Tivo Series2 Dual Tuner Digital Video Recorder w/80-Hour Capacity Logo
Mark Chaney Posted on Jan 19, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Tivo and Converter box
Do I need a Converter box when the change happens if I am using Tivo?
Anonymous
Level 3:
  • Master 11,896 Answers
  • Posted on Jan 19, 2009
Anonymous
Master
Level 3:
Answers
11896
Questions
Helped
3737152
Points
36074
Yes you do unless you upgrade to tivoHD
How do I set up a tivo series2 to a new digital tv. Do I need analog to digital converter?
Analog to digital converter is for OTA transmission. You are using a cable system, right? If so you have to feed into your Tivo the cable output signal from your cable box and set your tivo to correct rf or video input. Since cable tuner is determining channel all you can do to record is set the channel on your cable unit and program your tivo to turn on and record the input at appropriate time..
tip
Convert and Transfer Tivo/TS to iPad for HD 720p Playback I use the old version...
I use the old version of Toast 8 with TiVo Transfer to download my favorite shows from my TiVo Premiere to Apple hard drive. However, I could not get the movies to my new iPad via Toast or TiVo Transfer. The file extension for the TiVo videos is not supported by iTunes. Thus, I need to convert TiVo to iPad compatible format.
Aunsoft Video Converter for Mac is the right TiVo to iPad converter for me to convert recorded video to a file that iPad can use. The Mac Video Converter for iPad does convert .tivo files to .mp4 for iPad. I like setting it up to convert my favorite TV shows and movie, and go to bed, leaving it working. Then sync them to iPad for watching on my travel.
For you guys who may have the same problem for converting TiVo to iPad MP4, I here demonstrate the quick steps using Aunsoft Video Converter for Mac.
Step 1. Load TiVo videos to Aunsoft Video Converter for Mac.
Run Aunsoft Vido Converter for Mac as the recommended Mac TiVo to iPad converter, and click the "Add" button to load .tivo videos or .ts videos, which had been transferred from TiVo Premiere to MacBook Pro or iMac.
Step 2. Choose iPad 720p output format.
Click the "Format" option and choose iPad > iPad HD Video(*.mp4), and the Mac TiVo to iPad converter will downscale the 1080i TiVo videos to 720p iPad MP4 videos.
Step 3. Convert TiVo/TS to iPad MP4.
Click the convert button under the preview window, and the Mac TiVo to iPad converter starts transcoding TiVo/TS to iPad MP4 in 720p.
After the conversion, the HD videos will be ready for syncing to iPad. With Aunsoft Video Converter for Mac as the TiVo to iPad converter, it is easy to transfer TiVo videos to iPad.
Tips:
If you have TiVo videos from your friend, remember to ask for the Media Access Key (MAK) for the files. Click the Option button and enter the MAK before loading TiVo files for conversion to iPad.
on Aug 03, 2010 • Cameras
tip
Mac TiVo Converter for iPad-Convert HD TiVo to iPad How to convert TiVo for iPad...
How to convert TiVo for iPad on Mac? To solve this problem, you need to transfer TiVo to your Mac and then convert them to iPad mp4 format with TiVo converter. With our recommended software, you can convert TiVo to iPad mp4 by yourself fast and easily!
How to convert TiVo to iPad mp4 step by step
This guide has 3 parts:
Parts 1: Transfer TV shows from TiVo to Mac
Parts 2: Convert TiVo to iPad MP4
Parts 3: Sync MP4 to iPad
To transfer TV shows to Mac, you need to download TiVo Desktop Software for Mac
Parts 2: Mac TiVo Converter for iPad
After you transfer TiVo files to your Mac, you can convert them to iPad mp4 format. First of all, Download TiVo to MP4 Converter and launch the application. Then follow the steps below:
Step 1: Import TiVo files to TiVo Converter
Enter Media Access Key for your TiVo files from "Option" button and then load TiVo files to the TiVo converter.
When your TiVo is connected to your home network, TiVo Desktop provides you with a list of available shows for transferring to your Mac.
Hints: TiVoToGo Transfers system requirements: TiVo Series2 DVR, TiVo software version 7.1 or later, TiVo Series2 box must be connected to your home network using a wired or wireless USB network adapter.
Step 2: Edit TiVo files
Editing functions are available by clicking "Editor" button in the menu bar. You can crop, trim, add text/image/video watermarks, replace audio, add special effects, etc. you can check "Apply to all" to apply the present settings to all the TiVo files.
Step 3: Choose iPad MP4 output format
After you finished editing, you then choose output format from "Format" drop-down list and specify the format under iPad profile among the three options.
Step 4: Convert TiVo to iPad MP4
Click "Convert" button to start Convert TiVo to iPad mp4. Check "Merge into one file" to join all TiVo files to one output mp4 file before start conversion.
After converting your TiVo to iPad format, you will get mp4 file(s) in destination folder. Then you need use your iTunes to transfer the mp4 file(s) to your iPad device. You may refer to the help document of your iTunes to learn how to do, or you may follow the steps below:
1. Connect your iPad to Mac. And then launch iTunes.
2. Click "File->Add File to Library...." to choose the generated mp4 file
3. Drag the videos you just added to iPad icon.
Now you are free to enjoy your TiVo recordings wherever you go.
on Jul 31, 2010 • Cell Phones
1helpful
2answers
I need installation instructions for a tivo drt-400 humax dvr
No. There is no tuner in the Tivo . It will record cable or satellite but not off air antenna.
tip
Best TiVo to HTC Converter-Convert TiVo Video to MP4 for HTC No matter what...
