Question about Dehumidifiers
Mitsubishi MJ-E16VX-E1 fault code E8 - Dehumidifiers
Hi I have problems with my mitsubishi dehumidifier Oasis Elite MJ-E-142NX-A1 The water tank full light stays on even though the tank is empty. I have emptied the water and replaced the container care
Sounds like your float is stuck in the full position, or the sensor that shows full is stuck on full.
If tank is empty but shows full, problem lies where full signal is coming from.
Aug 19, 2014 | Dehumidifiers
Humidity sensor
Go to Http://www.Haier.com/us/products/home-comfort/dehumidifiers . Select the model number and proceed to the Manual. Download the manual and look at the E-Codes to solve your problem.
Dec 19, 2013 | Haier 65-Pint Dehumidifier
What does E1 mean on the display of my dehumidifier
follow this steps and fix it. God bless you
E1 error code : Deshumidifier
indicates generally an issue with rh sensor on the back of the control. However, at this time we would like to gather further information relating to the application if possible.
Oct 29, 2013 | Haier DE65EK 65 Pints eco-Friendly...
Whar does the E1 code suggest I do?
E1 indicates that the filter needs to be removed and cleaned. Be sure to turn the unit OFF and plug it, before removing the filter. You can either vacuum the filter or if it's really dirty, wash it in warm water and dish washing liquid, rinse and thoroughly dry it, before reinstalling it. NEVER operate the dehumidifier without the filter installed. Doing so could cause damage to the unit.
Jul 04, 2011 | Dayton 1DGX4 Dehumidifier
E1 CODE ERROR
E1 code for the primary humidity sensor behind right side grill. Unit MUST be unplugged from outlet. Take right side grill out, unplug sensor from wire socket and plug back. If no help, you need new sensor.
Dec 30, 2009 | Danby DDR451 Dehumidifier
My DANBY Dehumidifier model DDR4588EE has been working ok until it showed a E1 error code and since then it does not work properly. Any ideas please?
Dec 30, 2009 | Dehumidifiers
My model DDR6588EE dehumidifier runs for a while and then stops displaying an E1. If I hit power button it will run a while and do the same thing. This also happens on Continuous mode. Is there some thing...
Dec 25, 2009 | Danby DDR6588EE Dehumidifier
Kenmore model # 25800-25801 Error code E1?
unit has a sealed system leak call sears for tech support 1-800-905-9505 it is under warranty
Apr 15, 2008 | Kenmore 53701 Dehumidifier
Danby Dehumidifier
I dropped the water bucket by accident on the dehumidifier, and I have the same problem. Here what I found :
First, remove the water bucket and find the circuit diagram, it is very useful.
E1 code is related to the room humidity sensor, E2 code is related to the room temperature sensor and E3 code is related to the safety thermistor sensor. If you have one of these error code displayed, you will probably have to replace the sensor.
The humidity and temp sensors are located on the same board. To access it, remove the water bucket and you will see the 2 screws holding the front panel. Remove the screws, then gently prayed the front panel. Be careful, there is two plastic clip on the top of the panel and they are really easy to break. The board is located at the top right, under the cover. The safety thermistor is located on a pipe on the right side of the dehumidifier.
Aug 02, 2006 | Danby DDR583R Dehumidifier
Dehumidifiers Logo
196 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
