I have my Lg front loader washing machine,inverter direct drive 5 kg,F8068LDP.when I press on the temp control is warning and the other control or when I turn to washing its is not functioning. what Should I do?
  • 210 Answers
SOURCE: LG WM-1280 DD front loading washing machine
When the unit is off, open the door and spin the drum, does the noise occur? If the answer is no then there is nothing wrong with the bearings. Chances are the hall sensor on the motor is on the way out. Call for service and ask them to replace it. Make sure you are using a "HE" branded detergent,,,, less is best.
Sgt 48
Posted on May 31, 2008
  • 1314 Answers
SOURCE: washing machine dosnt spin dry,
remove the front panel and check for obstructions in the drain pump also on some models there is a catch screen in the tub to pump hose if you have a shop vac pull the water out of the drain hose first as there will be water in the unit
Posted on Jun 03, 2008
  • 4 Answers
SOURCE: bosch front loader washing machine water pump?
Always check to see if the water waste (located normally at bottom right) has no foreign objects in their such as bobby pins, coins etc It has happened to me 3 times (first time cost me $150)
Posted on Jun 16, 2009
jan mczeal
  • 632 Answers
SOURCE: lg tromm front loader washing machine display panel reading l-E.
error code 'IE' means water does not enter the detergent drawer..if your water is hard or contains traces of lime deposits, the water inlet filter may become clogged..regular cleaning is suggested..clean the filter using hard bristle brush..
note: hard water is the one not undergone any treatment..in other words it is directly from the ground through your water pump and to the washer.
Posted on Jul 19, 2009
DirtyOldGit
  • 5 Answers
SOURCE: what is the AE error code on LG steam direct drive washing machin
the AE code means that there is water in the base I found that the steam heater element in mine was leaking so after a quick repair using silicon and a good clean after drying the water out of the base it now works again
PS I used to be a washing machine repair engineer! I wouldn't suggest that you start opening up your washing machine!!!!
Posted on Mar 31, 2010
Hi my LG 7.5 kg (10165fu)front loader washer has just stopped functioning. It shows on screen a big "CL".What do i do? Pls help. Griffiths
CL means that your washing machine's CHILD LOCK is ON. You can find two buttons Temp and Options in the panel. Turn ON the machine, press these two buttons together for 3 seconds and thats it. It might have a little kids face above a lock key, inbetween the wash and rinse buttons, hold these for 3/5 seconds and it should work
Dec 03, 2016 | LG Washing Machines
It only wash & don't spin? Then it stops and leak water by the door....
LG Washer & Dryer 7 (WD12331AD)
Its is a direct drive front loader with 7kg capacity for washing and 3.5kg capacity for drying.
when new
thats 7 kg with wet clothes and water
and only 3.5 kg wet clothes to dry
the older it gets the less weight it can wash and dry
worn motor or drum overload if it doesnt want to spin at all
leak at the door . replace the door seal ..is a most common fix
extra info
It has 9 preset settings, 400 - 1200 RPM, 5 temperature settings, digital display and delayed start timer.
Sep 20, 2016 | LG Washing Machines
I have a front loader LG inverter direct drive
The water temp switch only determines weather THE MACHINE WILL USE cold or hot water. The real culprit sounds like the inlet water valve? change hoses from hot and cold and see if there are any significant changes in temperature. Another culprit may be ur motor control board, on front loads more of an issue.
Oct 03, 2014 | Washing Machines
How do you operate a lg inverter direct drive washer
it a procedure,read it manual........................or power on nd press the play botton ,,,,everything will operate itself automatically
Sep 04, 2014 | LG WD-1070QDP 7 Kg Direct Drive Washer
LG Inverter Direct Drive 7.5kg Front loader WD12020D
purchase a couple of washing machine cleaners from a local supermarket or homeware store. there will be on the console two buttons with a * next to them, turn the machine on and press both these buttons. the machine will display "tcl" normally, insert 1 cleaner into the drawer where detergent goes and press start. run a couple of times to make sure it has all flushed through
Apr 10, 2014 | Washing Machines
Lg Washing Machine Manualmy washing machines just started coming up with 1E in the display part what does that mean.. i have a lg direct drive 7.5 kg front loader, WD12020D
there is a problem in water inlet valve.....first turn off the water tap.then remove water inlet hose from washer end.after that see the inside of the valve.there is a small water filter in the valve.....take it out it using plier ...then clean it wel....now replace it correctly....now your problem will ok
Jun 02, 2013 | LG Washing Machines
LG WD12020D Inverter Direct Drive 7.5kg front loader. Has never had visible water level in the drum. I have even stopped the machine, turned off the power, waited for the door to unlock, pushed the wet...
No water that high. But you may have an extra water button that allows you to add slightly more water to each wash load. Water should be just above bottom of inside drum in the back of the drum as it rotates
Jul 01, 2017 | LG Washing Machines
Hi i want to know that a waight of 6 kg washing maching is a small one for cloths or it is ok . should i go for more than 6 kg. for 4-5 persons family. thanks.i just choose a whirlpool compact model of...
Your question is not easy to answer. An average washing machine is 8 kg. The smaller 6 kg will use less water and detergent, but you will be limited to 4 or 5 pair of jeans at one time...unless your children are small. A front loading machine may be a better choice for you. It can do very large loads, 12 kg, and still use less water and detergent than most top loaders, but be prepared to pay three times the price of a top loader.
Sep 20, 2010 | Whirlpool Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
