Question about Graco Sweet Peace Soother in Cuddly Bear
How do you replace the motor of a sweetpeace soother that stops swinging?
Our swing stops and makes a grinding sound. You can order a replacement motor from Graco's site, but I don't know if I need to replace the motor, and I don't know if the motor will come with instructions.
SOURCE: Graco swing not working, I'm trying to open the motor box.
You need to remove the center of the part the connects to the chair. Use a thin screwdriver to pry it out a little, slide the screwdriver into the center and then pry each of the two tabs outward from the center. As you unhook it, you will be able to pry it out and then the attachment mechanism will pull off.
Posted on Nov 20, 2009
  • 13 Answers
SOURCE: My 6 speed Graco swing will not work. The motor
It sounds like the problem is in the motor. Because of the heavy load on the motor during normal swing operation the brushes that are attached to the communicator are wearied out. This causes a loose contact between the brushes and communicator and the motor is loosing his power. Ideally, I would replace the motor. The only a problem is that the available replacement motors have a short shafts, when the motor used in Graco swing has a very long shaft. So, there are two solutions: buy a new motor sage from Graco for $28; OR buy a new motor ($5-$7), then carefully remove a nylon end cap from the old motor and replace it with the nylon cap from a new motor (WARNING: you have to be careful when doing this, because if it will be done inappropriately the brushes can be easily damaged)
Posted on Feb 11, 2011
jyackle5
  • 8197 Answers
SOURCE: i can not find the
You can get the manual on the link below.
http://download.gracobaby.com/ProductInstructionManuals/PD118655A.pdf
Posted on Apr 29, 2011
SOURCE: We need the base to a Graco Sweetpeace baby swing.
graco swing makes grawling noise no music sound at all
Posted on May 14, 2013
kjhbwerw
It is the motor problem... You can search for new one on amazon, take a look here: Amazon com graco swing motor. I hope this was helpful. cheers
Posted on Dec 06, 2014
All of a sudden my Singer Inspiration 4206 stopped working. When I press the foot peddle it only makes a swinging sound like when you're only swing a motorcycle but not driving it. If I turn the hand weel...
If the swinging sound is from the motor, right side just below your hand wheel, possibility your motor belting is loose or broken. If you don't have mechanical skill / experience, suggest to get your local technician to fix it.
Nov 10, 2013 | Singer Inspiration 4206
Under the "Add your solution or ask for clarification" window click on the camera icon to add photo.
May 25, 2012 | Graco Sweetpeace Newborn Soothing Swing...
I bought a used Graco baby swing (I think from about 2001) and I can't fiure out the buttons. There are four - low-timer- high - music. It has 6 speeds, 15 songs, and time listed on the front. I don't...
YOU NEED THE MODEL NUMBER then follow link below
LOOK FOR THE MODEL NUMBER
  • BOUNCER On the back of the vibration unit, below the battery compartment door
  • OPENTOP™ SWING Inside the battery compartment behind the batteries
  • WIND-UP SWING On the underside of the top housing- the piece of plastic that runs across the top of the swing and is right above the baby's head
  • TRADITIONAL SWING Under swing tray
  • TRAVEL LITE™ SWING On the bottom of the contoured plastic seat
  • SWEETPEACE™ NEWBORN SOOTHING CENTER On the bottom of the seat
  • DUETSOOTHE™ SWING + ROCKER On the underside of the housing
  • DUETCONNECT™ SWING + BOUNCER On the underside of the housing
  • DUETCONNECT™ DLX SWING + BOUNCER On arm with motor hub
  • LITTLE LOUNGER™ Inside leg near Rock Lock
  • DUET ROCKER™ Backside of front plastic panel with Graco Logo
  • GLIDING SWINGS Under motor housing unit (electronics hub on right hand side of swing)
  • SIMPLE SWAY™ INFANT SWING On tubing on bottom of unit
  • COZY DUET™ SWING + ROCKER Under battery hub on back of swing
  • DREAMGLIDER™ GLIDING SWING + SLEEPER On side hub with electronics
Product Instructions Search Results
Jan 01, 2018 | Graco Toys
Need a user manual for graco sweetpeace newborn soothing center
I received a Sweet-peace newborn swing and the A/C plug is pushed in. Is there a way to retrieve it? How hard will it be to take the swing apart and retrieve the plug? You can reach me at my e-mail at: dragonman34@mail.com Thank you for your time.
Nov 13, 2009 | Graco Baby Gear
Fisher Price Nature's Touch Cradle Swing - Not Swinging
Parts for your model can be found on amazon, here:
Amazon com fisher price swing replacement parts. I hope this helped you. Best of luck
Oct 03, 2008 | Baby Gear
Graco Sweet Peace Soother in Cuddly Bear Logo
216 people viewed this question
Top Graco Baby Care Experts
ray gallant
Valeriy Bacherikov
Level 1 Expert
ReGina Lewis
Level 1 Expert
Are you a Graco Baby Care Expert? Answer questions, earn points and help others
