Question about Keys Fitness Ht502 Treadmill Motor Controller- Great Deal
Motor hot and smells - Keys Fitness Ht502 Treadmill Motor Controller- Great Deal
    Top Expert:
  • Keys Fitness Master
  • 12,223 Answers
Step 1:
Please LUBE the deck belt+rollers bearing INMEDIATELY and proceed according see the video attached.God bless you
Step 2:
test the motor drive belt for loose
+ test the input voltage motor and see my personal TIPS for motor help.
Step 3:
test the output voltage board, for input voltage motor, if there are NOT the board is faulty. see the block diagram attached. use the VOltmeter.
Posted on Jan 04, 2013
I have a 2002 Mitsubishi Diamante the coolant fan will not come on. The gage says it isn't hot but it smells hot. What could be the problem ?
check fuses and relays -engines smells hot [all engines put out heat and smell hot ]could be nothing the engine could be running correctly or test the temperature sensor ,fan motors and fan circuit --if smells hot because of leak look for leak have coolant system pressure tested
Oct 15, 2016 | Mitsubishi Cars & Trucks
Just bought wine cooler on line from Costco, December 1, 2014 and delivered December 4, 2014, uncrated and plugged in December 5, 2014.....unit motor runs hot as can be and top of cooler hot to touch.
Compressors run hot and are cooled by the cold gas returning to motor via suction line. If top of unit is hot it is because your condenser, (part that gets rid of heat collected from inside) is up there doing its thing. If it draws excessive current the built in clixon will shut down juice to motor. The smell is just the paint and after a while it will disappear.
Sep 09, 2017 | Furniture
Why does my maytag dryer when turned on get red hot instantly, yet the motor only humms?
quit buying parts ur motor is shot and u should be or soon be smelling a wireish burning smell.
Oct 08, 2014 | Maytag Dryers
My dyson DC50 smells when hoovering
many things can make it smell bad wash filter top and lower in hot soapy water and rise well and dry well in sun
wash bin and all it's parts in hot soapy water and dry well
clean brush roll and check for any bad smells in head
could be from motor over heating or near to failing if above does not get rid of smell i would say it's the motor
May 31, 2014 | Dyson DC17 Animal Bagless Upright Cyclonic...
Fluctuating speed
With the motor being new and the "hot electrical" smell, I would say the motor control board, which sends the speed command to the motor, would most likely be your issue.
Apr 03, 2014 | Proform XP 580 Trainer Treadmill
Avv8000agw slow spin and smelly
First of all check if the motor is hot or there is friction on the drive. Since you had noticed some smell then the best option is to trace the smell which must confirm the case. It could be the motor or possible capacitor or within the power supply or drive output.
Jul 03, 2012 | Admiral AW22 Top Load Washer
Model number WDSR2080G3WW. GE Top Loading Washing machine will not spin. It fills, agitates and drains but does not spin. Lid switch engages, motor tries to start the spin it won't spin, so the motor...
The reason for the hot smell must be investigated. If it is the motor that is getting hot it won't be a new motor for very long. The hot smell might be coming from a drive belt or a clutch and there could be a brake mechanism that is binding or not fully releasing.
Clearly the next step is to closely observe the operation of the mechanical parts...
Sep 15, 2017 | Washing Machines
My rotating brushes stopped rotating and my steam vac smells hot...is it a belt?
the hot smell makes me thing the motor is stuck
do not attempt to use it unless you can rotate the motor by hand. If the motor spins freely then it could be a belt. check if the belt turns
Feb 02, 2010 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Acrid electric smelling smoke pouring out of machine when pumping down wash water. motor feels hot to touch.
If you are not overloading the machine, and the front of the motor is pretty hot, then it is going bad. If it smells like rubber, it is the belt.
Jan 14, 2010 | Amana DLW330RA Top Load Washer
Keys Fitness Ht502 Treadmill Motor Controller- Great Deal Logo
76 people viewed this question
Top Keys Fitness Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a Keys Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
