I have a kenore canister vacuum . the bag is new ,the hoses are clear, it won't pick up . What do I do ? help
Model 116.22512200
It does pick up but the suction is significantly weak. I have cleaned the HEPA filter and inserted a new bag. Add'l. it has a suction indicator that currently indicates suction is fine.
Comments:
Feb 06, 2009
- The hose had a small crack and I replaced both the HEPA filter at the back and the dust filter inside. Seems to be much better now, thanks!!
At the top of your wand, do you have a plastic swivel that cover a hole in the wand? This is for when you are cleaning curtains, and if that is open, or cracked you will loose suction there... also check your hose for cracks, or breaks. If it were in the shop I would put a gauge on it... normal suction is about 80-95 inches of water lift at the end of the hose. Once you have check each section of the hose, and wand, check the housing for cracks, a missing gasket (Very Good Reason For Lack Of Suction) As to your Filter, how long have you used that one filter, you can clean them for a while, but once a paper filter gets full of FINE dust you won't get it all out, you will have to replace the filter itself at that point. I hope this was helpful.
Was this helpful?
Yes
No
Popular Solutions for Kenmore 22512 Bagged Canister
vacuum repair, Dyson upright. Sucked up old slipper; slipper removed but now vacuum runs but will...
(More)
vacuum repair, Dyson upright. Sucked up old slipper; slipper removed but now vacuum runs but will not ****.