No matter what kinds of HTC Android phones you are using, you may notice that the supported formats for the smartphone are quite limited. While you have TiVo videos in .tivo or .ts format, which are recorded using TiVo Premiere, do you want to watch them on your HTC smartphone?
There is no mystery for getting TiVo to HTC. We just need to convert TiVo to HTC supported formats and the videos shall play on HTC smartphone. Aunsoft Video Converter is the best TiVo to HTC converter for you, as it includes direct output profile according to HTC models. It saves your time modifying the settings for your HTC Android phone.
Here is the step-by-step guide to convert TiVo to HTC Android smartphone.
Step 1. Load TiVo videos to Aunsoft Video Converter.
Run Aunsoft Video Converter as the TiVo to HTC converter, and click the "Add" button to load TiVo videos in .tivo format and .ts format.
Step 2. Choose HTC Android phone output.
Click the "Format" option, and move mouse cursor to "Android", you will find the profiles for HTC Android phones. There are HTC Droid Incredible, HTC Supersonic EVO 4G, HTC Hero (T-Mobile G2 Touch), HTC Legend, HTC Touch Pro as output profile. Choose the profile according to your Android phone model.
Step 3. Convert TiVo to MP4 for HTC.
Click the convert button under the preview window, and the conversion from TiVo to MP4 for HTC starts right away.
Give it a try, and you will find Aunsoft Video Converter your perfect TiVo to HTC converter. You can easily put and play videos on your HTC Android smartphone.
on Jul 20, 2010 • Cell Phones
tip
Convert FIFA World Cup Games TiVo to MPEG for NAS Sharing Starting from June 11...
Starting from June 11 to July 11, there are 64 games for the FIFA World Cup, which is held in South Africa this year. Even though most of us could not go to the 10 stadiums in 9 cities of South Africa, we can stay in front of the HD TV, and watch the favorite teams to goal. We can use the sports collections of TiVo to get the events and web content, and even record with TiVo Premiere.
After recording the first half of the game between Brazil and Democratic People Republic of Korea (DPRK) for the World Cup, I would like to put the first half to my Network Attached Storage (NAS) so as to continue recording the second half. However, the first half does not work on my TV in the bedroom. My friend recommended me to convert TiVo to MPEG for home network devices with Aunsoft Video Converter. I think it is the perfect tool for TiVo videos, as it exports MPEG files within a blink. Thus, I want to share with you my experiences.
I first use TiVo desktop software named TiVoToGo to transfer the TiVo videos to my computer, and run the TiVo to MPEG converter to rip TiVo for my NAS. You can download the TiVo desktop software. To rip the transferred TiVo to MPEG, just follow the steps below.
Click the Add button to load FIFA World Cup TiVo videos. While we have enter the Media Access Key (MAK) for TiVo video when using the TiVoToGo, the program does not ask me for the MAK again from the same TiVo Premiere. However, if the TiVo video is from different TiVo Premiere, the program will pop up a window for you to enter the MAK.
Step 2. Choose directly copy TiVo videos on the program.
Click the "Format" option and find the "Copy" group. There is only one option Directly Copy under the group. Just choose "Directly Copy" and the program will convert World Cup TiVo videos to MPEG fleetly.
Step 3. Convert TiVo to MPEG
Click the convert button under the preview window and the conversion from TiVo to MPEG starts immediately.
Step 4. Transfer MPEG videos to NAS.
Use the wired or wireless network and transfer the output videos to NAS. It is very easy to make the TiVo videos
Tips:
With the directly copy function of the TiVo to MPEG converter, you do not need to change the bit rate and frame rate settings, as the program will use the original settings of the TiVo video. If you want to convert TiVo video to portable devices like iPad, iPhone 4G, iPhone 3G, Zune, you can choose from the format and change the bit rate and resolution for output videos.
on Jun 17, 2010 • Cameras
I need the 5-digit Tivo series 2 IR code for my iView 2000STB digital converter box.
The 5 digit Tivo Series 2 code to use with the iView converter box is 10092
When my Tivo stops recording a show on, say, channel 54, instead of staying on channel 54 it switches to channel 5. In other words, it only gets ''part'' pf the channel number. This happens with other...
The end of the IR Cable that attaches to your cable box may have to be repositioned.
Try moving it a small distance (you are already close or you wouln't be receiving ANY channel changing info. from it) and see if that helps.
5helpful
2answers
TIVO DVR : Won't Change Channels
Set up your infrared blasters connected from your IR port on the Tivo and by placing the two lead lights in front of your cable box so it (the cable box) can read the signal.  Then go to Channel settings accessed through Tivo Central and follow the questions. It will ask you to change channels until the remote is working correctly.  This all worked on a different "input" on my Mitsubishi TV (it has multiple inputs.  I have the cable input on a different "input" to make it work.  Hope this helps.  Call TIVO tech assistance because they are the ones who talked me through this.
Top Tivo Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Are you a Tivo Televison and Video Expert? Answer questions, earn points and help others
