Question about Frigidaire ATF6000ES Front Load Washer
Why is my frigidaire front load washer model #ATF6000ES1 leaking water
Where could my washer be leaking form?
eagle338
  • 4889 Answers
SOURCE: Bleach and Fabric Softner Dispenser
This is absolutely normal and you dont have to worry about it..
The reason for this:
The fabric softener compartment uses an over flow method to get the fabric softener out of its compartment and into the wash load. Water comes up underneath through a syphon tube and gently fills the fabric softener dispenser and causes it to over flow in its diluted state. The reason for this is that it is the most effective way for fabric softener to be diluted prior to hitting the clothes in the drum. Fabric softener has to be diluted before coming into contact with fabrics.
This is in contrast to how detergents dispensers work which simply flush the soap powder in to the drum by water being squirted on to it from above.
It is perfectly normal to have a fabric softener dispenser full of clean water after the wash cycle. Just lift and empty it out when you need to fill it with fabric softner for your next wash
Posted on Dec 10, 2007
  • 125 Answers
SOURCE: frigidaire front load washer problems
most likely something is stuck in the pump. it could also be that you are not using high effiency detergent.
Posted on Jan 06, 2008
  • 156 Answers
SOURCE: leaking frigidaire top load washer
yes there a seal under the tub ring make sure tub ring has all the snaps in place
Posted on Mar 03, 2008
IFIXALL
  • 868 Answers
SOURCE: Door Leak
Not usually ,replace the gasket if you cant re set the old one.
Posted on Jun 03, 2008
aborcass
  • 2651 Answers
SOURCE: frigidaire front load washer no spin
sounds as if theres something stuck in your drain pump, youll need to remove the lower acess panel(2 screws across the bottom front of unit) you'll see teh pump in the rigth hand corner. i would remove as much water as possible before trying to remove the hose to the pump or you will get soaking wetaferer removig the hose youll be able tro see what trapped in oyu pump preventing free draining.. VERY common problem.DISCONNECT POWER THE DRAIN PUMP IS ALWAYS LIVE!!!!!!!!
Posted on Oct 19, 2008
Frigidaire Affinity Front-loading washer wont do anything
Check the wall socket with another electric gadget. Check your washer plug fuse. Finally open up the rear (after taking the washer power cord off the wall of course!) and disconnect and reconnect all wires and connectors one by one. Possible it could just be a loose connection somewhere. Sometimes happens due to vibration.
Click so pl if helped.
Apr 05, 2013 | Frigidaire ATF6000ES Front Load Washer
Atf6000es1 error code 43
Replace Main Control Board - consult a professional before going further.
Aug 14, 2012 | Frigidaire ATF6000ES Front Load Washer
Frigidaire washer model ATF6000ES1 door not locking, the door closes, but it's not recognized by control panel.
You are having a problem with the door latch sensor indicating everything is connected correctly. Check to make sure your door is not sagging and then make sure the door latch is not broken or cracked.
Jul 22, 2012 | GE Energy Star WCVH6260F Front Load Washer
Fix door ATF6000ES1
What is the problem with the door?
May 22, 2012 | Frigidaire ATF6000ES Front Load Washer
I transported my frigidaire front load washer.water leaks.
Check your pipes /drain and sump hose sounds lie something has came off in transit
Apr 08, 2010 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Affinity ATF6000Es1 washer- Keep getting an alarm and an E10 code and have to restart the washer each time the code comes up.
E10 code indicates there is no water supply.This can be confirmed by :
  1. Shut off the faucet to stop water supply to the washer.
  2. Disconnect and pulling the supply hose off the washer to confirm the E10Code
    • Opening the faucet and watch for running water
E10 also means that your cold water is coming in too slow, disconnect the cold water hose and check to see if the screen on your washing machine is clogged. If the screen is clean and the hose has good pressure then you will need to replace the water valve on your machine--- this is the piece that the hoses directly connect to.
Oct 18, 2009 | Frigidaire Affinity ATF6000F Front Load...
Fridgidaire Affinity ATF6000ES1 washing machine
Checked the internet for manuals and found one that had a blowup of the parts sequence. Also found instructions at the manufacturers site for trouble shooting and repair.
Jun 13, 2009 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire front load washer model LTF2940FEO. As
remove lower kick panel and check for leak at door boot and drain pump.
Apr 23, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire front loader leaking water
try turning the water supply down and recheck the form of water spray from above the soap tray(with it out and a towel there). if the jets of water are spraying everywhere it means there are semi blocked holes. either clean them out thorougly or drop the water pressure down to a fast trickle. tone.
Jun 07, 2007 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
37 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
