Question about Whirlpool GGQ8831L Gas Dryer
Whirlpool lgb6000kq1 I took and broke down the whole machine, and vaccum it down, check the continuity in all solonids, thermister, and sight glass/visor, reconnect it, and fire it up, with the top crack open, saw the light/flame, ran it for a few minutes, and open the front door and had the owner stick his hand inside, (Performance Test) and it was hot. Close the machine up, and clean and took my tools and pay and left. Today the owner calls me and said that it is not heating still? What went wrong? I will be on my way there after getting a pair of solonids, which is the other reason that the machine won't hold the gas open? Any suggestions?:
  • 1,214 Answers
Check that the vent duct is not partially clogged, reducing airflow. Overtemp sensor will shut the gas down after a period of operation when this condition exists.
Posted on Jan 19, 2009
Whirlpool Dryer LGB6000KQ1 - Dryer Doesn't heat nor does timer advance.
Probably the heating element. They go bad more often than timers.
Jul 25, 2017 | Whirlpool Dryers
My Kirkland dryer model # sdgs800jq2 will turn on but no heat
Recheck your model number. It is not coming up on my search but I can give you an answer regardless. The Kirkland Dryer is one of many whirlpool dryers sold under a private label so it can be sold at lower price. It works the same as most dryers. The heat cycle is regulated by 2 components other than the heating coil & timer. They are a thermal fuse to prevent fires and a thermister that turns the coils on not to exceed a predetermined temperature followed by a cool down period until it resets. So the heater is constantly turning on and off. 2 problems can happen. 1) The heater coil can burn out or 2) the exhaust can clog resulting in the dryer over heating and blowing the thermal protection fuse. If your exhaust comes out on top of the house I'd be willing to bet there's a clog just a few inches inside the exhaust outside the house. Some of these require you to cut it open to get at it. Before you do that, get an ohm meter open the dryer housing and test the fuse, thermister, and heater coil. There are numerous youtube video on how to do this seach for them on youtube. Most have to do with continuity. No continuity means the component is broke. For parts, see your local appliance store that has a parts department. Everybody stocks Whirlpool parts. And if worst comes to worst, write down you model number and go to & enter your model number into their self help section for step by step instructions & video links. Good luck.
Aug 24, 2015 | Dryers
Not heating
Do a continuity test on the heater coil. No continuity, it's broke replace it. If it over heated and the coil is ok then the thermal protection fuse blew. Both the fuse and the thermister need to be replaced & check the vent where it exits to the outside. It may be clogged and the cause of the problem in the first place. Very common cause. If not addressed it will break down again. See youtube for videos on how to test the thermal fuse & thermister. Just search "dryer repair". Review a few. Some are better than others.
Mar 03, 2014 | Candy CDC266 Dryer
I have a whirlpool cabrio dryer model WED6600VWD. What does the F1 error code mean?
The F1 error code means that the thermister (cycling thermostat) has a open circuit and should be replaced.
To check the thermister you would need to DISCONNECT POWER TO THE DRYER remove the lower small front panel below the main one where the door is at and using a digital meter set to measure ya would remove the wires from the thermister and check for appx. 5,000- 7,500 ohms at room temperature.
If the ohms at within 5 thousand to 7thousand 5 hundred at room temp. the thermister is good and the control board is what the problem is....if the ohms is way lower or higher that 5-7,500 ohms the thermister is going to be what would need to be replaced.
Here is what the thermister looks like
I hope i have been able to help you fix your dryer,
Oct 31, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
2005 Hyundai Santa Fe, continues to run after key is turned off, turn key to on position then back off the engine turns off.
replace the solonide valve on the fuel pump or the ign part of the key/barrel is broke.adrian,,,
Jul 30, 2010 | 2005 Hyundai Santa Fe
I have a Whirlpool LGB6000KQ1 Gas Dryer. It
Hello, Unfortunatly your wrong on all 3 counts sorry :) This problem is going to be your safety valve coils...basically they get old and over time of heating then cooling develop a short when they heat up...It may appear the gas lights to start but then goes out until the safety valve coils cool back down. Here is a picture of the coils 57d5263.jpgThis The coils are mounted to the gas safty valve, This should solve your problem. Hope this helps, Please feel free to comment again if you have any further questions or concerns. Good Luck! Mike
Sep 09, 2009 | Whirlpool LGB6000KQ Gas Dryer
Whirlpool model LGB6000KQ1 gas dryer runs but has no heat only cool air. The timer when set to timed drying, moves down to off position, but does not shut off. Please let me know what parts may be faulty...
If the timer advances to OFF and does not stop you have a bad timer. It could also be the cause of no heat. Replace the timer first. If still no neat replace the glow bar ignitor.
Aug 24, 2009 | Whirlpool Dryers
Ricoh CL4000DN Thermister installation
The thermister is located in the fuser section of the machine. It will slightly rub on the hot roller, or fusing belt.
Apr 03, 2008 | Ricoh CL4000DN Laser Printer
Kyocera KM-6330 ( c-6020)
Did you check the thermofuse? are you getting continuity from the fuser lamps?
Oct 27, 2007 | Office Equipment & Supplies
Whirlpool GGQ8831L Gas Dryer Logo
144 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
