I have a acer aspire x1200 started boot over and over and wont start at all now
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 52 Answers
Did you change anything in your BIOS? If not, it's mostlikely an Har drive issue
Posted on Jan 03, 2013
MATRIX_MMX
  • 209 Answers
SOURCE: acer aspire not booting up
Dear f1at3r1c
Righteo then, you should be starting by resetting your BIOS, and you can do this by removing the outer casing o the PC tower. Once yoiu have done this you then need to find the jumper that clears the CMOS/ BIOS. Now if you are somewhat unsure of what a jumper switch is, it just consists of a smallplatic cap which covers two metal conductive pins on the motherboard. There is usually a pin which is not covered.
Now once you have found the CMOS/ BIOS jumper setting, you will need to first remove the motherboard battery. The battery is nothing more than a glorified watch battery of the CR2032 type, and it will be silver in colour and obviously round in shape (typical cell battery).
Once you have removed the battery, you will need to then clear the CMOS/ BIOS and this is done by moving that jumper switch into the clear position. The pin that is exposed will need to be covered withthe plastic jumper, and the pin on the opposite side will need to be exposed. Leave the jumper in the clear position for about 10-20 seconds or so, and then replace it back to the original position. (doing this discharges all of the electricity in the BIOS/ CMOS chip). Once you have done this, you put the battery back in place and then start the machine, then you are good to go. Start the machine and enter the BIOS as you planned to do. You might want to consider ormatting your hard disk and re-installing windows or whatever operating system you have, and this is eeasy enough, just change the boot sequence to boot from your CD/ DVD drive first, the your hard drive second. Once its loaded up, re-enter the BIOS and reset it back to HDD first.
Now f this has not worked, then you have an oooopsie (this is my saying of oh ***T, oops, something has malfunctioned. Its more than likely to be hardware driven, so take out your hard drive first and try to boot, if it lets you bios, then you found your fault. Try this with all devices until you either find the fault, or you have narrowed this to your processor/ motherboard.
Now im sure this will solve your problem, but there is one thng you should need to know about, and it is how to identify the correct jumper. This will have either any of the following markings written on the motherboard very close to the where the jumper is. You may need glasses/ magnifyer lens in order to read the lettering, but it should say one of the following things.
CLRCMOS
CLCMOS
CLRBIOS
CMOSRST
RESET
CMOSRT
BIOSRST
CMOSCLR
CLEAR
could also be under J1, JUMPER1
Now im sure that this is the fixya for you, but if this still does not work, then please get hold of me, and i will provide you with more info.
I wish you all the best, and hope you manage to solve this issue sortly
kind regards
yours sincerely
Oz
Posted on May 11, 2008
  • 10 Answers
SOURCE: trying to start up an acer aspire T180
can you tap F8 while it is booting and start in safemode or select boot with last good know configuration?
Posted on Jun 11, 2009
SOURCE: How can I find a replacement power supply for my
you can buy a power supply in ebay or amazon.. remember find the spaficication of the power supply and you can put a generic.. its more cheaper... with the same spec of your machine
http://shop.ebay.com/i.html?_nkw=Desktop+power+supply&_sacat=0&_trksid=p3286.m270.l1313&_odkw=Acer+X1200&_osacat=0
pls click if my solution was helpful
Posted on Dec 28, 2009
Testimonial: "thanks will check it out"
  • 5 Answers
SOURCE: acer aspire m3201 wont boot up
There are numerous issues that could cause this but if absolutely nothing happens, no lights, no fans, nothing then check the power supply. Use a simple voltage tester to see if you have any voltage on the connectors going to the hard drive and cd/dvd drives. If not this is a pretty easy and relatively inexpensive fix. You can e-mail me at globalmac@yahoo.com for more help.
Posted on Jan 02, 2010
fanaudi
  • 1381 Answers
SOURCE: How do I restore Acer Aspire x1200 without disc?
