Question about Mr. Heater Portable Kerosene Heater - 175,000 BTU
Mr heater shuts off after 15 minutes - Mr. Heater Portable Kerosene Heater - 175,000 BTU
Ignition control failure
Try cleaning the flame sencor first , or it could be the snap dice shutting down there are two on there you could bridge them out one at atime and see if it stays on .
Nov 22, 2012 | Mr. Heater Natural Gas Garage Heater -...
Installed new heater it ran for 15 minutes and the gas cut off. The combustion fan and the fan keeps running, the only way to stop them from running is to throw the breaker. LED light blinks 4 times, book...
the high limit is an over heat switch that could mean the unit is over fired. you would need to time input or check manifold pressure. the roll out switch is a switch that shuts the unit off if combustion is spilling at the divitor on the unit where the vent connects. with this you need to check your venting
Jan 05, 2011 | Mr. Heater MHU75NG
Steam shuts down after approx.15 minute
I would venture a guess that the heating element has become intermittent with a short. Wasn't so bad before, but played heck with controller due to noise from arcing, but now have a dead short when heater reaches temperature.
Apr 11, 2010 | Mr Steam Mr. Steam MS 81500E AutoFlush
My mr heater won't stay running
No pilot in this unit.
Check the thermocouple and its connections.
The thermocouple is the device that has the copper cable connecting it to the vave unit. It leads up into where the burner can "heat it up". This indicates to the controll valve that the gas is actually burning and keeps the valve open.
Jan 06, 2010 | Mr. Heater Model MH12TS - Single Tank-top...
Heater shuts off , it shuts down after a minute or two looks like low flame and its blue in color i do hear a popping sound when it shut off
The heater thermostat senor for this heater could be bad or indicating a abnormal temperture shutting it down. You might want to return item if still under warranted
Nov 06, 2009 | Mr. Heater (F274825)
Stays lit for 25 minutes and shuts off
How large and sealed of an area are you using it in? I ask because those units have a low oxygen sensor which will shut it down if there is not enough oxygen in the space.(kinda prevents that pesky suffocation thing). Otherwise if using it in larger cold spaces, the issue is can be from the smaller tanks. As mentioned above, a larger tank can solve this, because these units have a fairly good input rate, which will cause the smaller tanks to freeze, and lower the propane temperature and evaporation rate, basically runs out of gas until the tank warms back up.
Jan 19, 2009 | Mr. Heater (F274825)
Mr. Heater Portable Kerosene Heater - 175,000 BTU Logo
94 people viewed this question
Top Mr. Heater Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Mack Baxter
Are you a Mr. Heater Heating and Cooling Expert? Answer questions, earn points and help others
