Question about Saws
Users manual Skil 4395 TYPE 1 (F012439500) Jig Saw
rowdy45176
  • 2176 Answers
SOURCE: manual
for Dave, go to BoschTools.com and then to the Product Services area on the left side click on it and it will take you to an area where you can get a manual and breakdown for this tool. Hope this helps
Posted on Dec 25, 2008
efs_perpends
  • 1996 Answers
SOURCE: BLADE CHANGING
What's the model number of that saw?
If it's one of the old ones, a 1581 VS or some such, you need a long thin flat-head screw driver that fits through the hole in the top of the handle and reaches down far enough to unscrew (loosen it) the set screw that holds the blade locked in place. Then you twist the blade 90 degrees (perpendicular to the direction of cut), and pull it out. Reverse process for installation, making sure before you tighten the blade it rides in the groove on the guide bearing below.
If that doesn't seem like it's the correct sequence for your saw I apologize.
The Bosch website won't accept any 10 digit tool product numbers due to some glitch in the system, and they made so many variations on that saw it'd make your head spin.
That's the other way some of them loosen up, actually, is by pulliing up the plastic head at the top of the handle and unscrewing it a few turns to loosen the blade.,, Vice versa for install..
Hope this helps a bit!
Posted on Mar 28, 2009
SOURCE: Instruction manual for Bosch Jig Saw 1587AVS
http://mdm.boschwebservices.com/MDMCache/English%20[US]/t10/0000000/r00061v-1.pdf
This is the Owner's Manual for the Bosch 1587AVS Jigsaw.
Posted on Jun 24, 2009
SOURCE: Do you know where I can download a manual for this?Thanks,Dave.
Hi Dave, Try the Bosch site at http://www.bosch-pt.com/boptmanuals/gb/en/index.jsp;jsessionid=CD238E0C373D87F9C2693A38909E1782.s035?
Thats where i found mine.
Posted on Jul 13, 2009
brewerstool
  • 141 Answers
SOURCE: jig saw model 7580 type 4, replacement for blade clamp
There is no model 7580 Jigsaw. The only model close to that I can see would be the 7588 Type 4. Unfortunately that part is unavailable for this model. You may want to contact your local Dewalt service center and see if there is a substitute for that part.
Posted on Sep 12, 2009
Missing skil jigsaw set screw
This will be a generic METRIC screw, take it to a fastener supplier and show them the hole, they can try out fit of a few METRIC screws to find the right size. Buy the screw/bolt that fits and hacksaw the head off it to make a set screw.
Nov 25, 2013 | Skil Standard Duty Jigsaw Model 497 1/3 Hp
How do you change a blade on a Skil 4280 jig saw?
It is REALLY easy, when you know how. There is a black piece, the larger one, near blade insert...lift it and VOILA, you can insert or remove blade easily. I lost manual and spent forever trying to put blade in. Hope this helps.
Sep 22, 2013 | Skil 4280-01 4280 Variable Speed Jigsaw...
Model JS250Q type 1 Skil Saw - cannot seem to get the blade to stay in and cannot find the manual - could you possibly send a pic of the clamping mechanism?
product diagram is at this link;http://www.ereplacementparts.com/black-and-decker-js250q-type-variable-speed-jig-saw-parts-c-4167_4262_11752.html. I suggest you remove the screw you use to tighten the assembly, install your blade and if there is a hole in the blade, try to visually line up that hole with the screw hole. Generally ,that screw has a nose that will pass the blade first, then tighten the clamping mechanism.
Aug 03, 2011 | Garden
Need to know how to put blade in
Just pull up on that rectangle shaped black piece on the top of the blade. Then pull the blade out. You can use both type blades in this model. take care and good luck.
Mar 08, 2011 | Skil 468004 5 Amp Jig Saw Kit with Laser
Blade broken down in jig saw
This may sound to simple and not mean to be funny or insulting but why can,t you just take the screw out that holds the blade in you would have to do this when ever you needed to replace or change to a different blade Idon,t know mabey im missing something that your trying to say im not sure
Dec 04, 2010 | Skil 449501 6 Amp Jig Saw
Broken blade inside jig saw. How to remove?
what type do you have?? is it a easy in or do you need an allen key to install and remove either way if you can hold it open try a tip of a nail file to wiggle it out or there should be an allen key or screw to remove the front its very small that will allow you to remove the broken piece....happens to me alot
hope i was a help
Dec 04, 2010 | Skil Saws
It's actually a Skil model 4280 sabre saw. Problem is it doesn't grip blades properly, so they are constantly slipping out. Chuck seems to be engaged, have shot WD-40 in it - no change. Ideas?
There is nothing wrong with your Skil 4280. The universal U chuck blade is the problem. Look at Lenox blade 4318JC or Disston 5418 and you will see a slight ridge on the face of the blade on both sides where the teeth start and the blade tail engages the chuck. Without the ridge the blade will come out.
Oct 05, 2010 | Bosch Skil No.4280 - 01Variable Speed Jig...
Need to know the type of oil that the skilsaw 7 1/4'' mag 77 use
skil recommends using their lube 80111 for an 8 oz tube or 80112 for a pint. however any good quality worm drive lube will work. Don't use a gear lube because the worm drive has additives for anti foaming and gear wear added. Let me know if you need more help
Nov 17, 2009 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
Saws Logo
121 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