Hi dustinwilkin From http://www.geekpolice.net/t7449-acer-system-recovery-partition-hotkey-instructions-erecovery : To access the recovery partition on your Acer computer for recovery, follow the steps listed below.
1. Power on the computer
2. At the white ACER BIOS screen, hold the Alt key and press the F10 key simultaneously to start Acer eRecovery.
3. Once eRecovery has loaded, click Restore to Factory Default Settings
4. Click OK to continue
5. From here, the eRecovery process will update all the data on the C: drive and restore a fully functional factory image (approximately 10 minutes).
6. Once eRecovery has run, press OK to reboot unit
Note that all data will be lost during this process and your computer will be brought back to it's original factory state and settings. Best regards , fanaudi .
Posted on Sep 29, 2011
Aspire x1200 coprocesor
Acer Aspire X1200 Drivers Coprocessor Downloads
https://user-guides.co/downloads/coprocessor-drivers-acer-aspire-x1200.html
check the above link for the respective driver for your device. If it is not the driver that you need please repost the query with further elucidation of the matter.
Sep 17, 2015 | Computers & Internet
How do i do a blind flash bios in acer aspire x1200
The PS (Power Supply) probably shorted out from a surge. Repair or replace.
Sep 26, 2012 | Acer Aspire X1200 Desktop PC - Athlon X2...
My acer aspire X1200 b601a wont boot past first POST screen, ive tried reseating the CMOS, but seems to have made it worse. it contains all original parts, though take into account that it was FACTORY...
IF the machine is just shutting down it's likely the power supply. If it's constantlly rebooting itself, it's a corrupt bootlog. If the machine is just "freezing" when it tries to boot, it's likely motherboard related.
Oct 09, 2011 | Acer Aspire X1200-B1601A PC Desktop
Here's what I do in a case like this:
Disconnect everything but the CPU, memory, and video (and keyboard) to see if it will boot. Many time one of your components has gone bad and will keep the system from booting. My money goes on the CD/DVD.
If it does boot, add in the hard drive and then the CD/DVD. If you have 2 sticks of memory, you can try each separately.
Sep 22, 2011 | Acer Aspire X1200-B1601A PC Desktop
My Acer Aspire x1200 desktop is giving me this message after booting: "BOOTMGR is compressed Press Ctrl+Alt+Del to restart" After restarting it gives me the same message again. I don't have...
Please follow the following steps to solve this problem.
  • Insert your OS cd in the CD/DVD Drive.
  • Go to the DOS Window and enter the drive where Windows is installed (normally C:/)
  • Type bootrec /FixMbr
  • Type bootrec /fixboot
  • Type bootrec /rebuildbcd
  • Now type Exit and then restart the computer.
Please make sure to enter these commands in the order indicated and the problem should be solved.
Hope this post helps you.
Jul 06, 2011 | Acer Aspire X1200 Desktop PC - Athlon X2...
Acer Aspire X1700 Desktop Wont Start up Shut down with blue Protection screen
That's Blue Screen of Death. Start up ur pc in safemode by pressing F8 key while booting and uninstall any recent hardware or software installations. Or try System Restore to an earlier date. If u failed to boot up ur pc even in Safemode, make a clean and fresh OS installation.
Jul 28, 2010 | Acer Aspire X1200 Desktop PC - Athlon X2...
My internet wont work anymore because i downloaded an update ( Windows home premium) on my acer x1200 I want to wipe / recover my computer to its original facttory settings but ive tried everything. I dont...
Click: Start
Click: All Programs
Click: Accessories
Click: System Tools
Click: System Restore
Pick a "restore-point" that was taken _before_ the update was applied,
and restore your system to that previous date/time.
OR ....
Look under "All Programs" for a utility that will help you burn CD/DVD(s) to create a "Recovery Disk" set. Burn more CD/DVD(s) with all your "data" files (or copy all your data-files to an external hard-drive). Then, boot from the "Recovery Disk", to begin the process of restoring the "factory" settings.
Sep 10, 2009 | Acer Aspire X1200 Desktop PC - Athlon X2...
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
