Question about Riccar 8850 Vacuum
I cannot get the cover off of the hepa filter compartment - can I safely pry it off with tools
  • Riccar Master
  • 18,402 Answers
Yes if you use a flat head screwdriver and pry it off gently cant see you doing any harm,,the link below is the manual
http://www.riccar.com/ftp/whitepapers/8000_Owners_Manual.pdf
Posted on Jan 03, 2013
  • conollyd
    conollyd Jan 05, 2013
    Was successful -thanks so much
Why cant i keep my hepa filter and cover on my new navigator?? help?
Are you sure that you are correctly connecting the filter, and flipping the tabs to "lock" it into the "closed" position.
Jun 13, 2014 | Shark Navigator Bagless Upright Vacuum
How do I clean and with what,a Hoover elite lifetime hepa filter?
Hello! Please follow the instructions below to clean the lifetime Hepa filter on your Elite Rewind.
1. Press on the tab located on the side of the filter cover to remove.
2. Remove the HEPA filter and brush with the combination tool to clean or tap side of filter against a trash receptacle. Return the HEPA filter into the filter cavity.
3. Align tab on filter cover with slot. Press cover closed until you hear a snap.
Hope this was helpful!
Jun 09, 2014 | Hoover U5507900 Elite Rewind Bagless...
How to remove electrolux guardian hepa filter
Open gadget compartment, remove all gadgets or attachments and the hepa filter will be below the vented frame...look next to the end with the hose and you'll see two spring clips (part of the vented frame) and squeeze them to allow the vented frame to release and move upward. This will expose the filter. Reinstall in reverse.
Mar 14, 2013 | Electrolux Guardian Bagged Canister Vacuum
Replacing the filters in a hoover mach 5
The filter is located under a cover directly under the bag in the bag compartment. That's the only one I can think of.
May 15, 2012 | Hoover U5194-900 Mach5 Multi-Chamber...
Where is the filter
Dyson put filters in three locations. 1) Remove the canister, there should be a release clip in the front above the handle, this allows the top to tip backwards. 2) On the left side, at the main unit is a round cover with thumb release, this pulls straight out. These are cleanable filters, RINSE ONLY no soap!!
3) Under the canister is a filter, the cover has 3 clips which need to be pried gently to open the cover. This is a hepa filter and cannot be cleaned, it must be replaced.
Nov 09, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Remove hepa filter
Turn the Dyson on its back as if you were servicing the beater brush and on the RH side you'll see the filter housing for the HEPA and a T-15 Torx screw. Remove this screw and then remove the cover for the HEPA filter.
May 27, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
Replacing the hepa filter
The cover for the HEPA filter is located immediately beneath the clear bin, and is exposed when you remove the bin. Removing the filter cover without breaking something can be a bit of a challenge, but if you look carefully you will see how it fits on, and then, with care, you can lever it off. Then the filter just lifts out. Don't worry if you do break the cover - the cost of a new one is nothing compared with the filter itself. You will need to buy a new adhesive seal too, as the old one will be stuck to the old filter.
Dec 31, 2009 | Dyson DC07i Bagless Upright Vacuum
My HEPA filter get's blown off of the vacuum when I vacuum. I just got all new filters and a new brush roll. Could something be clogging in the inside?
There should be a cover that closes over the HEPA filter. If the cover is missing, or is there, but does not snap closed, then either snap it closed, or replace the cover.
If something was clogged inside, then the HEPA filter would be less prone to being blown off. But, it sounds like the filter or filter cover is not being correctly installed. The manual is not clear on whether the cover snaps closed.
Dec 10, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
How do you remove the HEPA filter on Dyson DC07
I use a screw driver to pry them up.
Joe
Nov 07, 2009 | Dyson Vacuums
Hepa filter on dyson dc01
Not sure about you model, but some of the dyson's have the hepa filter under the dirt container. Remove the container, there is a cover that comes off and the filter is under that cover.
Apr 20, 2008 | Vacuums
Vacuums Logo
47 people viewed this question
Top Riccar Vacuums Experts
ray gallant
Thatvacguy.com
Are you a Riccar Vacuum Expert? Answer questions, earn points and help others
