Question about Whirlpool AWM8163 Front Load Washer
Clean pump light keeps coming on
Own a westinghouse wfs 1071aw 6th sense 7.5kilo front loader . just wondering if according to the manual that the definition of cleaning pump is undoing the filter bung and remofing foreign object because all the other front loader washing machines we have had e.g gorengi pacific , have a small filter tray incorperated into the bung when you remove it.the whirlpool doesent have this and it makes me think that something is missing ! is there supposed to be some sort of mesh or filter casing around it ? seems wierd that the filtration trap is just a skeletal plastic frame.is real pain when something as small as a 5 cent piece gets caught in it and i have to drain the remaining water and then put it through its rinse drain cyle again after mopping up .
  • daleandtony May 20, 2009
    I have lost my manual for my westinghouse 8kg front loader.
    I need to clean the filter.Do I just unsrew the bung at the bottom ?
    How do I clean the filter?
    Sergeant:
  • 367 Answers
That is the way to fix the issue. remove the debris and hope nothing else gets caught in the trap
Posted on Jan 19, 2009
  • harmsway147 Feb 04, 2011
    I tried moving all the foreign objects that I could see (obvious things) then I put it back through a cycle and found the light was still on saying clean pump. I had to repeat the step again, but this time I got all the little things right at the back over the rubber lip - thing and there was alot more smaller objects that I never got out originally. Took EVERYTHING out this time and its good as gold now.
My whirlpool 6th sense front loader has stopped whilst full of water, half way through a wash. Have emptied machine, Still no power, machine wont turn on.
Hello Janine Gooch,
Went out on our internet trying to find your trouble shooting guide (typically in the OWNERS MANUAL)...
Finally ended up in AU ... No luck.
(September 9th is only 6 hours old here (SF Bay area)).
Your local peers have NOTHING NICE to say about that machine... particularly the CONTROL BOARD:
Whirlpool WFS1071BD Question and Answers
Hope this helps (says top load... shows front)
Carnac the Magnificent
Sep 09, 2017 | Whirlpool Washing Machines
Were is the pump on whirlpool 6th sense
Whirlpool recently launched a new site and I find they have made it easier to find the solutions I need for DIY. www.whirlpoolwaterheaters.com/products/natural-gas/n50t61-403/
Jun 24, 2012 | Whirlpool 6th Sense 50-Gallon 6-Year Tall...
Whirlpool washing machine WFS1273AW manual
I have a whirlpool WFS 1273 AW front loader that gets stuck in the spin cycle. The timer counts down from 18 minutes to 17 minutes and starts to spin but before it gets to full speed the control panel lights all flash, go blank, and the. The timer resets to 18 minutes. I have cleaned he drain pump, removed the clothes and tried it when empty and it does the same thing. It does not appear out of balance.
Jan 04, 2012 | Whirlpool Washing Machines
I have a whirlpool wfs 1071aw and havent used washing liquid before only powder...cant find my manual and when I put the liquid where I would have put powder it leaks soap out of the dispenser onto the...
You should have a little divider in the soap drawer , it needs to be moved into a different position for liquid ( holds the liquid until the cycle begins)
Mar 15, 2011 | Washing Machines
Whirlpool AWOE 9559B 1200rpm 6th Sense Washing Machine, 9 kg instruction book lost; can you provide me with a copy please
Morning, Your model number does not come up. It is located on a front loader behind the door, top loader under the lid. GE right side at front bottom of case. Will await your answer. Thanks
Jan 23, 2011 | Washing Machines
Whirlpool front loader - 6th sense AWO 3561. The machine is stopping on the rinse part of the cycle and E09 is displayed in the "remaining time" display. The "water tap closed"and "clean pump" lights were...
please consult the user guide from the manufactures website its usually free to download and go to the problem shooting section for a possible answerer eric
Dec 19, 2017 | Washing Machines
Whirlpool 6th sense front loader awm 8121
my whirlpool 6th sense will not start all lights and power i think that it is the door sensor at fault? The green light door locked light is not on.
Jul 18, 2008 | Whirlpool AWM6100 Front Load Washer
Clean pump!
remove bottom panel torx or 7 mm nut driver needed.pump has "knob" turn counter clock wise ..have plenty of towels handy to unlock door first reach up to bottom of door lock tear shaped plastic tab pull down door will open
Apr 26, 2008 | Whirlpool AWM8143 Front Load Washer
Whirlpool 6th sense awm8163 programes never stops now cannot get it to work at all
The pump is at the lower left of the front of the machine covered by a white plate. Use a bowl to catch any remaining water when opening the screw thread inside and then clean and replace. If it is truely beyond repair then a new filter pump can be bought from ebay for £3 or thereabouts.
I have just drained mine manually in this way and am going to run it empty with soda crystals to glean a few more days use whilst the new pump arrives.
Good luck :)
Jan 20, 2008 | Whirlpool AWM8143 Front Load Washer
Whirlpool AWM8163 Front Load Washer Logo
540 people viewed this question
Dan Webster
Dan Webster
Sal De
