Question about Empire DV-215 Direct Vent Natural Gas Heater
Pilot is too strong
Pilot light is orange and strong
2 Suggested Answers
SOURCE: pilot will light, burner will not
check all limit switches to see if they can be reset if so reset it ,if problem reoccurs wich limit is going out ? make sure all wires are connected well to your gas valve , use a low voltage tester to make sure your firing circuit is operating properly , if you have a thermocouple it may not have enough juice left to open your gas valve
Posted on Nov 03, 2008
Pilot goes out
The pilot may no be strong enough to keep the thermocouple active . check to see that the pilot is engulfing the thermocoupler completely.
You may have to adjust the pilot for a stronger flame or you may have to clean the pilot orifice if it is dirty. Hope this helps.
Dec 30, 2013 | Blodgett 1060 SINGLE Gas Pizza Deck Oven...
I have a new Atwood G6A-7 water heater. The pilot lights fine but gas flow, when it turns on, is so strong it will blow the pilot out. Certain times, it sounds and looks like a mini fire ball going
Clean burner tube with proper brush, such as long spring type for bar-b-Q burner tube that are available at most hardware stores, and make sure you have new burner tube aligned properly (straight on) with brass orifice on gas control. Then be sure to adjust air shutter for nice blue flame, with little orange at tip. Do not give so much air that flame roars or jumps off the end of the burner tube. Too many people think more air, less fuel, but actually, when flame roaring and jumping off end of tube, the heat passes through faster and it takes longer to heat the water inside the tank. Like I said, only enough air to have quiet, steady blue flame. If your not giving it enough air, you'll see dark soot on trailer above water heater, which indicates burning too rich, need more air, or perhaps pilot is partially plugged. Pilot flame should also be blue, not yellow/orange. Small air intake hole on side of fitting just before pilot tube can get spider web, or debris in it as well. Use air to blow that out or a piece of wire like a paper-clip to clean inside that hole.
Dec 12, 2012 | Atwood G6A-7 G6A7 Manual Pilot 6 Gallon RV...
The pilot won't stay lit on gas hot water tank.
Make sure thermocouple tip is seated inside the burner flame.
Make sure thermocouple is not overtightened. Finger-tight + 1/4 turn.
If the pilot lights, then ECO energy cut off is not tripped, but gas control valve might be bad.
Check color of pilot flame: it should be strong and clear blue.
If pilot flame is weak, or color of flame is yellow-orange: Clean pilot orifice and burner and combustion parts on yearly basis.
Clean air intake screen if applicable.
Increase air supply to water heater. Open a window and see what happens.
Check for adequate draft going up chimney using match under vent hood to see if smoke drafts immediately upwards.
Bleed air out of gas line.
Check gas pressure.
Open following links for troubleshoot resources:
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
http://waterheatertimer.org/pdf/Pilot-outage-troubleshooting.pdf
http://waterheatertimer.org/pdf/Vent-spillage-test-atmospheric-gas-water-heater.pdf
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Sep 21, 2011 | Water Heaters
Pilot light will not stay light
1) Open following link for how-to resources, illustrations, and service manuals for some brands of heater.
2) Many things can cause pilot problems, including bad thermocouple, air in gas line, low gas pressure, negative pressure in house, bad venting, very hot attic, lack of combustion air, dirty combustion parts and dirty pilot tube, bad gas control, reversed polarity on electrical outlet.
3) If pilot flame is clear blue and strong, then next step is check that thermocouple sits in the flame, and then change thermocouple. This is start point. Following step would be reading service manual for exact troubleshoot and testing steps.
4) If pilot flame is yellow-or-orange or weak, then clean dirty combustion parts including pilot tube and air intake. Might want to change thermocouple while combustion parts are removed for cleaning.
5) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 05, 2011 | RTO W4 A.O Smith Gas Hot Water Heater...
Pilot light won't light the low flame or stay on
If the pilot light will light at all but not have a good strong flame I would remove pilot assembly and clean it thourghly,being careful not to damage pilot orifice. Reinstall pilot and seeif you have any improvement. If pilot still won't stay lit I would replace thermocouple being careful to make sure top inch or so is in pilot flame. Hope this helps. Thanks
Nov 20, 2010 | Blue Rhino Heating & Cooling
I have an Endless Summer (Blue Rhino) patio heater with model number 153100 and the pilot flame is not strong enough to keep the thermal coupling open. What has to be done to fix that?
The pilot jet may be clogged. If there is a flame, it must be small and blue. A large flame that is orange or yellow tipped means that there is a partial blockage in the pilot assembly which needs to be cleared. The pilot flame must also touch the thermocouple in order to heat it correctly. Make sure that the pilot jet and thermocouple are positioned correctly. If you have an extremely small pilot flame, try repalcing the regulator and hose as the regulator may be failing.
Sep 02, 2010 | Endless Summer 153100 Open Flame Patio...
Pilot light on gas fireplace will not remain lit
check that you have thermopile connections are right at valve and that the flame is hitting both thermopile and thermocouple good. pilot falme may be blue but is it strong? a strong pilot has flame completely hitting both safety's. if pilot is small check pilot orifice inside pilot hood, a quick fix which may work is put vacuum over pilot hood and **** out any dust in there, just be gentle...
Feb 06, 2010 | Ovens
High pilot
clean the pilot assy. poor gas/air mix
Nov 26, 2008 | Heating & Cooling
Oven not working - strong gas ordor
man that is an old oven, according to the diagram ther is a pilot light in the oven compartment , access form the lower drawer/ cover panel, looks like a pilot for sure and problably has blown out
Nov 25, 2008 | Magic Chef 31000 Gas Kitchen Range
Empire DV-215 Direct Vent Natural Gas Heater Logo
35 people viewed this question
Top Empire Heating & Cooling Experts
Paul Carew
vance jones
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you an Empire Heating and Cooling Expert? Answer questions, earn points and help others
