washer should drain.
Please try this test and let me know if the washer pumps out. Please can you also be a little more specific about how and where the washer is flooding.
Thanks,
BElectric
Mar 17, 2011 | Bosch 24 in. SGS43C12 Classixx...
Whrilpool modle #lsq9544kq0 washer works in
Humming could mean a stalled motor. These machines also have a coupling between motor and gearbox which can fail. However, the pump is attached to the motor, so if it's not pumping it probably means the motor isn't spinning. Check motor and/or gearbox.....Nomess
Apr 18, 2010 | Whirlpool LSQ9544K Top Load Washer
I m using maytag pav2200agw after fill the water washer is working fine but during the spin dry cycle water pump does pump out the water and start spin but the tub is not moving its not working propperly...
I WISH I HAD SOME ANSWERS ON THIS ONE, BUT IT SOUNDS LIKE YOUR PUMP MIGHT NEED REPLACING. HOW OLD IS YOUR WASHER? IT WOULD BE CHEAPER TO BUY A NEW WASHER. BUT IF IT IS THE PUMP, THEN YOU CAN BUY A NEW PUMP FROM WHERE YOU BOUGHT YOUR WASHER. GOOD LUCK.
RODNEY
May 12, 2009 | Maytag PAV2300 Top Load Washer
Doesn't spin all the water out
sounds like the coupler that connects the motor to the transmission is going bad.  A $20 part
Mar 30, 2009 | Kenmore 24902 Top Load Washer
Won't pump out water at the end of wash or rinse cycle.
I don't know this model at all, but hada similar set of syptoms on an electrolux .....
Just a thought, but have you checked the pump chanber is not impeded by a stray hairgrip, or bit of wire?
The fact it doesn't pump when it should, but allows water to pass when the centrifugal force of a spin cycle builds up, would indicate that maybe its the pump that either has a jammed impeller, or a blown motor (or fuse).
Feb 15, 2009 | Kenmore 23822 Top Load Washer
GE toploader Washing Machine pumping problems
Sounds like the water is syphoning away due to the drain outlet hose being too low..Raise the hose higher, and this should solve the poroblem.
Oct 31, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Washer fills/agitates and stops prior to draining
If pump works fine or still pumps out water, then it is a timer malfunction. Replace the timer and you should be fine. To locate a part number for your timer, refer to www3.sears.com with the model number off your washer.
Mar 14, 2008 | Kenmore 24032\24036 Top Load Washer
Water not pumping out and spin cycle not working.
it sounds like you have something obstructing the pump. does the machine eventually empty? or does it remain with water in it. you need to remove the hose that leads from the tub to the pump and clear any debris. if you continue to run with debris in the pump you could burn out the pump motor
Jul 02, 2007 | Kenmore 44072 Front Load Washer
Kenmore 24 in. 16032 Built-in Dishwasher Logo
61 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
