Question about BernzOmatic TS4000T Trigger-Start Torch
Bernzomatic ts4000 After a year the touch now leaks gas out a little hole in the front.
Why is the car leaking fuel at the rear passenger side
trace the fuel line coming from the tank going to front of car and look for leaks. With a car that is 15 years old the gas line may be leaking
May 31, 2014 | 1999 Lincoln Continental
Micro torch
to little air - air holes blocked up
Feb 23, 2014 | Omega Bernzomatic Corporation ST2200T...
Bernzomatic patio heater will not light?
these had problems with purging air out of the system.that may take a while and make sure you have spark.
May 01, 2012 | RTO Bernzomatic Brushed Nickel Patio...
I just filled my gas tank up in my 97 oldsmobile aurora, the 1st time that i have in about a year, after i did i drove to a school, and noticed smoke or steam coming from other hood, water (Large coolant...
You may have an issue with either dry rot of the rubber hoses or possibly a varmit got under the hood and chewed holes in hoses or wiring (happens all the time to vehicles stored for long periods of time).-Your fuel injection hoses up top pressurize to over 40 psi, so they need to be in good condition. If you are leaking fuel, do not drive it until you replace the leaking hoses, and driving an aluminum engine that is low or out of coolant is pretty much asking for disaster-better to get it towed and repaired.
Feb 23, 2011 | 1999 Oldsmobile Aurora
My ts4000 trigger is leaking gas from the small hole on the side of it, it will empty the cylinder. if you put your finger in the hole to try to stop the gas coming out it will eventually stop. the ruber...
While it is most likely a bad seal, I would recommend replacing just for the sake of safety. There are just too many horror stories out there about leaking torches, and while propane may not burn as hot as oxy/act, It is still enough to leave you with a lifetime of regret at best. Consider the biggest financial investment in your toolbox ... yourself.
Feb 07, 2011 | Garden
The bernzomatic patio heater will stay lit only if I continuously press the control knob
More than likely it is a bad thermocoupler. The thermocoupler is that pointed piece that receives the shock when pressing the ignite knob. You will have to take the unit apart to get to it. It is the pointed part with stiff wire attached that is between the shock electrode and the pilot light. It could also be the magnetic valve at the base of your control knob, but I doubt it. It could also be the tip switch which you can test with a simple continuity bulb or tester. The tip switch is wired inline between the thermocoupler and the control valve and knob assembly. It is about nickle size and has 2 wires attached to it. You can test the magnetic valve by removing it from bottom or base of the control knob and touch one end of it on a AA battery and the other end of it jumper to the opposite end of the same battery while depressing the spring at the same time. If the magnetic switch is working you will feel the magnets attract until you pull the battery or jumper wire away disrupting the connection. There is also a way to measure the resistance of the thermocouple but if you have tested the other two items you can bank that the thermocoupler is bad. Before and after make sure you don't have any leaks by using a soapy water in a spray bottle at all of the gas connections as per the owners manual.
Jan 14, 2011 | RTO Bernzomatic Brushed Nickel Patio...
Need to replace a control knob on bernzomatic patio heater, where would I get one? Called the company and they said they don't make them anymore.
what you could do is have like a lever valve (like the ones on garden hoses but for gas systems)
and then have the burner on full blast but you control the amount of gas going in
Jan 15, 2010 | RTO Bernzomatic Brushed Nickel Patio...
Craftsman 32cc would not start. What can I adjust or change so that it would start?
mine leaks gas from the little hole in the front of the carburetor when priming bulb
Jun 04, 2009 | Craftsman 25cc Gas Line Trimmer
BernzOmatic TS4000T Trigger-Start Torch Logo
517 people viewed this question
Top BernzOmatic Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a BernzOmatic Tool and Hardware - Other Expert? Answer questions, earn points and help others
