Question about Ruud Matching Split Air Conditioner
Smell when unit comes on with heat
I have a ruud heatpump in home. When heat comes on there is a smell of something burning. Only notice it in morning when it first comes on.
  • 163 Answers
Hi!!!remember everytime you turn on yout furnace you will have a strange odor thats all the dirt that is burning from the heating element if your using the emergency heta if not the what you are smelling is your fan motor replace it and you should be fine..Good luck..
Posted on Jan 19, 2009
I smell an odor possibly electrical but I was unsure and had the gas company come and check. The gas company serviceman states the gas connections are good, nos gas smell in any areas of the house. The...
You should have an Amp draw on the system and it's motors. Your nose will be your guide in figuring out what component is getting hot. Smell circuit board and electric motors.
Jan 16, 2011 | Ruud UBHC Air Conditioner
Unit set to heat but outside unit fan won't turn on. Outside temp is below freezing. The weird thing is that you unit is putting out heat and not set to emergency heat
If it is a heatpump, the outside unit should not turn on below 35degrees or so. Below that temperature, the unit cannot effeciently exchange heat. When the outside temperature is low, the system automatically switches over to auxillary heat which uses the same heating elements as emergency heat.
Jan 11, 2011 | Ruud Heating & Cooling
I have ruud heatpump and it is covered in ice and it does not seem to be defrosting what could this be?
The defrost sensor attached to the outside coil is defective and or the defrost control board in the outside unit is defective.
To defrost the unit,turn the thermostat to cool and lower the temperature as low as it will go. Run in the cool mode until the coils defrost. Then return to heat mode.
Jan 16, 2010 | Ruud Heating & Cooling
Hello, I have a 1.5 ton rudd ac/heat pump
Your outside unit is not defrosting. You need to call a service tech to check it out. Defrost board sensor or low on gas. Also you amy have an outside tstat that is not working correctly. Rus
Dec 06, 2009 | Ruud UAMB042 Air Conditioner
Moved into a new house with a goodman air conditioner. it is also the heater (?). No experience with this. Is there something we need to do when switching from air conditioning to heating? we turned it to...
Well it might be a heatpump. Where it uses the A/C portion of the system to draw heat from out side and place it into you home. If its a new home I would call for a Check-Up its only $60 to $80. But dont buy anything you dont need like a new thermostat. Just tell them to check the refrigernt levels and to tell you if everything is runing ok.
Oct 16, 2009 | Goodman CLQ36AR49 Air Conditioner
Ruud heatpump with electrice heat backup
Sounds like one or more of the following -
1) the thermal fuse for each of the elements have melted
2) the elements themselves have broken and opened
3) Heat sequencers have failed
4) One or more fuses inside the heater have failed (if fuses were installed from the factory.).
Items 1 and 2 are indications of poor airflow through the unit for some reason (dirty filter, closed vents, dirty evaporator/buildup of dirt/dust on evaporator.)
Jan 20, 2009 | Ruud Central System Air Conditioner
RUUD HVAC UNIT - HEAT STRIPS COME ON WITH THE A/C
What you are talking about I think are the strip heaters in the Air Handler this must be a Heat Pump system right??? If so please check your thermostat and make sure it is not in EMRGY HEAT mode.. One other note there is a 2 stage bulb system inside the stat if it is too cold outside and the heatpump on its own cant keep up with the call for heat the 2nd bulb closes and turns on the heater as a supplumnetal heat also these will come on or should come on when the unit goes into defrost.. plz let me know what it is you are trying to test and i can walk you thru it.. Also need a model # off the A/H to get a Wiring diagram
Feb 03, 2008 | Ruud Handler Air Conditioner
Heater problem model PHK 080-1
THE BURNING SMELL IS NORMAL. BEFORE HEATING SEASON OPEN ALL DOORS AND TURN THE HEAT UP AND LET RUN TILL ALL DUST IS BURNT OFF. IF BLOWER IS NOT COMMING ON NOW. THERE ARE 2 TIME DELAY RELAYS, AND ANOTHER RELAY FOR "FAN ONLY OPERATION". ALWAYS MAKE SURE THEY ARE NOT THE PROBLEM BEFORE REPLACING AN EXPENSIVE MOTOR.
Feb 07, 2007 | Goodman PHKJ060-1 Air Conditioner
Ruud Matching Split Air Conditioner Logo
293 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
