1998 gmc envoy heater problem, fan is working fine but is blowing cold air on defrost and heater.
  • 11,896 Answers
Do you smell antifreeze? If you do, then your heater core needs replacing.
If not then try these solutions:
Priority Action Part Type Cause 1 Inspect Cooling System Mix Coolant level low or flow is restricted. 1998 gmc envoy heater problem, - grey_line.gif 2 Inspect Thermostat Thermostat stuck closed grey_line.gif 3 Inspect Heater Control Valve Leaking or defective heater control valve.
Posted on Jan 19, 2009
I have a 1998 Ford Windstar. The A/C works fine, but the air only blows out of the defroster vents. It sounds like a vacuum hose to me. Where would be the first place to look? The vehicle has the rear...
to locate and fix the problem by your own you need service and repair manual which will guide you step by step with diagram and you can get the manual from the given link http://toolsnyou.com now you don't need the mechanic and save your money i had tried this link before and they provide the orignal manual good luck
Dec 13, 2017 | 2003 GMC Envoy
Hot to cold air in 1999 GMC Envoy
heater core plugged. remove heater hoses, use tap water to flush out core..
Jan 17, 2013 | 1999 GMC Envoy
On my 2004 Gmc Envoy, Heat only comes out on passenger side, still blows cold air on drivers side. Defrost, floor and vents all produce air flow. Rear heater works fine. A/C works fine. Any idea?
Sounds like the driver's side temperature actuator or blend door are defective. Part of the dash needs to be removed to access these parts.
Oct 26, 2011 | 2004 GMC Envoy
Air works great but no heat just blows cold air
For this types of problem,i suggest you to check this help links:----Car heater blowing warm, but not hot air?http://schematicsdiagram.blogspot.com/2011/12/car-heater-blowing-warm-but-not-hot-air.html
---------A/C, heater, defroster fan, not working?http://technoanswers.blogspot.in/2012/02/ac-heater-defroster-fan-not-working.html
--------Heater problem?http://technoanswers.blogspot.in/2012/02/heater-problem-on-isuzu-trooper.html
---------Engine Overheats and heater blowing cold?http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
-----------Heat blows cold on drivers side and hot on passenger side?http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html----------------This will help.Thanks.
Sep 05, 2011 | 2007 Suzuki SX4
2006 Envoy SLT air suddenly stopped blowing from vents
the resister block needs changing... oddly enough i'm unsure of what fan you are saying is not working.... if it's the front.. the resister block is located on the duct work under the dash for the air... near the fan... you will see a connector going into the side of the duct work. two screws and the block comes out... should be fairly obvious for the rear one but it will be near the fan.
Apr 16, 2009 | 2006 GMC Envoy
2006 GMC Envoy and the A/C fan wont work in number 5 position
replace the resistor 4 the blower motor that should slove that hope this helps
Mar 05, 2009 | GMC Envoy XL Cars & Trucks
The heater still won't work after I changed the thermostat on my
Get a female garden hose adapter from the local hardware store. Disconnect the heater hose from behind the fan pulley and attach the hose connection. Disconnect the other heater hose behind the alternator, aim it towards the ground and flush water through the heater core. This worked on my truck.
Feb 12, 2009 | 1999 GMC Sonoma
'98 S-10 heater blowing cold air - not hot air
will the air flow switch from floor to the mid to defrost? if so then we have a problem with the tempature door actuator. easy to replace just in tight place. Keep me posted for more help or if this was any help thanks
Jan 31, 2009 | 1998 Chevrolet S-10 Pickup
Cold and no heat
This is a common complaint for the 4.3 v-6 by GM, what happens over time is air gets into the cooling system, usually a small coolant leak at the intake manifold gasket. Ait gets in the cooling system and starts electrolisis. From this the coolant starts to solidify. If I'm correct your heater core is plugged. Remove the radiator cap (engine cold only) and inspect the coolant. The proper color should be red. If the elctolisis is taking place the coolant will turn to rust and look like mudd. If you find mudd in the radiator, most likely the heater core is plugged. This is a very expensive repair. You'll need to remove the raditor & sent it out to be boiled out. Replace the heater core, thermostat and the coolant hoses. You'll also need to perform a "prestone" flush. You may need to flush the cooling system monthly until the system is clean.
Oct 17, 2008 | 1998 GMC Envoy
Heating & Cooling Logo
164 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
