Question about Line 6 Music
Spider ii 75 watt amp makes crackling noise after 60 seconds
paulm10
  • 73 Answers
SOURCE: line 6 spider III 15 watt sound problems
Hi there. Sounds like the power amp IC is shorted. Must replace.
Paul
Posted on Jul 09, 2009
  • 1138 Answers
SOURCE: My Line 6 Spider 3 75 Watt amp is having trouble.
Try this site:http://line6.com/community/community/support
Posted on Aug 13, 2009
PolyrhythmFX
  • 109 Answers
SOURCE: High pitched squeal when the input jack is used.
Sounds like your master volume is turned up too much. The channel volume will make the squealing go away(caused by high gain and humbuckers). The best thing to do is dial in your favorite presets and change the channel volume to the correct level with the master volume where you usually keep it. I use my Spider Valve at master volume at about noon and the channel volume between nine o'clock and noon. Let me know if this does not solve the problem......
Posted on Aug 27, 2009
  • 88 Answers
SOURCE: I have a line 6 Spider III, 30, 30 watt. when I
possible software problem
Posted on Feb 04, 2010
chiefmecha
  • 600 Answers
SOURCE: Hi - my Line 6
It is more likely your amp speaker is damaged. The voice coil could be burnt or shorted, since you can hear from headphones yet it does not send the audio down to the speaker, you may want to check the speakers by removing it from the assembly, unsoldering the wires and test with a multi tester, if you dont have a multi tester, you can try using AAA bateries and attaching the positive and negative wires of the speaker to the positive and negative poles of the battery, the speaker should sound as if it is producing a scratching sound, just touch the positive repeatedly, to porduce the sound. But if this does not sound off, the speaker is dead.
if the speaker is working the amplifiers parts may have been damaged, there are a lot elements to check here, and often no service can be made by a non tech, for they are IC's, capacitor,transformers etc involved.
Posted on Oct 20, 2010
My line 6 spider mk 11 starts making a cracking noise about 50-60 seconds after i turn it on, then loud fuzz noise- whats wrong plz help
Disable ALL digital settings....problem gone? If not, with tube guards and/or shileds removed try lightly tapping on each tube (one at a time). Does your amp go crazy while tapping one particular tube? If yes then it is new tube time.
Oct 18, 2012 | Line 6 Spider Valve 112 MkII 40 watt 1x12...
Will this pedal work on my line 6 spider 3 75 watt amp?
It supposedly will work with your amp. It scrolls through the first four presets.
May 17, 2011 | Line 6 FBV2 Amp Pedal
El transistor de poder de mi amplificador line 6 spider ii de 30 watths se quemo, quisiera saber el modelo del transistor para poder cambiarlo
If you want to know what the part number of the power amp in your unit is, it will be either a TDA2030 or TDA2050 which ia a 5 terminal audio amp of 14Watt or 32 Watt respectively.
Aug 11, 2010 | Line 6 Spider Iii 30
Aug 22, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
Line 6 spider III 15 watt sound problems
Paul
Jul 04, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
Music Logo
37 people viewed this question
Top Line 6 Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Larry Stiles
Larry Stiles
Are you a Line 6 Music Expert? Answer questions, earn points and help others
