My HP 2840 color laserjet does not recognize HP toner cartridges
Since using some refurb toner cartridges my HP 2840 Color laserjet will not recognize any new toner cartridges. The display simply shows a question mark ('?'') in the display area where the toner cartridge fill level is normally displayed. I have tried authentic HP toner cartridges and it still won't recognize the toner cartridge.
  • wallers Apr 12, 2009
    same issue - id you ever get it resolved?
  • jolanda90 May 06, 2009
    My HP 2840 stopped recognizing Non-original HP toner cartridges 2 months ago.
    I Guess HP sent a 'update' which now refuses to recognize . Even new nonHP cartridges are not recognized. Hp orginals are recognized. Cause is in the NOn HP chip attached on the top at the right side.
    I'll try to downgrade the firmware and let you know.
    Marcel.
MUKHTAR
  • 2022 Answers
SOURCE: HP LaserJet 2840. "Install Yellow
make sure toner is not refilled just remove the toner and shake it and then install it again.
Posted on Dec 04, 2009
IB4G2008
  • 3587 Answers
SOURCE: toner marks down right side of page
hmmm...sounds like your toner cartridge is truly unhappy. I'd return it if I were you.
no worries..start by getting new driver for that here
Posted on Feb 28, 2008
SOURCE: HP OfficeJet G85
If its not recognizing the cartridge you probably need to go inside and clean the contacts. Best thing to use is ordinary rubbing alcohol but you should also get a can of dry air from best buy or similar place to blow out any areas you can reach. If you need instructions on how to take the machine apart email me at sanglemyer36@yahoo.com
Posted on Mar 05, 2008
  • 59 Answers
SOURCE: Out of toner........ but not really.....
You can also navigate through the menu and go into toner override mode. That allows you to print without being bothered by low/empty toner messages
Posted on Mar 11, 2008
jmassengill
  • 345 Answers
SOURCE: The printer doesn't recognize the new original HP color cartridge
There is a small spring that holds the ink cartridge in the ink holder. You will see it stick out from the right hand side of the ink holder where the ink cartridge slides in. If that spring isn't being held to the ink holder by two plastic tabs, (I.E. the plastic tabs are broken) the printer will never recognize the cartridge. If the printer is still under warranty I would contact HP or an authorized repair center for HP. Both the black and color ink holder has this spring. I know of no way to repair this kind of breakage.
Posted on Jan 08, 2009
My printer Hp Color laserjet 2840 is given an Incorrect yellow initially, after i bought the catridge it is telling me of 52.4 error how to go about it.
Take the cartridge out and reseat it. If you bought a compatible toner I would order an OEM HP brand toner. These machines don't work well with compatibles.
Jan 20, 2017 | HP LaserJet 2840 Printer
I installed an original Q3971A toner into the HP 2840 laser printer, However there is still a notice to install cyan catridge. Can you help please
PDF]HP Color LaserJet 2840 and 2820 All-in-One for small and ...
h10010.www1.hp.com/wwpc/.../clj2820_clj2840_bro.p...
Hewlett?PackardColour laser printing. HP Color LaserJet ... •Convert hardcopy documents into digital format for easy ... Color LaserJet 2820 All-in-One gives you high quality, ... Oth ring. Why HP. Save time. Printing a file. Printing a paper fax. Receiving a .... Install, configure and manage multiple networked ... Replace toner cartridges easily.
HP Environment: Product Safety Information - LaserJet ...
Dec 18, 2015 | HP LaserJet 2840 All-In-One Printer
Hp color laserjet 1025 cartridge memory error on imaging drum
If the ground spring located on the left inside wall of the printer is ok, and you have tried cleaning all the ground contacts on the cartridge, then it may just be a bad toner cartridge. Especially if it's a third party cartridge and/or especially if this problem happened right after or shortly after installing a new cartridge.
Jan 19, 2015 | HP RB3-1025 Hewlett-Packard Color Laserjet...
How can I override the calibrating mode on A HP LaserJet 2840 All-In-One printer. My black toner is out and it would not print any documents, keep saying replace toner can I override this until I purchase...
You Cannot override, as the black cartridge is required for all print functions. Both B/w and Color use the black, obviously in smaller amounts in color, but it still requires it none the less. Sorry, I know you were hoping to trick the printer somehow, but with HP printers it's not an option, especially on the Laser Printer models like yours.
Dec 15, 2010 | HP LaserJet 2840 All-In-One Printer
HP Laserjet 2840 asked for drum replacment afther only 5300 pages but should make 20000. Prits where still perfect but now it refuses to print. Any solutions how to keep using the drum?
Check online for refill instructions and where to buy the chip to replace on the drum, most of the drums today have little chips to replace that tell the printer when they are used up, even when there's still life in them.
Dec 24, 2009 | HP LaserJet 2840 Printer
I have an HP color laserjet 2840 and just replace the drum not long ago, maybe back in the spring, and changed all the colour cartridges in the summer, now it's saying to replace the drum again, the...
The HP Color Laserjet 2840 Is a Very Good Reliable Printer. I'm curious if you are buying American made components or cheap components from some thrid world country sold at ahuge retailer. They really should stand behind their laser drums, but if they don't then shop over at www.officeinks.com or www.wowsuperdeal.com and Purchase American Made Toner Cartridges and Laser Drums. Office Inks has a 1 year satisfaction and quality guarantee and free return shipping if their ink, toner, drums, ribbons etc, don't make you happy. Only Ships USA Though.
Oct 15, 2009 | HP LaserJet 2840 All-In-One Printer
Incorrect yellow of HP laserjet 2840
Turn off the printer and open the cover and manually rotate the assembly for the toner.
Jun 24, 2009 | HP LaserJet 2840 All-In-One Printer
HP Color Laserjet 2840 refill problem
It may be that the cartridges are the problem? Usual fix is to go back to before the problem and start again. If you don't have old good cartridges, you may have to get new cartridges.
Feb 15, 2009 | HP Color LaserJet 2550n printer + HP Color...
HP color jet 2840 cartridge not recognize
Turn the printer off and turn it back on again and see if happens now.
Jul 12, 2008 | HP Color LaserJet 2600n Printer
Replace Cathridge
The front panel tells you witch toner cartridge should you replace. If a supply memory error ocures then the cartridge should be replaced or exchanged with a new one. The imaging drum unit is also consumable. for "Joe 50" - there are 4 toner cartridges in the printer.
Dec 28, 2007 | HP LaserJet 2840 Printer
1,515 people viewed this question
jasbo
jasbo
