Question about Dishwashers
We have a Hobart FXS 70N Dishwasher and it gives us a F04 error code. What does it mean and how can it be fixed? Where can we also get a wiring diagram for it? Thanks Engela
  • 4 Answers
SOURCE: indesit evolution de 73 dishwasher with an AO5 error code
a05 is pressure switch not reset. check for blockages in the drain pump, filters and sump
Posted on Jul 28, 2007
bigg t
  • 640 Answers
SOURCE: what is p3 code on hobart am15 dishwasher
It means that the final rinse thermistor is bad.Your not getting 180 degrees---right?Its located on the booster and costs about $65.I work for hobart.Any ?
Posted on Jan 25, 2009
SOURCE: hobart amx/aux-s dishwasher "bof" error code
press the 1st and third buttons on the display nxt to the start button then press the start button,this will change the the display to something like BOF1 then allow the achine to fill the rinse tank you will know when this has happened as the display will go out (all of it) then you can turn on the machine using the button marked with a I the start button will light red allow it to go green and you are ready to go ... if when you are boffing it it changes to FIL the your water pressure is to low good luc fella
Posted on Mar 04, 2009
  • 109 Answers
SOURCE: Hobart dishwasher model LX30H; displays wrench and E4.
Water is not to top sensor in alotted time.
Top sensor is in right rear corner, and is the upper of the two. Check the connector to the probe on the outside at the back. (sometimes gets wet fro vacuum breaker leaking when dirty or low flow pressure. Machine needs 20 psi flow rate
Posted on Aug 14, 2009
  • 1420 Answers
SOURCE: HOBART FX-20 dishwasher out of order
There is one glued to the lower panel on the inside. Hobart is very tight lip'd when it comes to getting any info from their web site. Best I can do, sorry.
Posted on Jan 25, 2010
I got a Hobart am900 dishwasher, and is giving error F04------1, I had changed the pressure transmitter, but still this error code appears on the display. Can you please help me fix this?
Presuming the code took you straight to the sensor so congrats on R&R??.
Where was the sensor and what pressure is it reading?
I'm a big fan of thorough DW cleaning and have found most problems relate to debris accumulation in water level sensor systems or under the cover at the bottom of the tub.
what else's can you share on your problem?
Oct 24, 2016 | Dishwashers
I have a Panasonic NV-VP60GL, it has repeatedly come up with error code f04. From what I've been advised this is to do with the loading motor. I replaced said motor and still get problem. Help please?
F04 actually just means the mechanism locks during unload. The load motor can indeed cause this, but it can be working fine, but the timing might be out. This could be something to do with the mechanical parts of the mechanism. You should examine it for broken or worn plastic parts.
Mar 19, 2015 | Panasonic Televison & Video
Panasonic deck ag dv2000 gives error code f09
Your vcr seems to use the K Mech. F04 Means that the mechanism locks unloading.
The cause of which might be the loading motor timing.
F09 means No serial clock linking IC2004, IC7005 and IC7701.
Apr 29, 2009 | Panasonic AG-DV2000 Mini DV VCR
E-2 Error on LX30 Hobart Dishwasher
E-2 error is a fill problem. Water did not reach the lower probe within the time out. (innitial fill only
1- Is the bottom probe clean?
2- No fill water (check valve, hose,fill screen in end of hose, and fill source.)
3- low water pressure, should be 20 PSI flow.
4- Fuse 1FU blown.
5- Check wiring to fill valve.
6- Check relay board function.
Feb 15, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Error code E2 (with a picture of a wrench)
E2 means a problem with the fill. The wrench means to contact Hobart for service
Feb 27, 2008 | Hobart 29 in. AM15-1 Free-Standing...
Hobart dishwaser
hi,i just read your a hobart service tech and fix these units all the time.what model do you have and are you sure the error is bof?let me know,i can tell you all the info,error codes about hobart dishwashers.
Jan 14, 2008 | Dishwashers
Dishwashers Logo
491 people viewed this question
Top Dishwashers Experts
