Question about Moon Jumpers Jumping Stilts - Adult Size 155-200 Lbs
SPARE PARTS FOR MOON JUMPERS - FOOT LOCKS, RUBBER FOOT
I have a new pairs of moon jumpers but unfortunately one of these four foot locks is weak (spring inside the plastic foot lock is weak and i can not rise well the foot) and i don't know where to find these spare parts. Rubbers foots are blunted and i want to change it but i don't know where to find these spare parts.
I have a Sewing Machine EURO PRO 416 I need a POWER CORD WITH FOOT CONTROL and RUBBER RING LOCK
Check this site
Euro Pro Sewing Serger Machine Parts www drdanessmh com
It is impossible to list all parts on a webpage so if you don't see the part you need click their Contact Policy Tab at Dr. Dane's Sewing Machine Hospital for more Parts
Jul 27, 2015 | Euro-Pro 416 Mechanical Sewing Machine
Moon roof and power windows do not work. Power seats and door locks till work. Relays and fuses good
Are the switches located near each other? Plug may have come off or on some models with console switches things get spilled in them???
Sep 17, 2014 | 1999 Ford Explorer
Just got back from buying the Crescent Moon Series 13 snowshoe. Looked online and that series is for woman. Is that a problem for a man to wear?
Are they your Size?
What is your Weight?
If you are a LARGE MAN, it could be an issue but if your Foot fits into the shoe, and you are a normal stature, you are ok.
Feb 12, 2014 | Crescent Moon Snowshoes Crescent Moon Gold...
Removal of turn signal switch
To remove turn switch, make sure steeing wheel is staight and remove horn button and steering wheel...Now you will need a special tool called LOCK PLATE REMOVAL tool . that will expose the turn swith.Unscrew the turn switch handle and emergency flasher switch.Remove 3 screws to remove the switch.At he bottom of the steering colum is a half-moon shaped connector that you need to disconnect and install a 3 foot piece of wire securelly so when you pull switch out the wire will be able to guide new switch wire into place and reinstall
Feb 21, 2011 | 2000 GMC Sierra
I have Calandar Creator 10 and have created a family calandar which I use from year to year that includes birthday events, holidays etc. and phases of the moon. This year, when I went from Dec. 2010 to...
Calendar Creator 10 has the four moon phases from Jan 1990 thru Dec 2010. To extend past 2010:
- File Open Collection ' Local Disk(c:)'Program Files'Calendar Creator' Template'Events'Phases of the Moon.bcc
-For each of the four events (First Quarter, Full Moon, Last Quarter, and New Moon) change the Repeat Until date past 12/31/2010 to 12/31 of the year you will add data for
-For each of the four events, click Advanced Repeat Rule you can selete the drop down under Exceptions / Pick exception and there you can see the dates by month and year from Jan 1990 thru Dec 2010 for the event. You need to extend this list. First obtain the moon phases from some web site like www.timeanddate.com/calendar. (note that this site calculates the mone phases base on New York time). The simply select each of the dates for the event you are modifying by clicking that date on the calendar in the upper right hand of the screen. Just advance the calendar thru the months and years you want to enter data for. You can check the list when finished by selection the ExceptionS Pick exception drop down box.
- Save your changes by clicking OK and Ok again. Make changes for all for events.
- Select File and Save Collection
- You need to replace the Phases of the moon events in your calendar by removing the old events and importing the new events. To remove the old Phases of the moon in your calendar, select Events'Categories highlight Phases of the moon and delete. Then add back the changed events by File'Import Events and browse for the Phases of the moon.bcc file you changed.
I hope this gets you what you need.
Nov 19, 2010 | Broderbund Calendar Creator Deluxe 10 Full...
I need replacement bands for shoes that are frayed
http://www.bigtimetoys.com/contact.html Big Time Toys, LLC
708 Berry Road
Nashville, TN 37204
Moon Shoes Replacement Rubber Bands
Send a check for $7 to Big Time Toys at the above address for a pack of 50 replacement rubber bands.
Oct 23, 2009 | Kb Toys Moon Shoes
Keyless entry, moon roof and door locks dtopped
Well there are more wires behind the radio which may have been unhooked while pulling out your old radio. If you cut any wires and left bare wire exposed its a possibility it could have touched and blew a fuse.
Jul 26, 2009 | Dodge Stratus Cars & Trucks
Lost rod totransfer case on 2003 1500 dodge pickup bought replacement parts but can't get rubber groments to go in .
Have you tried oiling them with wd40 and try squeezing it together with a pair of channel locks or vice grips.
May 19, 2009 | 1998 Dodge Ram 1500 4WD
Moon Jumpers Jumping Stilts - Adult Size 155-200 Lbs Logo
433 people viewed this question
Top Moon Jumpers Sport & Outdoor - Others Experts
Are you a Moon Jumpers Sport and Outdoor - Other Expert? Answer questions, earn points and help others
