Question about Frigidaire 18 in. FDR252RB Built-in Dishwasher
Soap dispenser not work - Frigidaire 18 in. FDR252RB Built-in Dishwasher
  • Official Brand Answer
  • 4,342 Answers
Hello Sean Radler - Confirm that water action is reaching the dispenser; water sprayed from the lower wash arm is directed at the dispenser, reposition any dishes that may be obstructing the water from reaching the detergent cup. Make sure items in the dishwasher do not prevent the detergent dispenser from opening (like tall dishes or cookie sheets). If these items do not correct the issue, there may be a problem with the detergent cup opening. Contact a professional to move forward accurately.
Posted on Jan 08, 2013
Fix soap dispenser
remove the entire soap dispenser and clean out any dried soap which may be lodged in the pick up tube, blocking the pump
Aug 26, 2014 | Plumbing
Dispenser door will not open
Hey friend, thank you for the post!
I understand that your soap dispenser door will not open on your Frigidaire dishwasher, LGBD2432LW0A. You could possibly be seeing an issue with soap dispenser not getting water into it to release the soap from dispensing. I would check to make sure there are no dishes blocking or obstructing the soap dispenser. You could also remove the soap dispenser to clean it and make sure there is no buildup of any previous detergent remaining that would cause the door to not open. If those steps do not solve the issue it could be a problem with the dispenser and I would recommend having a tech come out to the home to properly diagnose and repair the dishwasher. Hope this is helpful. -Matt
Jul 28, 2014 | Frigidaire Dishwashers
Blinking light
The issue is the dispensing unit you have is a sanitizer dispenser, not a soap dispenser. The adapter collar on the bottle is the issue. Soap dispensers use a GRY collar, sannitizers use an LBL collar. There should be a sticker on the dispensing unit that says "LBL" or "GRY". Try removing the collar from a sanitizer bottle and place it on your soap bottle......should work fine. In short, make sure your letter code on the bottle mathces the letter code on the dispenser.
Jan 30, 2014 | GoJo Purell 2720-12: TFX ? Touch Free...
Soap no longer dispenses automatically.
Mine would not work with the Costco brand (Kirkland) batteries. The light indicator came on but the pump did not work. Once I replaced them with Durcell, the pump started working. I'm guessing Energizer brand would work just as good.
Nov 22, 2013 | Umbra Otto Automatic Soap Dispenser,...
How to get soap to come out of dispenser of mcculloch power washer fhh 18a
Most people make the mistake of using a high pressure tip on their power washer while trying to get the soap dispenser to work. These tips are usually red, green, white or yellow and they cause too much back pressure at the dispenser for it to work. You need to use the soap tip, they're usually black, for the dispenser to work properly.
Jun 17, 2012 | McCulloch Garden
We have an Emerson hands-free soap dispenser that won't work. We've installed brand new batteries and it still won't dispense soap. The red light comes on to indicate it' s working but no soap will come...
We have 5 Emerson hands-free soap dispensers that don't work. Tried new batteries, light comes on, but no soap comes out. How can we get our money back?
May 20, 2010 | Vacuums
My grohe soap dispenser won't pump out any soap.
If the soap dispenser is not pumping the soap then the soap is to thick. You need to then the soap down some so it will pump.
Apr 01, 2010 | Grohe Satin Nickel Soap Dispenser...
Soap dispenser pump not working
I have the same problem after just about 6 months of use. I have checked to make sure it's full of soap, before you ask...I've run hot water through it while pumping and had success in pumping just water out. Then when back in the soap, nothing happens. Soap comes up about half way into the tube and sits. I now use it as a soap dispenser, dip stick style.
Nov 29, 2009 | Moen 3910S Sand Line Art Deck Mounted Soap...
Dispenser door
Remove the outer door panel and check the actuator for the soap dispenser door it is probably broken. You might also check and make sure you don't have an old soap build up inside the soap dispenser. Sometimes old soap builds up and dries inside the dispenser and causes the door to stick. It should be free. Good luck.
Dec 21, 2007 | Whirlpool 24 in. DU1055XTPS Stainless...
Frigidaire 18 in. FDR252RB Built-in Dishwasher Logo
216 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
