Question about Compaq Armada 1700 Notebook
Dim display Is a dim display a common problem with this laptop? Has anyone replaced a display and if so what is the difficulty level. My 7 year old is always playing internet games on my computer which worries me so I had her bring her own laptop over which is this old dilapidated armada. Everything functions fine except a somewhat dim display which would drive me nuts. Doesn't seem to bother her but at least she is not playing spongebob games on MY computer anymore!
  • rmitaliano Jan 22, 2009
    I think it is most probably a hardware issue but getting it fixed would cost more than the think is worth. thanks, Myra
  • 55 Answers
Check power settings as it may be in battery saving mode, for games it should be set to maximum performance. There will be settings for brightness and contrast possibly using the function key and cursor arrows. It may help to change the screen, which is moderately difficult if you have a disassembly diagram, but it is worth trying to change the inverter first.
Posted on Jan 19, 2009
The display is too dim to read. what can I do?
Depends if it was dim when new then not a lot you can do
if it has gone dim , you have 2 options
1 unplug it and put plug in front of oven door,then remove all cabinet screws.locate the display control printed circuit (under display)take photo of wiring with phone to aid reassembly ,unplug and remove printed circuit board screws and board,clean display screen and window ,if was clear then either obtain replacement panel or take panel into radio or electronic repair shop and have them check and replace any poor electrolytic capacitors, this usually cures older ovens ,but if 6 0r 7 years old displays themselves dim and need replacing.ps if good at soldering just note these capacitor values uf and voltage and obtain at maplin and replace all observing polarity when fitting
Jan 11, 2015 | Microwave Ovens
Freezing On Master level difficulty
Please do clear marketplace and cache and try again
Apr 09, 2012 | Konami Dancemasters for Xbox
Dim display on Toshiba Satellite 4090XDVD notebook
The backlight CCFL lamp provides the lighting for the LCD screen. If you have already adjusted the brightness to the max. setting and it is still dim, it means the CCFL lamp is is nearly worn out. To determine if you have a LCD screen or video card problem, read this and follow the instructions. Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp. Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case. The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills. Check out www.lcdparts.net for parts, repair service and DIY info.
Jun 18, 2009 | Toshiba Satellite 4090XDVD Notebook
My lcd monito goes bllurd
The dimmed effect is caused by the internal lamp on the LCD screen...
Look for a lamp replacement.
Jun 10, 2009 | Compaq Armada E500 Notebook
The Display is Dim. Hard to read the numbers.
I have the same model and problem. The time display is totally unreadable. Looking for a solution as well. I suspect given the cost (I believe around $60), it's time for a new one. Anyone have any suggestions or easy repair ideas?
Mar 12, 2009 | Sharp R-314FS Microwave Oven
Blue LED display too bright
TRY........with radio on and set on "AM", hold "Clock" button about 7 seconds and let up - bringing a setup menu. Using tuning knob,scroll to "Hardware". Press tuning knob in, bringing up contrast menu. Press tuning knob in, bringing up "contrast level". Turn tuning knob counter-clockwise to "00". Brightness, dimming level should be "170". Turn radio off to exit, then adjust "Dim" button to your liking.
Nov 02, 2008 | Boston Acoustics Recepter Clock Radio
Dell 6400 when connected to Digital projector forces zoom to unreadable levels
This is a common problem with an application called intellitype or Intellitype Pro.
You can turn off zoom in the intelliType application. This will fix it.
Apr 18, 2008 | Dell Inspiron 6400 Notebook
Jenn-Air Convection Oven
Our 7 year old "Jenn-Air Convection Oven", Canadian Model # SVE47600 also has a very dim display. We can barely read the temperature on the oven. Does anyone know what is wrong, how to fix it, and what it may cost us?
Dec 20, 2007 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-air slide in range/convection
I put a $.12 capacitor on the display board and the display came back. capacitor in position c3, part from mouser electronics, #746-uvy1v680med
Dec 19, 2007 | Kitchen Ranges
Dimming temperature and clock light on display window
I found capacitor c3 (68 uf 35 volt) had leaked and dried up, causing the display to fail. I unsoldered and tested c1, c4, c7, and made sure they were good, using a digital multimeter with the ability to test capacitors. C3 also had visible signs of leakage. Works like a charm again, and the display is bright like new!
Dec 30, 2006 | Thermador SC272T Electric Double Oven
Compaq Armada 1700 Notebook Logo
182 people viewed this question
Top Compaq Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
