Question about Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
Carrier Comfort Zone ii - trying to find user manual
I can't get the heat to kick on downstairs.
  • Ksez Feb 19, 2009
    I have the same problem...any solution.
  • Dale Koehn
    Dale Koehn May 11, 2010
    is this a zone system ?? does it have separate temp control devices in the home ?
    Guru:
  • 462 Answers
Your description leads me to believe you have 2 thermostats. How long have you lived in the house? Did it work for you lately? Sometimes its just the door switch. If you have to remove it to change the filter or had it off for another reason hold the switch in by hand and try it. then check the door for correct channeling in the grooves provided and see if this is it.
Posted on Mar 10, 2009
Manual for comfort zone CZ+-20110
Try Googling (comfort zone)(CZ+-20110)(manual) without parens.
Nov 14, 2017 | Comfort Zone Heating & Cooling
My comfort zone 2 thermostat and unit is brand new. I have 2 zones. AC works fine in both zones but when I needed heat only zone 1 heats which is downstairs. Zone 2 which is upstairs, does not heat.
I would call out the installer, you said it was new, so it should be under warranty.
The "W" wire is traditionally the call for heat which may not be getting to the upstairs unit, and if it is, then the unit needs to be diagnosed.
Jan 23, 2016 | Heating & Cooling
I have a Carrier Comfort Zone II with 2 controlled zones. The floor with just the sensor controls perfectly. I set that zone at 75 and it stays at 75. The other zone has the actual thermostat. If I se
Sounds to me like a bad damper or a bad zone panel. Turn tstat off and call for cooling on zone 2. Then see if your still getting cool air to zone 1.( where the main tstat is)
Jul 15, 2017 | Heating & Cooling
Carrier comfort zone ii thermostat troubleshooting
emergency heat probably strip heating
Sep 07, 2014 | Heating & Cooling
My carrier comfort zone II thermostat is flashing E1. What does this mean and why am I having trouble setting my temps?
I suspect that if you change the battery in the thermostat. All will be right again.
Thanks for choosing FixYa.
Aug 27, 2011 | Carrier Heating & Cooling
Blank readings on Carrier Comfort 3 zone thermostat
The stat that works is called the main and the other two are called slave stats. The stats must be set to heat or cool the same as the main. If you want one room to cool and one to heat , sorry. Need to upgrade to auto changeover. Is this AC actally a Heat pump?
Jul 01, 2009 | Carrier 38CKC042 Air Conditioner
I get the error code E2 It only shows 2 zones on my 4 zone syst
I reset the circuit breaker to the panel and everything is good now.
Jun 24, 2009 | Carrier 38CKC060 Air Conditioner
Thermostat issue with comfort zone II.
Is this an electric or gass furnace - Eather of these can can have this problem its most recomendable that you call a seviceman .
in the case of electric furnace you may requier a new heat sequencer. And in the case of gass you may requier a new relay.
Feb 18, 2009 | Carrier 38CKC060 Air Conditioner
Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
619 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
